#301 | |
![]() Join Date: Sep 2006
Re: Dumptruck Dolly
Regarding the transfer case, it’s a 1968 and I believe it’s the 205. |
#302 |
Re: Dumptruck Dolly
Removing rivets of the sway bar bracket as well as the ones where the front leaf shackle will attach.
#303 |
Re: Dumptruck Dolly
Original front shackle mount doesn’t look good...remember, the Blue Ox parts truck was hit in front.
#304 |
Re: Dumptruck Dolly
Adding insult to injury...Ouch!
#305 |
Re: Dumptruck Dolly
Art/Fabrication 101...tracing it out...going to build new mount brackets.
#306 |
Re: Dumptruck Dolly
Fired up the Plasma Cutter.
#307 |
Re: Dumptruck Dolly
Got a lot done...Vikings weren’t very distracting today. Added the gusset and welded it up.
#308 |
Re: Dumptruck Dolly
A little paint and done...when I bolt them up to the frame I’ll drill out the other holes. Done for tonight.
#309 |
Re: Dumptruck Dolly
A pretty busy week...I had a tough time finding the time to finish up the front leaf spring mounts, but here they are.
#310 |
![]() Join Date: Apr 2008
Re: Dumptruck Dolly
Brackets look good! Did you drill up through the brackets and frame for bolts on the tab that goes under the frame?
71 C10 72 K20 72 K10 Super Kirk |
#311 |
Re: Dumptruck Dolly
#312 |
Re: Dumptruck Dolly
I am trying to plan the next step.
...I have to remove the lower bracket of the transmission crossmember (red arrow)—this will make room for the rear shackle mount. I’ll think about a different type of lower support to replace the original, because I think the trans crossmember will remain in the same place when I drop a Small Block V8 in to replace the Inline 6, while using a similar 4 speed trans. ...I will be cutting out a section of the frame to remove the curved out emergency brake frame attachment (red square) which is in the way of the mount. The replacement steel will come from the 3/4 ton “Blue Ox” frame, which will have the factory hole (and flat steel) that the grade 8 bolt will pass through, holding the shackle. I’ll take better pictures the next chance I get. ...I think this will do it. Last edited by fishnixon; 10-07-2019 at 01:58 AM. |
#313 |
Re: Dumptruck Dolly
Went out to look at the carcass of the Blue Ox...yup, upon closer inspection, the drivers side frame horn is pushed over. I am trying to justify my next move.
#314 |
Re: Dumptruck Dolly
Yup, I’m going to do it.
#315 |
Re: Dumptruck Dolly
A messy crime scene...heh, the WD40 kinda looks like blood.
#316 |
Re: Dumptruck Dolly
Measurements, thinking, measurements...eh, I’ll sleep on it. Getting late, and am hoping the Twins can win tonight.
#317 |
![]() Join Date: Dec 2009
Re: Dumptruck Dolly
Great progress.
Good call / Don't measure tired. Measure. Then wait till tomorrow and see if it still makes any sence ![]() .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#318 | |
Re: Dumptruck Dolly
I hope to use the cardboard template to its fullest potential. The cab mount edge that is labeled, is key for me. Also, I am thinking about how small a rectangle I can cut out, and cover the necessary area...all without compromising Dolly’s frame. At least there’s not a heavy motor hanging in front of the work area...I think I’ll be OK. |
#319 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: Dumptruck Dolly
You're progress is looking good. Keep at it
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#320 |
Re: Dumptruck Dolly
#321 |
Re: Dumptruck Dolly
Let me know what you think...
Trying to keep the cutting to a minimum, I came up with this for the cut pattern. I like that I keep Dolly’s top and bottom frame rails, and that I use the the donors original mounting points, and that there are angles. Hopefully the size of this will cover the two dimpled spots on Dolly’s frame. All of this being in my head, I guess I’ll find out when I get a chance to get out to the garage. I see another cardboard template in my future. |
#322 |
Re: Dumptruck Dolly
Ok, here I go.
#323 |
Re: Dumptruck Dolly
I cut out the area where the “bumps” were, so I could work on a relatively flat surface.
#324 |
Re: Dumptruck Dolly
Using the template, I mark the top line and then match up the same line on the steel.
#325 |
Re: Dumptruck Dolly
Looking good.
![]() That is a Great plan you have in place. I am taking notes ![]() Just my input. Tack and fit inside of the frame rail 1st. Cause the outside will be easier to grind shape and re-weld. .
