Old 02-20-2016, 04:48 AM   #301
MTCK
MTCK's Avatar
Re: 1991 V3500 Project Heavy Hauler
Thanks for the pointers. I'm not too concerned with the cam install. It would be nice to have one of those gear driven stands that rotate but I'll figure it out.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Plow Truck
MTCK is offline   Reply With Quote
Old 02-20-2016, 04:59 AM   #302
watahyahknow
watahyahknow's Avatar
http://www.jalopyjournal.com/forum/t...-stand.734137/
made from a cam chain setup and a cheap handwinch
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 02-28-2016, 04:06 AM   #303
MTCK
MTCK's Avatar
Hey that's pretty cool. Now I wish I hadn't thrown my old timing set away.
Question for all the smart folks out there: I installed the cam and retaining plate and checked the end play. 80 thousandths. Installed the timing sprocket and checked again. 4.5 thousandths. Spec is 5-10 thousandths in the comp install manual. Is it proper to check with sprocket installed? The factory manual doesn't address this (that I can find).
-Marcus
Project Plow Truck
Old 02-28-2016, 04:08 AM   #304
MTCK
MTCK's Avatar
Stupid smart phone.
-Marcus
Project Plow Truck
Old 02-29-2016, 04:22 AM   #305
MTCK
MTCK's Avatar
Did a little searching and sprocket on is correct. I had over tightened the cam sprocket and when I backed it off my end play was right at 5 thousandths.
Spent a lot of time doing my favorite thing today: cleaning. Lifters all looked great, pushrods, rockers, lifter retainers and pushrod guides all cleaned.
-Marcus
Project Plow Truck
Old 02-29-2016, 04:25 AM   #306
MTCK
MTCK's Avatar
I started to put together my #1 cylinder valvetrain so I could degree the cam and discovered I was missing the spacers required to let the lock nut sit above the rocker elbow with no slack. Back to Amazon...
-Marcus
Project Plow Truck
Old 02-29-2016, 04:29 AM   #307
MTCK
MTCK's Avatar
Still went ahead and installed all the lifters, retainers, spider, rocker studs, pushrods and pushrod guides. I used the air hose spark plug adapter and spring compressor to install the lightweight springs on #1.
-Marcus
Project Plow Truck
Old 02-29-2016, 10:21 AM   #308
whitels1
whitels1's Avatar
Good work! Bummer about the missing parts, but keep at it!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 02-29-2016, 01:24 PM   #309
watahyahknow
wat i allways do with hydraulic lifters is compress them submerged in a bad of engineoil , gets the crud out of the inside of the lifters and you can see right away if there still working
leaving them in the engine oil till right before assembly is a good idea too
Old 03-02-2016, 12:23 PM   #310
MTCK
MTCK's Avatar
Thanks Dave. Yeah the red solo cup in the pic is full of lifters and oil.
Degreed the cam last night using intake cl method. Hit the number exactly so that was cool. That was easier than I thought.
Installed the crank oil seal and timing cover and went to turn the motor over and it was harder to turn over. Pulled the timing cover back off and it spun freely. Hmmm. Took the crank reluctor ring off and reinstalled the timing cover. Spun freely.
One of two things was going on. Either I didn't press the crank sprocket on quite far enough, or the new timing set is thicker.
Grabbed my harmonic balancer installer and went to check that the crank sprocket was all the way on and it pulled the threads right out the end of the crank. Hardly took any force so there is no way the balancer would have gone on. Looks like another side project... Ream and tap or drill and helicoil?
-Marcus
Project Plow Truck
Old 03-02-2016, 12:40 PM   #311
watahyahknow
normally you use an install tool wish you screw in the crank and use the tread on the tool to press the balancer on
hope you get the helicoil in correctly
Old 03-02-2016, 12:48 PM   #312
68Timber
I know the pieces fit
68Timber's Avatar
Great truck and great build. I'd probably call the machine shop that did the work for you and see what they think. I'd be afraid a helicoil insert would pull out without talking to someone that'd done that repair before.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 03-03-2016, 04:26 AM   #313
MTCK
MTCK's Avatar
Yep this is how my installer works.
Thanks Timber. I'm excited to get it all together. Chatted with our master mechanic and think I have a plan going forward. No helicoil.
Cleaned up inspected and reinstalled the oil pump, and my oil filter adapter, plug wires and throttle cable showed up from summit. I also ordered and received a new fuel rail, as mine had a broken injector lock tab. I'll get it all together with the new fuel pressure regulator soon.
-Marcus
Project Plow Truck
Old 03-06-2016, 11:41 PM   #314
MTCK
MTCK's Avatar
My fix on the stripped crank worked great. Reamed it out to 33/64" then tapped to 9/16-18. Balancer is on and torqued to 110 lb ft as specified.
I have another concern though. My reluctor right was contacting the timing cover (it's just outboard the crank timing sprocket) when I had the timing cover and no balancer installed. I gave the crank sprocket one more good game with the balancer installer then installed the balancer. Everything spins freely again now. I'm not sure if I got the sprocket on another fraction of an inch or if the balancer pressing the ring into the sprocket cleared up the rubbing. The balancer looks to me like it should go on a little further. My plan is to install the drive pulley and water pump and check alignment. If it is off the only thing I can think of is the comp cam timing set, specifically made for this motor is too thick??? Hope not...
-Marcus
Project Plow Truck
Old 03-07-2016, 01:36 AM   #315
watahyahknow
could be the cam cover bowed in a bit during installing due to the resistance of the sealring , might well be that it will spring back once you run the engine a little
Old 03-07-2016, 03:30 AM   #316
MTCK
MTCK's Avatar
Not sure I follow. You talking about the timing cover or cam retaining ring? It is the crank sprocket with the issue and timing cover is cast aluminum so it is pretty stiff.
The crank pulley and wear line on the water pump line up as close as I can measure with my carpenters square. I sent a question to comp cams tech support so we will see if they answer.
-Marcus
Project Plow Truck
Old 03-14-2016, 03:40 AM   #317
MTCK
MTCK's Avatar
Comp cams tech support was essentially worthless. I have them the part number of my timing chain and they wrote back and said we don't recommend a double roller timing chain with this motor. No crap it's a single roller spec'd out for a gen 6 in stock configuration.
It spins freely so I buttoned up the rest of the motor. I installed the plugs in the oil cooler lines and removed a bypass valve that needs to come out to eliminate the cooler. Pained the long block, installed the intake and primed the oiling system. Confirmed oil to the rockers and continued with assembly.
-Marcus
Project Plow Truck
Old 03-14-2016, 03:42 AM   #318
MTCK
MTCK's Avatar
Painted
-Marcus
Project Plow Truck
Old 03-14-2016, 03:43 AM   #319
MTCK
MTCK's Avatar
Engine stand protesting loudly.
-Marcus
Project Plow Truck
Old 03-14-2016, 09:05 AM   #320
y5mgisi
Second Chance Program
y5mgisi's Avatar
So awesome!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 03-14-2016, 10:04 AM   #321
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Seems like most tech lines are worthless when one calls for help.
The engine looks great! It would have never thought of gray but the L29 wears it well. The L29 is such a good looking big block…..so much cleaner looking than a L18. Can’t wait to hear when you get it going. Did you decide on manifolds or headers?
DirtyLarry is offline   Reply With Quote
Old 03-15-2016, 12:45 AM   #322
MTCK
MTCK's Avatar
Thanks guys. Honestly I had the two cans of grey laying around and figured it would be a good industrial look. And it will show any leaks. NOT THAT IT WILL LEAK.
Went with the manifolds. $138 delivered to my door thanks to Amazon Prime. Hard to argue with the almost $800 in savings and no fitment issues.
-Marcus
Project Plow Truck
Old 03-15-2016, 01:22 AM   #323
whitels1
whitels1's Avatar
Hell yes man! Keep up the good work!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 03-15-2016, 07:38 AM   #324
y5mgisi
y5mgisi's Avatar
Cab you post a link to the manifolds you bought?
Old 03-15-2016, 11:55 AM   #325
MTCK
MTCK's Avatar
Thanks Dave. Links below:
https://www.amazon.com/gp/aw/d/B000C..._st_dp_summary
-Marcus
Project Plow Truck
