Old 10-07-2015, 11:22 PM   #301
chewychevy67
Re: 67 GMC super custom build
Thank you for the kind words. I am going to have a hard choice on the colors. I like them both. Was hoping these renders could help me with a solid decision but has not. I wish I could see the red interior through the glass. That would help.
chewychevy67 is offline   Reply With Quote
Old 10-08-2015, 10:48 PM   #302
chewychevy67
Here is one with the black roof and a light background. Also this one has the drip rail moulding. I am pretty sure I am going all black. The white does look good but with the red interior I am scared there will be too many colors close to each other.
Old 10-09-2015, 06:00 AM   #303
darkhorse970
darkhorse970's Avatar
Black, red, and chrome is as good as it gets! Very cool truck!
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 10-09-2015, 09:10 AM   #304
Hart_Rod
Hart_Rod's Avatar
Great progress! The truck looks outstanding!
Hart_Rod is offline   Reply With Quote
Old 10-09-2015, 09:58 AM   #305
slowcpe
slowcpe's Avatar
Looking good! My vote would be all black.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 11-14-2015, 11:27 PM   #306
junkcarguy
Was just thinking of your running an auto you should run the 68-69 camero disc brake pedal that's wide with a trim ring to match
junkcarguy is offline   Reply With Quote
Old 11-15-2015, 01:49 AM   #307
chewychevy67
I thought about that when i consiidered discs but I decided not to run disc brakes.
Old 11-27-2015, 08:07 PM   #308
chewychevy67
I found someone with a 1967 Oldsmobile tilt-telescopic steering column. it has the 4 way flasher and no ignition in the column so I figured id try it on my column. I found out that you can simply remove the top from the tilt and simply use the top pieces from the tilt-telescopic and install. even the wiring harness just plugs in the same. The only mod is the light for the gear selector and light which should be no problem. Here are the pictures of the bottom part. If i set the column back to the gauges this should still be useable I hope and not too close to the driver. when I am finished ill put my seats in and check it out.
Old 11-27-2015, 08:14 PM   #309
Hart_Rod
Hart_Rod's Avatar
Slick!
Old 11-28-2015, 09:11 PM   #310
chewychevy67
I got the column all done for the telescopic tonight. Here is how it turned out. I think that it turned out very nice. ill have to put my seats and my column in the truck now to see how this works and how close it gets to the driver. I may have to find a flatter ( less dish) wheel. If I need one I would like one off of a 1965-66 impala telescopic column and just adapt my GMC horn button to it.
Old 11-28-2015, 09:16 PM   #311
chewychevy67
two more that show it short and long. I broke my shift indicator piece so I will have to get a new one. But that all works nicely and accurately too.
Old 11-30-2015, 04:47 PM   #312
chewychevy67
here is how it looks in the truck. I think the wheel is too far back. I might put the seat in it to get a feel. if I change wheels it will be to the one below. it is more flat and made for the telescopic column.
Old 11-30-2015, 06:46 PM   #313
chewychevy67
...and a few more with the driver seat installed. the wheel is not as close as I thought. ill have to think about the steering wheels for a bit.
Old 12-02-2015, 12:35 AM   #314
swamp rat
swamp rat's Avatar
OK, now ya gotta take it apart and do it again after paint! Pretty cool mod.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-02-2015, 02:50 PM   #315
chewychevy67
The whole cab is coming back down to metal in feb. James (nuke1) is going to do the truck after the shotty work I had done in 2010. So it will all need to be repainted. That's why I'm doing these last few mods. After the cab is done this time that will be it.
Old 12-04-2015, 09:40 AM   #316
chewychevy67
I have done a little searching and found that this wheel will also work on this column. Its from a 66 cadillac. I may buy one. I like that it is 3 spoke. A little closer to the original wheel.
Old 12-04-2015, 04:56 PM   #317
chewychevy67
I measured the column distance from the dash to the top of the wheel. the tilt telescopic column fits great and works just as it should and looks proper. I moved the column back and did some measurements. I used my 70 without tilt in stock position and my 67 with pushed back column with for the measurements. I can move the wheel from the top of the gauges from 11.5" to 14". The 70's wheel from stock sits 12" from the same spot. I can move it 0.5" further back from where it was stock. no gain at all. when I get the other wheels ill do this again. I think the impala wheel will sit 1" - 2" closer to the gauges just because it is designed that way. If not I guess it will just be for the cool factor.
Old 12-11-2015, 12:54 AM   #318
chewychevy67
While I had the seat and the vent window frame in I put the thermometer on the mirror arm with the mirror just to see if when I sit down I can see it clearly and I can. I was worried the division bar would be in the way. Here are some pictures. I will put a black decal on the end of the lens so it does not shine into the mirror head. the housing would be black, not chrome, to match the mirror arm. obviously the tape will be removed if I decide to use this and it will be mounted with a screw.
Old 12-11-2015, 05:55 PM   #319
chewychevy67
mounted to the arm.
Old 12-11-2015, 06:31 PM   #320
chewychevy67
and finished.
Old 12-14-2015, 01:19 PM   #321
chewychevy67
Here is the 66 impala telescopic wheel installed. This moved the rim of the wheel back to 9 3/4" from the gauges and I can move it out to 13". that is a nice range.
Old 12-14-2015, 02:42 PM   #322
Hart_Rod
Hart_Rod's Avatar
Very slick.....
Old 12-17-2015, 10:09 PM   #323
chewychevy67
Thanks to photoshop here's the interior with the tele wheel. I like the 2 tone wheel but will probably keep it all 1 color.
Old 12-18-2015, 02:17 AM   #324
nuke1
nuke1's Avatar
Looking really good rod!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 12-20-2015, 11:03 PM   #325
nuke1
nuke1's Avatar
Hey Rod, I looked at your door panels and have an idea for your switchs how they are mounted. we will have to talk in the near future to discuss it.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
