03-14-2014, 02:19 AM | #301 |
Re: What did you do to your truck today part II.
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
03-14-2014, 08:01 AM | #302 |
I'm heading outside to start pulling off chrome and handles and the like. My 63 Burb goes off for paint Monday.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
03-14-2014, 09:20 AM | #303 |
Removed my rear air bags yesterday and put in a set of 3" drop rear coils. Hoping to fab up a watts link over the weekend and get rid of the original bar. Installed some Marshall 2 5/8" gauges. Hoping to get the bed liner sprayed too during this nice weather we are having. Then bodywork and paint, all in hopes of making a May 10th show we will be at as a vendor.
03-14-2014, 10:50 AM | #304 |
I ran out to Laguna Seca and bought a fresh drum of Sunoco 104. Gonna cruise over to Monterey tonight and scare some tourists.
03-14-2014, 03:39 PM | #305 |
dragged my machine up to my loft and snagged another harrison rad for $20 on the (e)bay yea!!!
03-14-2014, 03:42 PM | #306 |
my GM rad says its from a pontiac or oldsmobile anyway is the same shape and size 3 core and for an auto trans non ac
03-14-2014, 08:04 PM | #307 |
Post Whore
Hauled fertilizer with mine today. Also gave her a bath.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
03-14-2014, 08:32 PM | #308 |
Dragged the truck out of the yard where it has been sitting all winter and into the garage. Started dis-assembling the front end to start rust repair. One fender took an hour and involved cutting three bolts and snapping one more.
There is a *lot* of rot on the fenders, radiator support & front panel. Going to be interesting fabricating it all.
1964 C/10 Longbed Fleetside, base model. (build thread) (pictures) SOLD 1964 C/10 Shortbed Fleetside, Deluxe. (pictures) SOLD |
03-14-2014, 10:22 PM | #309 | |
03-15-2014, 01:12 AM | #310 |
Hi, Id like to second what OTM said, You may want to just get some used parts to save a lot of time, I do like your enthusiasm though.
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438 70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983 76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612 79 GMC 3500 Fleetside LB 454/400 90 Suburban Silverado 4x4 350/700R4 97 1500 Cheyenne Short Fleet 350/5sp |
03-15-2014, 09:15 AM | #311 |
I have been searching for used parts around here for months, with little luck. Pretty much everything in the northeast is just as rusted, or they want thousands of dollars for what I would call a parts truck. Metal and welding wire is relatively cheap compared to the $900+ aftermarket parts would be(not counting the inner fenders even), so I figure it'll be good practice to try doing it myself.
03-15-2014, 10:41 AM | #312 |
I got my gas tank the other day. The Fed Ex guy brought it to me.. yay. I started putting it together and have the sender set up to go in next.
I removed the spare Tire from my truck (which is an L78-15 Sears Bias-Ply Tire. I think it is dated as Jan 1988) drilled out the rivits to the retaining bar and that is pretty much where I am at now. Hoping to install the tank in the next few days and get the stock one out of the cab. Yes it stinks in there after putting fuel in.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
03-15-2014, 12:27 PM | #313 |
Here's the universal TBI tank installed between the frame rails of my 62. I also took the opportunity to wire loom frame wiring, paint the frame, install new 3" drop coil springs (2" blocks already installed), relocate the exhaust to discharge out the side(instead of under bed blowing on tank), change the cab bushings, paint the inside of the bed flat black and install a "new" custom wood floor.
03-15-2014, 01:18 PM | #314 | |
03-15-2014, 03:48 PM | #315 | |
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 03-15-2014 at 03:54 PM. |
03-16-2014, 08:40 PM | #316 |
Fired up the new motor for the first time. I will load the video later. It sounds healthy to say the least.
03-16-2014, 10:36 PM | #317 |
not really today but more like the whole weekend.
Started off Friday evening by placing the fuel cell between the rails in the rear. Then went on to running new fuel line from the rear of the truck to the front. Had to chill out for the day because I let a friend borrow one of our vehicles and was stranded at the house (needed parts). The next morning, went to the hardware store and bought enough nuts, bolts and washers to choke 5 evil donkeys and a stubborn mule. Also picked up various fittings and hoses. When I got back home, it was time to bolt everything in place. I also took out the old, in cab fuel tank and modified my transmission hump (running PB gear up front). Ran a few pounds of pressure to the temporary air lines and tires, cranked it up, and drove it out of the garage. She also took her first steps on the road but was cut short due to some bad lug nuts and no tags. But all in all, a very successful outing. She did get a bit fussy about going back into the garage though... which leads to the laundry list of items I need to do before making her truly road worthy (both known issues and some surprises). Cleaned myself up and headed out (minus truck) to a car show they have every third Saturday of the month. ...I now have a target due date. ..and the oil spot in front is from the Blazer... she was being a diva that day too! |
03-17-2014, 01:55 AM | #318 |
03-17-2014, 06:49 AM | #319 |
Sounds real good.
03-17-2014, 06:51 AM | #320 |
Took her off to be painted yesterday.
03-17-2014, 08:45 AM | #321 | |
03-20-2014, 05:39 PM | #322 |
I removed the west coast mirrors. installed a chrome front bumper. Went and cut a load of fire wood and tested it out.
03-20-2014, 07:32 PM | #323 |
Post Whore
Had to move my truck outta the way of the back hoe attachment so I could install it on the tractor. Took some pictures while I was at it. Showing off my sign "Chevy Truck Parking Only." lol.
03-20-2014, 10:00 PM | #324 |
Got new tires. 345/30r19 on all 4 corners.
Only to tow the truck home because I had too thick of a front wheel adapter. But when I finally changed it, everything cleared. |
03-20-2014, 11:21 PM | #325 | |
wow how does that work .? tubbed.? I have 245 50 16 and don't think i could go any large on rear stock setup ....sp . picked up paint for interior . . . |
