09-14-2024, 10:52 AM | #301 | |
Re: Eliminate draft tube options
Thanks for noticing.
1953 Chevy 3100 - 5 window 1/2 ton pickup My 1953 Chevy Work-In-Process Photo Gallery "I don't have a carbon footprint, I drive everywhere." |
09-15-2024, 07:05 PM | #302 |
For those of you that love photos. Here is a photo of the underside and the ceramic coated headers and exhaust pipes. A close eye can spot the shelf with the linear actuator that I fabricated a mounting for to the replace the foot operated parking brake.
1953 Chevy 3100 - 5 window 1/2 ton pickup My 1953 Chevy Work-In-Process Photo Gallery "I don't have a carbon footprint, I drive everywhere." Last edited by TX3100Guy; 09-15-2024 at 11:20 PM. |
09-16-2024, 09:42 AM | #303 |
Do you have a picture or two of this bracket from other angles?
my son's 261 powered '46 2 dr will be getting MII front this fall. The suspension parts kits are cheaper than ordering individual parts but all the reasonably prices kits we find come with power rack. PS is a nice feature anyway. picture to fuel the internet |
09-16-2024, 10:36 AM | #304 | |
I'll take a few photos today for you. The bracket actually was purchased from VintageAir when I bought the system for the truck. It's designed specifically for the engine, however my setup has headers instead of the stock exhaust manifold, so it didn't fit properly. The alternator at its highest adjustment still wouldn't clear the headers. Fortunately, I have access to a CNC plasma torch (Dynatorch) so I first made a cardboard template to increase the swing arc of the alternator, then I drew it up on the Cad software and cut a test piece on 18 gauge steel, then finally on 1/4" plate steel. I then cut the old section out and welded in my new piece.
09-16-2024, 11:37 AM | #305 |
Sidetrack time!
Any of you looked into eps. Electric power steering. Should be lots of room under the dash for one. |
09-16-2024, 11:51 AM | #306 | |
I had already purchased an Ididit steering column and a company in Florida (EPAS Performance - https://epasperformance.com/ sells an Ididit column with an electric assist power steering unit already installed. I emailed the owner and he agreed to have me ship my column to him and he retrofitted my column with their electric unit. I was already familiar with the electric power assist units, since I had installed one from a European vendor for a 1969 Jaguar XKE that I had restored and knew that it transformed the car. I can't wait to drive the truck with this and power brakes, it should be enjoyable.
09-16-2024, 12:27 PM | #307 |
Good deal!
I sure wish I’d had that option 40-50 years ago. Woulda made a lot of my projects easier. |
09-16-2024, 02:10 PM | #308 |
My '52 has 60s vintage c10 suspension and steering. I grew up without power steering and assumed I'd never need it for the '52. Drove it last year armstrong, then swapped to a 80s suburban PS box and pump as I thought the lack of PS precluded my wife from being able to enjoy driving it.
Power steering made it a lot more enjoyable to drive for me too. Without power it was always just a bit slower than people expect you to be getting around in modern traffic and parking lots. And harder work! EPAS would be a tight fit under dash with firewall hung pedals, at least with my C10 based setup where clutch and brake hang on opposite sides of column. |
09-18-2024, 03:34 PM | #309 |
Almost ready to turn the key and see what happens. Just a few more wires to connect and all fluids to input (coolant, engine, transmission, and differential)
09-22-2024, 04:11 PM | #310 |
New photos of finished install and a link to a video of the very first crank of the newly rebuilt engine.
YouTube Video of Rebuilt Engine's first crank
09-22-2024, 04:22 PM | #311 |
sounds awesome! you must be pumped
09-22-2024, 11:13 PM | #312 |
You have no idea, after waiting for five months to get my engine back, I was amazed that it started on the first turn of the key!
I have a few niggling issues to deal with surrounding the electric fan, the electric e-brake, and an annoying drip/leak on the brake boost pump. I will work quickly to get them all resolved and then run the truck around the neighborhood without bolting the fender back on a few times, just to make sure I won't have to take them off again. More to come.....
10-09-2024, 07:53 PM | #313 |
I haven't posted anything since the video of the engine kicking over for the first time due to what happened the very next day. I went out to diagnose my thermostatically controlled electric fan not coming on during that first start-up, only to find that I could not get the engine started.
I mistakenly attempted to start the car without turning the electric fuel pump on, the engine ran for a few seconds, but then abruptly stopped. No amount of encouraging, troubleshooting, or swearing could get it started. After hours of trying everything I knew to do, I started testing for good ground to the engine and determined that both the body of my Vertex magneto was grounded (as it should be) but so was the grounding terminal, even when the grounding switch and grounding wire was disconnected. As a result, I had to pull the magneto and send it out to Joe Hunt Magnetos in California to have it diagnosed and repaired. I have my fingers crossed that this solves the start-up problem. I should have it back by the end of next week (I hope).
10-09-2024, 09:22 PM | #314 |
Look on the bright side, no towing bill was involved in diagnosing the faulty magneto.
Stay strong, your getting there! |
10-09-2024, 10:53 PM | #315 |
Today, I eliminated the "kill/ground switch" that I had wired in to ground out the magneto and instead used something that Joe Hunt Magneto sells, although I sourced the same component myself locally. I wired in a relay to my ignition circuit, when the ignition key is turned on the relay is open and stops grounding the magneto, as soon as the power is turned off, the relay closes and grounds the magneto, thus turning it off. This way, the key switch activates both the starter and the magneto, instead of it being a two step process.
Now I'm considering eliminating the switch I wired on the dash to shut off the fuel pump and instead replacing it with an inertial safety switch that I bought a few months back. The inertial switch is triggered in a accident and turns the fuel pump off. It has a larger red reset button, in case it accidentally activates. After accidentally attempting to start the engine without turning the fuel pump on, I have been re-thinking the logic of having a push/pull switch on the dash for a fuel pump shut-off.
1953 Chevy 3100 - 5 window 1/2 ton pickup My 1953 Chevy Work-In-Process Photo Gallery "I don't have a carbon footprint, I drive everywhere." Last edited by TX3100Guy; 10-09-2024 at 11:12 PM. |
10-09-2024, 11:50 PM | #316 |
Having to flick multiple switches to start is very cool, 'race car'. I'd preserve all the switches, but make it so when the key was off everything was off. So you could leave the individual switches on and turn the truck on or off with the key.
And by all means add the inertial switch as well. Or, perhaps better, a timed relay to provide fuel pump power for starting with a oil pressure driven switch that takes over once the motor starts |
10-17-2024, 09:18 PM | #317 |
Heard back from Joe Hunt Magnetos today. Apparently, they had to replace the condenser to get the magneto to work properly. The repaired mag is now in the hands of UPS on its way back to me. I'm more that a little bit anxious to get it back in the truck and fire up that engine again.
10-17-2024, 11:10 PM | #318 |
nice it was an easy fix. now the waiting game. maybe clean up your garage while you wait (joking of course. it's already spotless)
10-17-2024, 11:13 PM | #319 |
Yeah, the shop is generally clean, my OCD spouse has rubbed off on me. Although, I'm going to see a 1940 Chevy Business Coupe on Monday for a potential "next" project, to the dismay of my wife. It will require a bit of body work, so the shop floor won't always be clean if I decide to bite off that project.
10-19-2024, 09:53 AM | #320 |
that series is one of my favorite old coupe styles. post up pics for SURE.
10-19-2024, 11:00 AM | #321 | |
The front clip is off, there are multiple boxes of new parts - gauges, carb, wiring harness, body panels, wheels, tires, etc. He has partially installed a new shaved firewall and it needs the rear section of the lower body panel replaced. The interior is mostly removed. Now for the better news, it has a 1971 Chevy Camaro front frame with steering rack, engine mounts and a 350 c.i. V8, with a Trans Am rear diff. I'm good with all the mechanical and electrical work, but have some pause on the body work. The visit is to determine if the amount of work is in my wheelhouse. Also we have not discussed price yet either......
10-22-2024, 10:40 PM | #322 | |
10-22-2024, 11:08 PM | #323 |
too bad, it would be great to see the start to finish pics and the journey. i would love to find one of those, even in the shape you are saying this unit is in, as they are one of my faves. years ago a fella wanted to trade me my corvair powered rail buggy for his 37 chevy businessman's coupe, which was freshly painted by the owner who was a body man goint through trade school for autobody. my new wife said no. well, that hatchet was buried but the handle has been sticking out for many years. haha. I still remind her of that old coupe and it's been 40 years of married bliss this october.
10-22-2024, 11:17 PM | #324 | |
The real issue I have with the car is this. The bozo with the acetylene torch cut the frame clip off a 1971 Camaro and welded it to the frame of the 1940 Coupe. The welding that was done is downright ugly. Where the cab A-pillar should be resting on the frame, he booger welded a short section of square tubing to the frame to support the cab, with a hunk of wood in between. A friend who used to own a business restoring high end classic cars has suggested that given the cutting skill of the former owner, his measuring and welding skills are likely of the same caliper. This will result in never being able to get the front end aligned. I am still torn over walking away from this project.
1953 Chevy 3100 - 5 window 1/2 ton pickup My 1953 Chevy Work-In-Process Photo Gallery "I don't have a carbon footprint, I drive everywhere." Last edited by TX3100Guy; 10-22-2024 at 11:28 PM. |
10-23-2024, 11:56 AM | #325 |
there are quite a few builders using the S10 frame under their old coupes. maybe something like that could work.
it probably wouldn't matter what new project you take on, if it's old you likely will need some welding and panel work. lol. |
