Old 08-11-2015, 12:25 AM   #1
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
Re: New project! The "Red Herring"
Let's see if I can do this in something vaguely resembling order:
Intake elbow came in. Clearance is good on the fan and the belt drive. Yes my intake is presently made of PVC
Finished up the fuse panel mount. Realized I wasn't going to be able to take the panel out of it once it's wired, so painted it before installing:
Trailer hitch went on. It determines some of the exhaust, fuel and electrical routing so it was time to get it in place.
Pulled the rear springs and installed the track bar to center the rear end and push it right up to the bump stops so I can route the exhaust with adequate clearance (as well as check my tire - fender... a little snug!). Also confirmed that my driveshaft does NOT bottom out anywhere in the range ... somebody put some nagging doubts in my head on that one a while back.
Started in on the exhaust tonight. System is 304SS, 2.25" true duals, doing a traditional H-type crossover in 1.75" behind the trans cross member. Decided to route below the frame rather than through, because once my running boards are on, this will be level with them anyway so no need to take all the extra effort.
Let me tell you what, welding 16ga tubing to 1/2" manifold flanges is a PAIN!!! Using a 312SS rod on the stick welder to do a base pass and capping with the MiG ... ugly but it'll hold.
The flanges are set up for 2.5" OD pipe, so I had to expand the end of the tube to fit, which is okay because it allowed for some misalignment to clear the lower A-Arm mounts.
In other news, the new water neck came in today. It's not clocked down *quite* as much as I had hoped, which means it's back to the catalog for round #3 of hunting for a lower hose, but it WILL clear the frame so that is good news.
Lastly, started laying out the engine harness in prep for doing the wiring - decided I'm not happy with the routing, so I'm going to be re-looming a portion of that and shortening some stuff up, to do a partial wiring tuck so it will all be hidden under the center cover I haven't made yet. Going to relocate PCM/TCM to the firewall and bring the harness off the motor at the rear for neater appearance.
Wow. Words!
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
Old 08-11-2015, 08:42 PM   #2
Advanced Design
Advanced Design's Avatar
Good progress JJ. Getting a lot done!
Advanced Design is offline   Reply With Quote
Old 08-12-2015, 12:35 AM   #3
JJorgensen52
A lot of effort for sure Thanks!
Didn't get a whole lot done tonight -if there's one tool I really rely on for this stuff it's my angle grinder, and I wore the thing plum out! Just brushes, I ordered some replacements and jury rigged it for now, but that put a dent in my shop time.
I'm working on the H-pipe right now, have to cope the second end and then I'll move on to test fits. Thinking maybe that's enough exhaust ???
Also, for anybody interested, I'm using this tool:
http://www.metalgeek.com/static/cope.pcgi
Turns out to be pretty handy for making tubes fit together.
CURRENT
SOLD
Old 08-12-2015, 08:48 AM   #4
Advanced Design
Thanks for the link...http://www.metalgeek.com/static/cope.pcgi
Saved in favorites. Pretty handy!
Old 08-12-2015, 10:51 PM   #5
lower50's
lower50's's Avatar
I second that with the angle grinder.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 08-13-2015, 01:02 AM   #6
JJorgensen52
It's a love hate relationship for me, I'm not a huge fan of using it and it loves to try and kill me
Got the h-pipe in tonight
I also mounted my front two hangers to the frame (no mounts on the exhaust yet) and I've planned exactly my moves as far as the mufflers right ahead of the rear axle - after that, it's all still a bit wishy-washy but I've got an idea what should work. Stay tuned to see what kind of zany plumbing I come up with
Wednesday is usually a short shop day for me, goings on at church in the evening. Tomorrow isn't looking good either, late afternoon meetings at work. I'm really hoping to hear this thing run soon!
CURRENT
SOLD
Old 08-14-2015, 12:59 AM   #7
JJorgensen52
More progress. Snapped this one while I was welding the V-bands on the muffler side elbows (a LOT easier out of the truck, but I must've pulled this thing a dozen times today )
Also added the requisite O2 sensor bungs
One of the things I'm working on as I design and build parts for this truck is ease of service - I've worked on or around too many customized vehicles where you just can't get to anything, and I want no part in it. So every stage of this involves thinking and fiddling and trials to make sure those little things (like the O2 sensors) are easy to access, you can get a wrench on them. The devil's in the details!
A little detail here - these particular pieces are the tailpipe hangers from '98+ S10 pickups - they've got a bend to them, and they only come in one direction, so I have one mounted on top and one underneath to get the angles right.
And with the front section installed:
That 3/8" stainless hanger rod is TOUGH to bend, but it's plenty strong so I'm not too worried about the length of the horizontal run on the hangers. They're preloaded just a tad, to take a little stress off the manifolds.
This shows the run of the leg where it climbs over the trailing arms:
With the V-bands in place there, I have about 1" clearance to the trailing arm at the bump stop.
Last shot, I've got the mufflers mocked up:
I need to extend my 45 degree bends about 3" to get the bend in the right place, then I'll drop over the axle with a 90 and another 90 out underneath and up towards the fender - I'm going to drop the tips out at the back of the fender at probably 30 degrees downward and 45 degrees out.
Hopefully these pictures of the process are helpful to somebody down the road. I know I spent hours combing through build threads looking for ideas.
On a different note - how close can I get to the bed floor, and do I need heat shields over my mufflers?? I'm thinking yes on muffler shields, but the bend at the axle wants to be within about 1" of the bed floor and I'm not so sure I like that plan...
CURRENT
SOLD
Old 08-15-2015, 02:17 AM   #8
JJorgensen52
Finally found a lower radiator hose that fits
And I got my mufflers welded up with hangers:
I'm cutting the 45 elbows down and putting a V-band right ahead of the axle so I can still get them in and out easily. May have to do some funny business with the angles to get it all to fit and clear ... we'll see
Another S10 hanger - this one hangs the muffler on Blazers
CURRENT
SOLD
Old 08-15-2015, 07:50 PM   #9
Advanced Design
Exhaust looks good JJ. Nice work! You are killing it on progress. How many hours a week are you able to put in on the truck?
Old 08-16-2015, 01:36 PM   #10
JJorgensen52
Thanks! Right now, I'm probably managing 30 - 35 hours a week. Work is generally a bit slower for me in the summertime.
I was thinking the other day about how many total hours I have in this (and how much it would cost to have had it built ), and I decided I wasn't interested in trying to figure it out
CURRENT
SOLD
Old 08-17-2015, 01:15 AM   #11
JJorgensen52
I've been a little distracted this weekend... more on that in a minute.
Built the passenger's side tailpipe
I had to slice the tubing all which ways to get the clearance I wanted ... I wish I had a mandrel bender
You may note there's not a hanger yet - it's going to be the same hanger as an S10 Blazer tailpipe, just haven't drilled the mounting holes yet. That makes three hangers per side.
I'm going to slash cut the tip about 1" below the fender line, but I want it to be parallel to the ground so I'm not sure where that is yet, so not yet.
So who recognizes this one?
I picked this little bugger up for a song with no engine or trans but a nice clean body and all the important pieces that go with it - it's going to get an LS1/T56 swap in the future - but I had it at a friend's house and it was sitting in a field, so I wanted to retrieve it and get it home now that I have some space.
CURRENT
SOLD
Old 08-17-2015, 08:58 PM   #12
lower50's
lower50's's Avatar
Great job on the exhaust, should sound sweet. I'm doing the same accessible thing for the maintenance on my truck. As for the clearance for the mufflers and pipe 1" to the bed should be lots, I have 1/2"- 3/4" clearance from the mufflers to the fiberglass tub on my jeep 2' from the motor for many years no prob. If that helps.
1951 MG TD
Old 08-17-2015, 09:11 PM   #13
Advanced Design
Typhoon?
Old 08-17-2015, 09:25 PM   #14
oldman3
oldman3's Avatar
Typhoon?
Doug, I think you mean Syclone (spelling?) for pickups. Typhoon was the Blazer type. Drove both of them when I was with Chevy, at the time they were fast...Jim
oldman3 is offline   Reply With Quote
Old 08-17-2015, 09:35 PM   #15
Advanced Design
Jim, yes I think that is right. I was Buick back then and we didn't get to spend time with the trucks. I had the Typhoon and Syclone reversed in my memory. They were 4.3 turbo's weren't they? Been a long time for me.
So JJ, another project?
Old 08-17-2015, 09:45 PM   #16
iowaboynca
iowaboynca's Avatar
Oh...giddyup of a Grand National in a truck. I wanted one as a kid and the rumor was could never get it insured. Forget the fact i couldn't afford one in the first place.
What cracked me up were the guys that put 200lbs of stereo equipment in the Typhoons and think they were bad a...you get the idea. (where's my Def Lepard "Hysteria" cassette???)
Nice haul, looks like your toy box is growing
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 08-17-2015, 10:54 PM   #17
JJorgensen52
Jim and Doug, you're in the right church but the wrong pew And yes, Syclone and Typhoon were both 4.3 turbos with AWD.
This one's a Sonoma GT ... the rarest of the three, shares a lot of cosmetic parts with the Syclone and Typhoon. It's the rarest of the S10 special editions with one year production of 806. 2WD with the CPI 4.3 V6. Basically a ZQ8 before there was a ZQ8.
I've played this game before, my Dad bought a Typhoon new which I frame off restored with him in highschool, I owned it for some years and had a lot of trouble with it and sold it to buy my Wildcat. I also had a Sonoma GT at that time with a 5 speed swap - it was a great little daily and a hoot to drive, I regretted selling it so when I saw this one I snapped it up. It's going to be a low buck LS swap build - I'm collecting junkyard bits for bigger brakes and such, and once the Red Herring is done I'll start looking for a motor and trans.
Here's a few shots of the last one I had:
I had to do sway bar links and control arm bushings on the daily today, but I'm just getting wrapped up putting a rear hanger on Red, so back to your regularly scheduled thread here shortly
CURRENT
SOLD
Old 08-18-2015, 07:36 AM   #18
Advanced Design
Won't hurt to flush put. I've seen catalytic converters come apart and the debris end up in the engine.
Old 08-31-2015, 12:00 AM   #19
JJorgensen52
Got the driver's side tailpipe made, not happy with the angle so probably will remake it later.
Mounted some of my switchgear - Wipers, lock, unlock, hazards.
ECM/TCM mounted using the GM bracket for the 2011 truck ($6 part at the dealer) and beginning the mess of tucking the engine harness
CURRENT
SOLD
Old 08-31-2015, 10:40 AM   #20
Advanced Design
Nice progress. The $6 bracket was a great idea.
Old 09-02-2015, 12:22 AM   #21
JJorgensen52
Thanks! I tried about a dozen ideas and then thought to look at how the factory did it - it's really compact, hard to beat it.
I'm still in the shortening phase of the harness, I've probably taken 30 feet of wire out already!! Starting to look neater, though.
CURRENT
SOLD
Old 09-02-2015, 01:47 PM   #22
Advanced Design
Much neater. Looking like a factory application. The trans dip stick looks like it worked out well too. Nice!
Old 09-03-2015, 03:05 PM   #23
JJorgensen52
I did have to tweak it a bit, but it's almost like GM made these parts to fit in here
CURRENT
SOLD
Old 10-05-2015, 11:49 AM   #24
JJorgensen52
Holy cow! It's been a whole month since I posted anything on this truck It's been a busy few weeks at work, and I've shifted focus onto a couple other projects for a little change of pace.
I'm still picking away at it here and there - I ran into some more parts I needed in the electrical side of things, I have some parts on order. I've also been slowly working away at the fuel system, which is proving to be more of a nuisance than I had hoped.
CURRENT
SOLD
Old 10-05-2015, 01:48 PM   #25
Chevy-49
Chevy-49's Avatar
Yes time flies, same over here.
Looking for parts means you are still working on the truck...
My build thread: 1949 AD truck 'Chevy-49'
Chevy-49 is offline   Reply With Quote
