Old 06-24-2011, 10:43 PM   #3226
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: Project Vitamin C-10
I'm also deciding on which brake fluid I should go with. I really don't want to use DOT3. I heard DOT5 is silicone based. It has several improved properties over DOT3. One being it won't eat the paint. What are your thoughts?
Alan's Classic is offline   Reply With Quote
Old 06-24-2011, 10:44 PM   #3227
Strodder
Daring to be Different
Strodder's Avatar
I've done a few drive shafts. Have the drive line guy tell you where to measure from. He should have yokes to sell you too. It's easy. Not worth your time to find a used yoke.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 06-24-2011, 10:46 PM   #3228
Strodder
Strodder's Avatar
Yes DOT 5. I'm going to throw out all my DOT 3
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 06-24-2011, 11:50 PM   #3229
Alan's Classic
Thanks Dennis
Did a search on how to measure a drive shaft and found this place that I think had a good sheet to use.
dennysdriveshaft.com
Old 06-25-2011, 12:02 AM   #3230
198plus
198plus's Avatar
Alan I've got a drive shaft complete that came out of my truck with 350 trans, that should be the right length...If you used your rear perch mount holes on engine. Let me know you can have it.
198plus is offline   Reply With Quote
Old 06-25-2011, 09:43 AM   #3231
Strodder
Strodder's Avatar
Thanks Allan.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 06-25-2011, 08:10 PM   #3232
TR65
TR65's Avatar
Hey Alan,
I run DOT 5 in my truck (and a lot of other vehicles in the past). Any fluid that will eat your paint when you spill a little bit is not for me. It is supposed to be a little more spongy than DOT 3. But it doesn't absorb water and has a higher boiling temp than DOT3. Expensive though.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 06-25-2011, 09:15 PM   #3233
Strodder
Strodder's Avatar
A little tip. Plain water will neutralise DOT 3. If you rinse it off right away.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 06-25-2011, 11:43 PM   #3234
Bugeyev8
Bugeyev8's Avatar
New catalyzed urethane paints are not supposed to be effected by brake fluid..but it still seems to...go figure that one out
I run the silicone in a car I built, you MUST remove all traces of dot 3 before using silicone, and it has been known to dissolve some seals ,I flushed the whole system with denatured alcohol 3 times before using the silicone, the silicone will give a harder pedal and it is harder to find and certain brands can't be mixed, I used the Napa brand and it works great and is cheaper than other brands
Oh and as far as the drive line, if you have a yoke push it in till it stops and pull it out 1/2 to 3/4" and measure from there to the rear flange, the drive shaft does not really move in and out too much, there are different types of yokes...long and short and car and truck
I just get a used drive line that is too long and get the drive line guy to shorten it put new u joints in and balance it, costs about 150$ out here in Ca, a whole new drive line will run 450$ out here
someone on here was able to use an aluminum one from a later truck in a short bed with no mods, I don't remember who at this moment but a search should turn that one up
Great progress on your truck...the work you have done looks awesome, keep it up !
Bugeyev8 is offline   Reply With Quote
Old 07-02-2011, 12:00 AM   #3235
Alan's Classic
Thanks Ronnie!!
Originally Posted by TR65 View Post
Hey Alan,
TR
Thanks Guys!!
Thanks, great info as well. My system is completely new so I don't have to worry about crossing fluids up.
No progress on mine lately. But I did make a patch for Shannon's truck tonight just to see if I can do it. It still needs some trimming it's just a roughed out patch. It's the piece that catches all the debris in the cowl area.
Old 07-02-2011, 10:20 AM   #3236
Strodder
Strodder's Avatar
That's kewl Allan.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 07-04-2011, 07:43 PM   #3237
shortbed70
shortbed70's Avatar
Nice patch!
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 07-09-2011, 08:18 PM   #3238
chad64chevy
chad64chevy's Avatar
alan what have you done to your truck lately? any updates????
chad64chevy is offline   Reply With Quote
Old 07-11-2011, 10:13 PM   #3239
Alan's Classic
That's kewl Allan.
Originally Posted by shortbed70 View Post
Nice patch!
Thanks guys.
Thanks for asking. I haven't done a darn thing in over two weeks. There are numerous reasons. The main one I can contribute it too is working in a shop with 100+ degree and 150% humidity all day I'm pretty much spent by the time I get home. I know I'm not the only one affected by the heat. I guess it's a good reason to be lazy.
Old 07-11-2011, 10:43 PM   #3240
Strodder
Strodder's Avatar
Thanks for asking. I haven't done a darn thing in over two weeks. There are numerous reasons. The main one I can contribute it too is working in a shop with 100+ degree and 150% humidity all day I'm pretty much spent by the time I get home. I know I'm not the only one affected by the heat. I guess it's a good reason to be lazy. [/QUOTE]
I don't blame you/ I can't work in the humidity. When it's 110 here with very low humidity I can work in my shop. Lots of fans, and this year I installed a swamp cooler. Works good when it's a dry heat.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 07-11-2011, 11:36 PM   #3241
shortbed70
shortbed70's Avatar
I've found my time is best used early in the morning when it's only 75 degrees out. This heat is no fun...Work in it all day welding then come home and work when it's 115 in the shop! No thanks.
Troy
Big Red Dog build
Old 07-12-2011, 06:27 PM   #3242
awbrown
It has been too hot !! That's my excuse.. and I am waiting on parts...
awbrown is offline   Reply With Quote
Old 07-12-2011, 08:48 PM   #3243
Strodder
Strodder's Avatar
It was only 84 here today with low humidity, and a slight breeze. Couldn't ask for any better weather.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 07-12-2011, 11:22 PM   #3244
Alan's Classic
How does that swamp cooler work with bare metal present?
Are you bragging?
Thought I would go out to the shop for a little bit to see where I ended. My cab to bed alignment is really confusing me. It's the same cab, bed and frame. The only thing that is different is new cab mounts. They also look to be installed correctly. I looked at a pic before teardown and it looked like it lined up a lot better. Nothing is tight right now, but everything is sitting on the frame. Thinking of shimming up the back of the cab. Both sides are the same.
Old 07-12-2011, 11:36 PM   #3245
shortbed70
shortbed70's Avatar
Smile Re: Project Vitamin C-10
Hey Alan we could swap beds because mine is on the lower side for some reason.
Troy
Big Red Dog build
Old 07-13-2011, 05:19 AM   #3246
Maybe the difference in the height of the bed is the bed wood?
Old 07-13-2011, 10:24 AM   #3247
Strodder
Strodder's Avatar
Are you bragging?
It works great because the shop is fully insulated. An extra $2,200.00, but really worth it. And yes I'm bragging
I have the same problem you have with lining up, but I yet to make cab and bed mounts.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 07-13-2011, 01:25 PM   #3248
aggie91
I'm just glad to be here!
aggie91's Avatar
Your cab/bed alignment looks off by a good 1/2" or more. Are you sure that the bed cross members are in the right locations? If you shim the cab won't that effect the core support/fender alignment too? I'm just guessing on the bed, from the pictures and what you did, I would think it should be off the other direction if any at all.
I know you will figure it out!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 07-13-2011, 01:42 PM   #3249
1966chevytrucks
1966chevytrucks's Avatar
Just a question Is the back of the bed sitting right it kinda looks like bed to cab gap is angled?
1966chevytrucks is offline   Reply With Quote
Old 07-13-2011, 04:14 PM   #3250
daverod
SSN 706
daverod's Avatar
Kinda what I was thinking too.
daverod is offline   Reply With Quote
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange
