#301 | |
Re: 78 silverado stepside her names 'Quicksilver'
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
#302 | |
Her name is Quicksilver 1978 Chevrolet silverado, shortbox stepside currently being swapped IN is a LM7 5300 vortec, 4l80E, factory 4.11s, slammed, a dream ride and coined QUICKSILVER gotta pay $$ if you wanna play ![]() |
#303 |
Nice!!! looking forward too it man, going to be suuuuuuuhweeeeeeeeeet!!!!!
#304 | |
#305 | |
#306 | |
#307 | |
#308 |
well, i didnt mention the Camaro i had before the truck, did i? well i just so happen to let the truck go for the camaro... but truck isnt finished and my brother inlaw owns it now.... that means... i can update both camaro and project aka "my baby" Quicksilver on this thread.. hes really a funny guy and intelligent, been asking when he will update this thread and this forum with his wisdom... I did it because of the LS swap and he like sqaure bodys, but not one has he ever known this valable... lmao
#309 | |
#310 | |
#311 | |
Well at least the truck is in a good home and you know where it is, so best of luck to your bro in law hopefully it'll be running soon!
#312 | |
#313 |
Thats great news!!!
#314 |
imma mess with the 350 in my car, bore the engine 30 over and make it a 355...
new connecting rods and pistons. im gonna invest a budget of 1000 dollars in the valve train.. that includes the camshaft, valves, valve springs rocker arms, guideplates, studs, and the pushrods..
#315 |
Well I decided I wanted my truck back because it has the 5.3 liter in it. My intentions for it now, ls6 camshaft, twin turbos, and a good tune. Of course I'm gonna fix the bed with some fresh lumber.
#316 |
Tomorrow is gonna be fun. I may not have the money but I do have a welder. I'm gonna fashion my own transmember. Since I have angle iron laying around I think it'll be easy. There's another positive thing I may do to the truck. I'm gonna check and see if I can remove the egr tube from the exhaust manifold so it clears the frame.
#317 |
![]() ![]() Yes!! I have the alternator and powersteering bracket for the truck! The correct one finally... After obtaining it, ill never go to the pick and pull in said city were I got my engine, cause I got a better source of parts elsewhere in a different city that actually keep there harnesses and brackets on there engines. Lol. I imediatley wanted to call the guys who sold me the engine for making me go elsewhere and spend most of what have should have been spent on other things instead of a new harness. I digress though since its my fault for falling for easy and cheap engine for sale. Well anyways, I got the new transmission gasket since the one that is on it has been leaking since I jacked the tranny up by the pan so ill have to do that also the pan isn't clearing stock crossmember so ill have to make one of angle iron on hand. Fuel pump I got lying around in a MPFI v6 buick car tank, looked up specs, and says it puts out 65 psi, correct amount for the 5.3 LM7 fuel rails, also has the built in fuel regulator. For this swap ill have to go without a high pressure cooling system, and opt for a 160 degree thermostat since I'd like to keep my stock radiator and stock heating core, which are atleast 32 years old. All I need to do is figure out how to connect the CS130D to my piggy back wiring harness system. Also have the correct throttle cable for efi, came from a 99 tahoe with a 350 vortec. Plan on doing this, but another obstacle is the exhaust manifold egr on the passenger side. I'm going to take it off, and since I have a mig at my finger tips ill cut the egr opening flush off the manifold and weld some steel angle iron or aka bed railing on. I reassure you tje manifolds are cast steel. Wish me luck!! Any advice on the CS130D and the pcm, and the truck harness, let me know
