#301 | |
![]() Join Date: Dec 1999
Re: Restomod 72 K10 "Good Memories"
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
#302 |
Picked up the seat today. I am almost never fully satisfied with results of work I farm out, regardless of the cost. Very happy with the results. Feels nice but I sit a bit higher than wanted now, I fully expected this with the foam work. Will shorten the seat mount brackets about 1"-1.5" My modified inner bracket for the 60 side needs an additional 1" chop. I sat them in the truck to see how they look. What do you think?
#303 |
All about them K’s
![]() Join Date: Jun 2014
Man Richard, those seats are incredible! I’m pretty jealous!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
#304 |
![]() Join Date: Jan 2008
Seats turned out good. I definitely understand the not being satisfied with farmed out work.
#305 |
![]() Join Date: Apr 2008
Look like they belong!
71 C10 72 K20 72 K10 Super Kirk |
#306 | ||
Thanks! Objective I am trying to accomplish with many of the modifications. As I need to modify all four seat brackets now. I am reconsidering a custom frame that bolts to stock mounting points. Going to look at seat risers again and make a decision on which way to go.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 07-08-2024 at 01:37 AM. |
#307 |
You outdid yourself on these
#308 |
Thanks, they are starting to grow on me
Steve Budy and his daughter did all the hard work. I provided the seat, material and he worked with me to achieve my vision. Maybe a slight variation of the original vision. I wanted a somewhat unique seat for the project that was comfortable, provided a bit more room and as said "looks like it belongs" I am very satisfied with the results.
#309 |
I don't think so. Sounds like you're in my boat. I have found very few people in my life who strive for the quality, attention to detail I can see.
#310 |
Built a frame for the seats a couple weeks ago. Pushed through the heat and fabricated the mounts today. Want to add some gussets to the feet for more strength. Maybe get to that and cutting seat risers down this weekend.
#311 |
Have been working on the seats when I can. The three most difficult risers are modified. Inner on the 60 side need chopped still. I took over 4" out of the risers to get the drop I wanted. Had to order hardware online to complete the install. No one here in California seems to have more than a couple of bolts in stock. Pretty sure I know who to thank for this ridiculousness.
#312 |
Wow! over 100,000 views now. Thanks to all for the interest in my project. It has been really hot here, 114 degrees +. Would love to see some more comments. To hot for me to get any work done. My work place is at least 10 degrees lower and is somewhat tolerable. Supposed to be cooling down by end of week and may get on finishing the seats.
#313 |
What steel is it that you used? I need to make a seat riser for my seats out of a Mercedes R350.
#314 |
Just used a mild steel 1" square tube I picked up at Ace Hardware. Did not see a need to go way overkill. Only needs to support 3 people and the seats. Seat belts are are floor mounted in the truck. If I was installing seats with integrated belts a thicker wall tube would have been ordered and used. Should finish up all mounts tomorrow.
#315 | |
My rear seat brackets are way overkill at 3/8 inch thick. Those are integrated belt seats from the third row of a cadi/suburban. I will likely go with 1/4 inch for the front brackets. |
#316 |
Should have mentioned I used 1/4" steel for the feet. The gussets and box plates on the mounts are 3/16". Fully finished finished the seat mounting today, last riser and feet of frame boxed in. It is ready to bolt into truck as the original bench went in. Will most likely do a beauty cover for the sides now.
#317 |
Working on wiring when I can. Still to much work time at the shop. I installed the headliner and trim. Think it looks nice. Was going back and forth on whether or not to use it. No holes were drilled in cab to install so I can remove later if I choose.
Threw the dash pad on just to see how it fits. It is an OEM type replacement I purchased in 03 from Dashes Direct. I know a parchment dash pad was never offered by GM, but that is what I wanted. Took my door panels to the shop, cleaned, prepped and painted them. Used the SEM "super white" that was recommended. They are more white than the parchment. Do not know of any other choices at this time.
#318 |
![]() Join Date: Oct 2014
Hey Richard, I just read thru your entire build. Impressive work you have done on the truck. And that seat, wow, that is nice!
Can’t wait for more updates.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
#319 |
Thank you for the kind remarks. I have been working on the truck but nothing really to see. I did find a parchment paint for the door panels that has an acceptable match to the other interior pieces I used. Panels and arm rests are in the new color. Mentioned in a couple of other threads, OER PP807 Parchment. I purchased from Summit Racing. Don't cheap out or forget the adhesion promoter when painting the plastic pieces.
#320 | |
#321 |
All about them K’s
Awesome progress Richard, hope you are having a blessed and prosperous new year!
#322 | |
I would wager that you have much more experience than I when recoloring plastics.
#323 |
Thanks Tyler.
#324 |
Goodness, that’s a bit pricey. Use the SEM Sand Free Adhesive Promoter, it’s a bit cheaper. I get it off Amazon
#325 |
Have not updated in a while. Have been working on wiring lately as lucky for me I am not needed at the body shop. A couple of pics of installed components and wiring. Not real exciting but a lot of work. Had to move the ECU over to right side as cluster would not go in. Even with the 90 degree adapter on speedo cable clearance was 1/4" to short. Rebuilt the mounting bracket and it allowed a few components room on the left. Paddle shifter wired, as well as tach/speedo module, ecu and cruise control. There is room for more things.
Wiring still a bit messy, but there is more to do before final cleanup.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 03-07-2025 at 04:15 AM. |
| Bookmarks |
