12-16-2015, 12:34 AM | #301 | |
Re: 75 Dually build
12-16-2015, 11:00 PM | #302 | |
Re: 75 Dually build
The truck is sitting on the CM in that pic. I never wanted to body this ride, maybe the next one, but not this truck. I want it just like it sits today. |
12-16-2015, 11:01 PM | #303 |
Re: 75 Dually build
12-16-2015, 11:01 PM | #304 |
Re: 75 Dually build
So Santa UPS dropped by today and left these toys for me to play with! Trying to get this truck ready for Lone Star Throwdown and other 2016 shows.
01-06-2016, 01:17 AM | #305 |
Re: 75 Dually build
Well I actually got some real work done on the truck tonight. I am changing out the brake booster and master cylinder from the Suburban to the correct hydro boost booster and matching master cylinder. The brakes should work a lot better from now on. The only thing I have left to do is get new lines made up for the high pressure side, and get a "T" fitting to tie into the low pressure return line. The pics below show the new master and the hydro boost just after I shot some Rustoleum on them for protection.
Lots more to do before it rolls out of the shop, but at least I am checking off one item at a time. Stay tuned... |
01-08-2016, 09:52 PM | #306 |
Re: 75 Dually build
The hydro boost is now done! Ok I still have to bleed the brakes, but hey it's mostly done!! Yes the brake lines need the bends to be cleaned up, and all that wiring needs to be cleaned up as well. The underside of the engine bay really needs some attention.
I was so glad to have the OEM lines from Napa. They made this so much easier and cleaner. I also did the spark plugs on this side of the motor because the brake system was out of the way. Talk about a knuckle buster with all that stuff in the way... I will get the other side done tomorrow, we are now getting freezing rain and more snow on the way. Yeah! |
01-08-2016, 10:32 PM | #307 | |
Re: 75 Dually build
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
01-08-2016, 11:07 PM | #308 |
Re: 75 Dually build
I just cant get past all the lines from OE set-ups. That's why I swapped to a vacuum. There were a couple high end set-ups that really clean things up (HydraTech) but their about a G.
01-08-2016, 11:13 PM | #309 |
Re: 75 Dually build
01-08-2016, 11:41 PM | #310 |
Re: 75 Dually build
So is my dually. I cant wait to get mine on air. Just about got all the parts now just gotta come up with the time. Im in the middle of a rewire on the pro street then gotta get my dually ready for the haul to LST next month. After that its getting some air..
01-09-2016, 12:01 AM | #311 |
Re: 75 Dually build
Are you bringing both to LST? I'm almost tempted to bring the new 68 on my trailer to LST.
01-09-2016, 12:08 AM | #312 |
Re: 75 Dually build
I registered the Pro-Street but Im pulling it down there with the new dually. I Sold my black one and bought my son his first car and bought me a replacement with the money. Its Not as good looking but its got potential.
01-09-2016, 12:38 AM | #313 |
Re: 75 Dually build
That truck with Alcoa's, slammed, would be wicked!
01-09-2016, 12:41 AM | #314 |
Re: 75 Dually build
I'm going to lower it and put it on air but not gonna slam it. Just want a good ride quality without cutting my bed.. stay tuned. It's going under the knife after LST.
01-09-2016, 01:08 AM | #315 |
Re: 75 Dually build
Subscribed
01-11-2016, 02:27 AM | #316 |
Member of the longbed union.
Re: 75 Dually build
Looking good. What steering pump are you running?
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
01-11-2016, 12:33 PM | #317 |
Re: 75 Dually build
01-11-2016, 01:14 PM | #318 |
Re: 75 Dually build
Do you mind getting a pic when you can. I'm running a 454. Buy it has the remote reservoir for power steering and I haven't been able to find a new hose. And just wanna run the single unit pump/reservoir.
01-11-2016, 03:51 PM | #319 |
Re: 75 Dually build
Paul, I will try and snap a pic tonight of the pump for you.
01-11-2016, 11:35 PM | #320 |
Re: 75 Dually build
Here is the picture of the power steering pump and the new lines for the hydro booster. Man this truck needs a serious bath!
01-12-2016, 12:31 AM | #321 |
Re: 75 Dually build
Does your pump have the keyed shaft or the smooth one? I need a keyed one to mount my new pulleys, but I can't seem to figure out which years they came on...
83 Crew Dually build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=686192 Instagram: lofab77 |
01-12-2016, 12:43 AM | #322 |
Re: 75 Dually build
In all truth I do not know. My pump is a new pump, but it has been so long since I installed it... However I checked the Oriley's website, they have great pictures, and it showed a smooth shaft. So I would have to assume that is what I have. If it were me I would go down to Autozone (or similar parts outlet) and just have them pull a couple of pumps and check them out that way.
01-12-2016, 01:29 AM | #323 |
Re: 75 Dually build
Thanks for the pic. I'm trying to get mine all together but it's hard to work in it when u work out of town. Dang oilfield.
01-15-2016, 09:32 PM | #324 |
Re: 75 Dually build
Made a pedestal for the eLevel touch pad last night, got it installed today after work. I will leave it unfinished for a while so I can concentrate on other portions of the interior.
01-15-2016, 09:40 PM | #325 |
Re: 75 Dually build
That looks pretty good if I say so.
Tags |
air bags, alcoas, chevy, dually, lowered |
