Old 12-31-2017, 12:44 AM   #301
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: "Elwood" the 77_remix
Originally Posted by gringoloco View Post
Much mo betta! What are you using to protect the lines where they pass through the framerails?
I slide a piece of fuel hose over the air line on individual lines. Where those are clustered together I have a rubber boot.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-31-2017, 12:08 PM   #302
N2TRUX
Happy to be here
N2TRUX's Avatar
Wiring, wiring, and more wiring. Yesterday Chris came over and we sorted out the wiring. I had planed to wait till I got in the cab to pull the Ride Pro E3 system. Unfortunately it was in my way and we decided it was time for it to go.
Articles-
"Refining Sierra"
Old 12-31-2017, 12:22 PM   #303
N2TRUX
Happy to be here
N2TRUX's Avatar
With the E3 system clear we looked at where to mount the Ride Pro X processor. It will go inside a custom enclosure under the seat. Till we get inside the cab that will have to wait.
For now we ran the compressor turn on wires and pressure sensor line to the rear. That was combined with two power wires and tail light wiring in one loom.
Articles-
"Refining Sierra"
Old 12-31-2017, 12:30 PM   #304
N2TRUX
Happy to be here
N2TRUX's Avatar
Chris and I analized how to terminate all the wires necessary to run the Viaair compressors. I hated having a big cluster of connectors, so we opted for a terminal strip.
I ran to the local electronics warehouse and grabbed a 4 junction 60 amp strip. I had hoped to get one that was weather proof, but they didn't have any.
Articles-
"Refining Sierra"
Old 12-31-2017, 12:36 PM   #305
N2TRUX
Happy to be here
N2TRUX's Avatar
Since there wasn't a weather proof option, I made a cover myself. It's not weather tight, but it covers the exposed connections.
Each wire was precisely measure for fit, then terminals were swedged on and covered with marine grade shrink tube.
I had to modify the pressure sensor line so it was soldered and protected with weather proof shrink tube as well.
Articles-
"Refining Sierra"
Old 12-31-2017, 12:40 PM   #306
N2TRUX
Happy to be here
N2TRUX's Avatar
With the wiring in place I topped the strip off with a protective cover. I will take it all apart to paint again. When I do final install all the long bolts will be cut short and braided wire loom added.
Articles-
"Refining Sierra"
Old 01-04-2018, 01:03 PM   #307
N2TRUX
Happy to be here
N2TRUX's Avatar
Now that the wiring is wrapped up I can do the final assembly. I decided the air tanks needed to contrast a bit so I brushed the raw aluminum with 150 grit followed by a green Scotch Brite. I had planned to use satin clear but ran short so I was forced to use gloss instead. Not my first choice but I needed to move forward.
Articles-
"Refining Sierra"
Old 01-04-2018, 01:12 PM   #308
N2TRUX
Happy to be here
N2TRUX's Avatar
I had previously installed all of the fittings and cinched them down. I mounted the tanks in place one last time and adjusted the fitting to the proper orientation to route the air lines. The lines were trimmed to length and pushed in place. I will check for leaks once the system is active.
Articles-
"Refining Sierra"
Old 01-05-2018, 07:43 PM   #309
N2TRUX
Happy to be here
N2TRUX's Avatar
I had previously downloaded the Ride Pro X app on my Android phone. Its also available for you iPhone guys. Its becomes obvious that RideTech paid big money to have this app programmed. It has a very animated control screen with highly visible graphics.
I discovered that you must calibrate your system before some features are functional. Once I realized that your phone becomes married to the system after the calibration, the ease of operation was very simple.
Articles-
"Refining Sierra"
Old 01-05-2018, 08:06 PM   #310
N2TRUX
Happy to be here
N2TRUX's Avatar
AwwWe needed to get the X management system up and running quickly. With out it I would have to rig an input line to air the system up so I could move the truck. Chris and I removed the Ride Pro E3 system and set it aside. We laid out the X components and mapped out a plan.
I will mount the electronics inside a custom enclosure under the seat. RideTech includes a cool bluetooth control that plugs in the cigarette lighter. Instead, I plan to install a 7" tablet to control and demo this app, along with others I will be using. Until then I connected the necessary wires and fired the system up. Its not pretty, but it is functional.
Once we get inside the cab and I'm able to route the wiring properly I will give more details on the RidePro X. Until then take a look here. RidePro X
Articles-
"Refining Sierra"
Old 01-07-2018, 11:50 AM   #311
N2TRUX
Happy to be here
N2TRUX's Avatar
With no fuel in the system yet, I cant start the truck. Consequently, trying to run two ViAir 444c compressors off of a dead battery and charger was a lesson in frustration.
The Ridepro X system runs to compressors to 150 psi before shutting off. To calibrate it goes through 200+ small steps that use air and drain the tanks. This process should be done with the truck running, or on a high output charger, and mine was neither.
I finally had an epiphany and turned one compressor off. With a fully charged battery I was able to complete the calibration process. With that done I could set the 3 presets and finally take control the system.
Articles-
"Refining Sierra"
Old 01-07-2018, 02:54 PM   #312
smbrouss70
smbrouss70's Avatar
I'm at the same stage with mine. Another idea I had was to screw-in in a fitting for an air tool into an unused port on my tank and let the shop compressor do all the work.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 01-07-2018, 03:38 PM   #313
N2TRUX
Happy to be here
N2TRUX's Avatar
I considered that option. I even bought a 3/8" T fitting to use. I decided it was to my advantage to get the system operational instead. That clock is running away and I'm chasing it.
Articles-
"Refining Sierra"
Old 01-08-2018, 02:49 AM   #314
nuke1
nuke1's Avatar
Truck is looking great Bud!!!!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 01-08-2018, 11:21 AM   #315
N2TRUX
Happy to be here
N2TRUX's Avatar
Thank you. Its slowly coming together.
Articles-
"Refining Sierra"
Old 01-08-2018, 11:26 AM   #316
N2TRUX
Happy to be here
N2TRUX's Avatar
It was a productive weekend at the @n2trux shop. I took a break Friday night for some quality time with my family. My wife and I took my daughter and son-in-law to dinner and had some much needed time together.
Saturday morning I helped a neighbor with a busted water pipe, then settled down in my shop. It was time to get the front suspension updated. I had some quality parts from RideTech and Wilwood that would give Elwood better handling and stopping ability.
Articles-
"Refining Sierra"
Old 01-08-2018, 11:38 AM   #317
N2TRUX
Happy to be here
N2TRUX's Avatar
With the truck secure on jack stands, I let the air out of the bags and got busy. The complete 12" stock disc and 3" spindle assembly was going away to be replaced with Wilwood components. I opted for 13" rotors with 6 piston calipers. These are mounted on modular spindles from Wilwood as well. This should make a huge improvement in my stopping power.
Articles-
"Refining Sierra"
Old 01-08-2018, 11:49 AM   #318
N2TRUX
Happy to be here
N2TRUX's Avatar
The current suspension was changed several years ago when RideTech developed the latest in air suspension. It included Strong arms tubular A arms, a Muscle Bar, sway bar and upper shock mount to add additional length for the HQ series shock.
Articles-
"Refining Sierra"
Old 01-08-2018, 03:20 PM   #319
rustytruck50
rustytruck50's Avatar
Looks great Ken! How much is changing on the front suspension or are you doing detail work?
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 01-08-2018, 07:31 PM   #320
N2TRUX
Happy to be here
N2TRUX's Avatar
The core of the system will remain unchanged. The shocks and mounts are new, along with the sway bar and it's mounts.
Articles-
"Refining Sierra"
Old 01-08-2018, 09:26 PM   #321
moregrip
moregrip's Avatar
not many things better than a nice clean wiring setup!
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 01-09-2018, 11:53 AM   #322
N2TRUX
Happy to be here
N2TRUX's Avatar
I'm an Electronic Technician by trade, and I'm OCD as well. I cant help myself when it comes to details. especially wiring.
Articles-
"Refining Sierra"
Old 01-09-2018, 11:57 AM   #323
N2TRUX
Happy to be here
N2TRUX's Avatar
I removed all of the RideTech suspension except the lower Strong Arms. I was able to strip them clean and prep for paint with them in place. The rest of the components were removed and prepped or replaced.
Articles-
"Refining Sierra"
Old 01-09-2018, 12:08 PM   #324
N2TRUX
Happy to be here
N2TRUX's Avatar
While I was waiting for the painted parts to dry I kept busy building new tie rods. Mine were in good shape, but I had purchased new ones several years ago along with some cool billet adjusters from RideTech. I guess these are considered vintage now since they have the old Air Ride Technologies log on them.
Articles-
"Refining Sierra"
Old 01-09-2018, 12:17 PM   #325
N2TRUX
Happy to be here
N2TRUX's Avatar
With the paint cured, I bolted the new upper shock mounts in place. If your not running these mounts on your lowered or bagged truck, you should be. There is no way a shorter shock has the same damping ability as a longer shock. By adding additional length you gain fluid capacity and travel.
The RideTech HQ shocks are adjustable so you can dial in your rebound and firmness preference. They have 24 positions to choose from. RideTech suggests starting in the middle and tune to your driving style.
Articles-
"Refining Sierra"
