Closed Thread
Old 01-19-2016, 04:13 AM   #301
Roadkill58
Roadkill58's Avatar
Re: Roadkill's 58 Chevy Stepside
Originally Posted by ptc View Post
YEa I was hoping for mine to be ready to at least go down the road by then, but people been holding me up! I was waiting on some roll bar guys that said they could swing me a deal... well the deal became just wasting my time!
Ordered one today from ChassisWorks.
Weather is holding me up. My open air shop is not working out this time of year. My Les Nesman shop.
All of you can stop praying for rain now.
Rust Never Sleeps
Roadkill's 58 Chevy Stepside build
Roadkill's 69 Custom C20
Roadkill58 is offline
Old 02-03-2016, 05:04 PM   #302
Roadkill58
Roadkill58's Avatar
Last weekend my brother helped me get the cab back on the chassis.
After the bed is on I can:
1. Set pinion angle.
2. Finish fabricating torque arm mount.
3. Cut tube to length for brake booster to brake pedal assembly.
4. Finish steering rod from rack to steering column via a heim joint and bracket. Sets me up for an LS engine in the future.
Rust Never Sleeps
Old 02-03-2016, 06:12 PM   #303
ptc
ptc's Avatar
Looking good there Jim! - Looking like a truck again, its always good to get the cab on - its like the HEART of the entire build. Everything passes thru there.
My Build: 57 Chevy Pro-Street
ptc is offline
Old 02-03-2016, 06:17 PM   #304
Task Force Era
Task Force Era's Avatar
Exactly! Such a rad feeling setting the cab back on after an extended time
Task Force Era is offline
Old 02-03-2016, 11:33 PM   #305
Roadkill58
Roadkill58's Avatar
Thanks PTC, Task Force Era.
The cab was off way too long.
I am going to drive it this year even if it is multi colored.
Rust Never Sleeps
Old 02-04-2016, 12:11 AM   #306
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice progress!
ChuckDriver is offline
Old 02-04-2016, 03:10 PM   #307
ptc
ptc's Avatar
I am going to drive it this year even if it is multi colored..
Mine too, paint or no paint !!!! Im ready to be driving already!!!!
ptc is offline
Old 02-04-2016, 09:40 PM   #308
Roadkill58
Roadkill58's Avatar
Originally Posted by ChuckDriver View Post
Nice progress!
Thanks JJ!
How is your PB install going?
Rust Never Sleeps
Old 02-04-2016, 09:44 PM   #309
Roadkill58
Roadkill58's Avatar
I was starting to think paint was over-rated....until I looked at tpimuncie's build thread again.
Rust Never Sleeps
Old 02-05-2016, 07:57 AM   #310
ChuckDriver
Thanks JJ!
Still very sloooooow!
.[/QUOTE]
Old 06-07-2016, 06:01 PM   #311
ptc
ptc's Avatar
Hey Jim I hope youre still pluggin away at this thing! we gotta be driving these things come this fall....
ptc is offline
Old 06-08-2016, 01:04 PM   #312
Roadkill58
Roadkill58's Avatar
I'm getting a little done here and there. Got the rear end pinion angle set and tack welded. Working on torque arm mount design.
Need to shorten the drive line by about 10 1/2".
Shortened the steering column and need to re-assemble it.
I almost bought a Cadillac CTS for the independent rear suspension (like Camaro).
Making mods to my new blast cabinet so that it actually works.
Built a 212' redwood fence (still need to make a gate).
Drove to Oregon and helped brother in law demo and build a deck.
Graduations, Weddings, and other stuff will steal some weekends from the truck.
Yeah it's time to get this truck on the road.
Rust Never Sleeps
Old 07-21-2016, 07:17 PM   #313
tpimuncie
tpimuncie's Avatar
Look at all that stainless!!
1959 apache 1948 chevy coupe
http://67-72chevytrucks.com/vboard/s...d.php?t=562949
1964 gmc burban build for pops
http://67-72chevytrucks.com/vboard/s...d.php?t=724632
tpimuncie is offline
Old 07-22-2016, 11:28 AM   #314
Roadkill58
Roadkill58's Avatar
Do you mean the trim on the cab?
The square stock on the ground is mild steel left over from the rack on the 69.
Rust Never Sleeps
Old 07-22-2016, 12:15 PM   #315
II_Slow
II_Slow's Avatar
A few posts up was some discussion about how great it is getting the cab on one. For some odd reason, I just really liked getting the bed on mine for the first and being able to sit on the tailgate and drink a beer. I guess it just really felt like a real truck then - not just a pile of parts.
Keep plugging away at it, brother. Any progress is good!
1955 SB Stepside 3100 big window cab on a 99 Ram 2500 Frame w/ 12-V Cummins diesel power and
47RH AOD transmission
http://67-72chevytrucks.com/vboard/s...d.php?t=640042
II_Slow is offline
Old 07-25-2016, 04:18 PM   #316
Roadkill58
Roadkill58's Avatar
Thanks II_Slow.
Rust Never Sleeps
Old 07-25-2016, 04:29 PM   #317
Roadkill58
Roadkill58's Avatar
My brother re-assembled the truck column I shortened.
Finally got it mounted (temporary brackets) in the cab.
Also welded heim support and connected D-shaft and universal joints.
It's nice to be able to steer the truck with the steering wheel instead of kicking the tire while it's rolling.
This morning I made a pattern for the torque arm mount before rolling the truck off the lift.
I still need to trim it up a little. I hope it will clear the drive shaft.
Rust Never Sleeps
Old 07-25-2016, 05:32 PM   #318
ptc
ptc's Avatar
Looking good ------ every little bit counts!!!!
ptc is offline
Old 07-25-2016, 05:48 PM   #319
Roadkill58
Roadkill58's Avatar
Thanks ptc.
I'm starting to think I will get it running and driving by the end of August.
Will be driving it ugly, but driving.
Rust Never Sleeps
Old 07-28-2016, 02:30 AM   #320
Roadkill58
Roadkill58's Avatar
Today I removed 9 1/4" from the drive line that was in the truck when I bought it.
The rear end yoke does not match up to the truck drive line.
The front yoke slides right in the muncie trans.
With the torque arm bracket almost in place (no bracing or welding) it's very close to the drive line.
I called Drive Line Service of West Sacramento and was told I would be fine with a smaller tube (2 3/4").
Tomorrow I'm taking the drive line to DLS and they will make me a new one using the front yoke (if it passes inspection) and rear u-joint to fit the IROC rear end yoke.
Rust Never Sleeps
Old 07-28-2016, 09:04 PM   #321
Roadkill58
Roadkill58's Avatar
This morning before removing the drive shaft I loosened the bolts on the torque arm at the rear end housing.
I was able to adjust it a little bit which made a difference of about a 3/4" at the other end.
Now I can have the drive line built with a 3" tube.
Removed the pinion yoke (needed to replace the seal anyway) to take to Drive Line Service so there would be no mistake as to what was needed.
Decided to have them build a complete drive line so I could keep the old one for mock-up on the other trucks.
I'm hoping to get a call tomorrow to pick it up.
Rust Never Sleeps
Old 07-29-2016, 05:16 PM   #322
Roadkill58
Roadkill58's Avatar
Got the call from Drive Line Service to pick up the new drive line this morning.
Cleaned and painted the torque arm mount.
Still deciding if I want to weld the bracket, or make it bolt in.
Rust Never Sleeps
Old 08-02-2016, 01:19 AM   #323
ptc
ptc's Avatar
Dang that is sweet!!!! Jimmie and the guys do some nice work down there at DLS!!!!!
Im hoping to talk my motor guys into getting my engine to me by this week so I can get him hot on a driveline for my rig to get it going! Big Car, Truck, Boat show at clear lake Aug 12-14 coming up....
ptc is offline
Old 08-02-2016, 02:54 AM   #324
Roadkill58
Roadkill58's Avatar
They do some good work, and fast turn around.
My tractor parts came today. Got the fan and water pump painted and ready for installation in the morning.
I can't get anything out of the engine shed without the tractor.
Got a deep cut Milwaukee band saw at the swap meet on Saturday.
I have wanted one for a long time.
Rust Never Sleeps
Old 08-13-2016, 01:51 AM   #325
Roadkill58
Roadkill58's Avatar
Torque arm mount is about done (trim up and paint).
Removed mock-up engine. Retrieved 355 SBC from engine shed.
I removed the mechanical fuel pump & rod from the block. Noticed some grit at the bottom of the fuel pump cavity on the block. Not a good sign.
Removed oil pan and found a bunch of crud in the oil pump pickup screen.
Removed timing cover and found a gear drive and it was clean.
I could see the bottoms of the pistons were still clean.
I'm wondering if this was a Canadian motor.
Under the ford blue and Chevy orange there was a metallic green color. I remember my high school auto shop teacher had just moved from Canada to Sacramento and his car (don't remember the model, don't think it was a Chevy) had a SBC painted the same color.
It also had an extension cord coming out of the oil pan which I thought was funny.
Anyway I am doing an in depth inspection and cleanup on this motor before it goes in the truck.
Rust Never Sleeps
Closed Thread
