#301 | |
Re: 57 GMC, frame swap, 4wd, 454 big block, 4 speed
My 57 GMC build |
#302 |
![]() Join Date: Jul 2009
Love the look of your truck. My original plan for my '59 was to make it 4x4. Then I built a different 4x4 and decided I'd do something else with the '59 (haven't started yet). Your truck has me thinking I may have to go back to the original plan!
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ![]() 2001 GMC Sierra K2500 |
#303 |
Thanks! I say go 4x4 on your 59!
My 57 GMC build |
#304 | |
I used to do egonomics as part of being a design engineer. 12-13" is about max for comfortable safe step. Hoop or bar type steps seem to pose a leg breaking hazard or two. With all the trash and debris on roads around here higher and 4x4 are a must. Last two low vehicles had major damage from hitting road trash. One took a hit from a 1' square piece of 3/8" plywood that got sucked up and took out fuel line and tank. The other hit a vise that fell off a utility truck --left a trail of diesel 2' wide for miles!! |
#305 |
Yes, and add 1 or 2 inches to the actual step, so its really up there. I've had other rigs that were higher, so its workable, but I'll make something before long. I still have a lot of things to finish on it.
My 57 GMC build |
#306 | |
I haven't checked my step in height yet, but I'd guess it's in the 20" range as well, not that I had a really tall truck in mind to begin with, but due to the frame layout on the Dodge chassis I used, I ended up there anyway. Keep up the great work! -Joe Edit- I just checked where mine is sitting. My door sills are at my knee caps, 21.5” off the ground. I can see where 26” would be. Steps are definitely a must.
My '57 "Ram-rolet" not a NAPCO build: http://67-72chevytrucks.com/vboard/s...d.php?t=589917 Last edited by Purcell69; 11-01-2018 at 05:52 PM. |
#307 |
I ruined my 87 GMC Van Column by using it as a grab handle to get in before i added the power steps. (Us old farts have shrinking inseams)
#308 | |
![]() Join Date: May 2007
![]() looking great, shes a big girl but very trim!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#309 | |
My 57 GMC build |
#310 |
Yes, that is a quick way to ruin a column!
My 57 GMC build |
#311 |
Haha! Yes, shes tall, but skinny! I didn't want fat tires sticking out with wide wheels. I used stock K20 6 1/2" steel wheels and hubcaps. I almost got bias ply tires that were even narrower and taller, but I wanted a good tire to drive on. These are 255/85-16, which measures 33".
My 57 GMC build |
#312 |
I picked up my new windshield at Bowtie bits. I wanted a clear one, but that was special order with a month wait and twice the cost, so I got one with a tinted strip across the top. I guess it'll look ok, and better than the stock cracked one that I took out at the first of the build. I have a glass guy coming by Tuesday morning to install the windshield and back glass. I've always done my own windshield and glass installs, but for some reason I just thought I need to let a pro do this one. He is good with the hot rod / street rod stuff, so he was my choice for this. I even installed my own glass in a 59 El Camino I had years ago, by myself, but maybe it's the height of the truck that is causing me to not be comfortable with doing it, I don't know. Anyway, hopefully Tuesday morning I'll have glass in it. Well, not the door glass yet. I need to take my door windows and wing windows to the glass shop to have new ones installed in the frames. After that, I should be ready to assemble the door windows with new seals and hardware. I have everything new for all that. It's nice having Bowtie Bits here in town. I have bought a ton of parts from him, and I think everything that I've bought was in stock except for the windshield and one patch panel back when I was fixing the cab rust.
My 57 GMC build |
#313 |
I had to stick the rear fenders on with a few bolts to check it out. I'd say all of my measuring, figuring, frame shortening, etc. worked out perfect. The rear wheels fit just right in the fender openings. I'm about to get the fuel filler cap installed in the driver side rear fender so I can finish making my filler neck and vent.
My 57 GMC build |
#314 |
Post Whore
![]() ![]() Join Date: May 2015
Haha....I did the same thing with my rear fender....couldn't stand not seeing how it would look
Are you installing the glass before paint?...
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 11-04-2018 at 10:11 AM. |
#315 | |
-Joe
My '57 "Ram-rolet" not a NAPCO build: http://67-72chevytrucks.com/vboard/s...d.php?t=589917 |
#316 |
The interior and window jambs are painted. I'm installing the glass Tuesday morning. I'm going to finish the truck in everything except paint and drive it a while. When I can get it painted, I'll take it back apart for the paint job.
My 57 GMC build |
#317 |
Thanks, it's good to see it looking like something besides piles of parts. Hopefully you can get a little more done on yours before the weather turns cold.
My 57 GMC build |
#318 |
Big blocks get thirsty, so I needed to have a way to give it a drink... I mounted an aluminum flip up fuel cap in the driver side rear fender, and made a filler neck out of small exhaust tubing to connect the cap and the filler neck on the tank under the bed. The vent line is 11/16" braided fuel hose from a local hot rod supply shop.
I also had plenty of "guard doggin" while I worked in the shop...
My 57 GMC build |
#319 |
I think having the filler up high will help. Mine is too low and tends to "burp"
#320 |
Yes, at first I thought about putting the filler in the back of the fender, but decided to do it in the rear top. It should fill with fuel good, and has a good size vent. I poured in about 7 gallons out of a large can pretty fast with no burping back.
My 57 GMC build |
#321 |
Mine is about 4 " lower than yours. It will take gas as fast as you can pump it but "burps" right when the filler cuts off. Hard to gauge when its nearly full and here in OR we mostly have attendants so fill ups are always interesting.
#322 |
The glass guy came by this morning. He had the front windshield and back glass installed in about 30 minutes. The windshield fit pretty nice. I was hoping there wouldn't be any issues because of it being aftermarket. I talked to the glass guy about my door and wing windows. He's going to cut new glass and install them in the frames for me, so I'll get them to him soon. I also hooked up the new front park/signal lights and tested them out. I have the headlight buckets blasted and ready for a coat of paint, so I'll get the headlights installed the next chance I get. I took some measurements today for a rear bumper. I'm trying to decide if I want to make a custom bumper, or use a stock one. I don't want to make something that doesn't go with the look of the truck, but I also have wiring ran for back-up lights, so I may make one to work with those. Still deciding...
My 57 GMC build |
#323 |
Post Whore
DANG!!! That looks killer!!
#324 |
It's coming together real nice Gabe
#325 |
Thanks guys, I'm really happy with the look and the stance. It should turn out to be a pretty good truck. It'll be a while before I can get it painted, but otherwise it is turning out just how I wanted it.
My 57 GMC build |
