Closed Thread
Old 03-13-2014, 09:55 PM   #3251
OrrieG
OrrieG's Avatar
Re: What Did You Do With Your Truck Today ?
Figured out the 4wd "in" lamp, the LED was wired in backwards. Attention to detail....All wiring tests out good. Next going to check fluids and fire it up this week end to see if anything leaks.
OrrieG is offline
Old 03-14-2014, 12:17 AM   #3252
yossarian19
Finished / mounted the intake piping, thought briefly about trying to get it cranking before going to class.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline
Old 03-14-2014, 12:49 AM   #3253
akdg87
akdg87's Avatar
Fired it up, turbo spools...no leaks so far, tested starter turned out it was okay
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline
Old 03-15-2014, 12:29 AM   #3254
Drakien
Drakien's Avatar
Just put vintage plates on it! It is legal to drive on the road!
Drakien is offline
Old 03-15-2014, 02:14 AM   #3255
yossarian19
Got the radiator fixed & reinstalled, went over the hoses I built a little. Started thinking about yet another iteration of the electric fan setup.
"Over my head"
Old 03-15-2014, 09:23 AM   #3256
la hi
I bit the bullet and had a HD 700-r4 built(Middle class auto services granite shoals) and changed out the 200-4r. This required a drive shaft cut of approx 2" (55" c to c on the yoke).
Scottys in austin did a great job while I waited. They fixed a tight u joint, cut the shaft, balanced the finished product for about 150.
I learned my lesson, don't do it yourself, and had a shop in Kingsland (gods hot rod shop) recommended by the builder build a new trans mount, install the 700-r4, adjust the 454ci so that the thumper cam would idle at a stop light and idle rather than stall.
An expensive 2k project, however it is a really sweat ride now.
la hi is offline
Old 03-15-2014, 01:30 PM   #3257
youngrodder
youngrodder's Avatar
I primered all of my floor pans for my 53 Suburban. Getting closer to welding them in.
I also started rebuilding the rear barn door latches on the Suburban as well.
The warmer weather is encouraging.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline
Old 03-15-2014, 01:58 PM   #3258
Rednek13x
Rednek13x's Avatar
Waiting for it to warm up and the snow to melt to start to disassemble.
Rednek13x is offline
Old 03-15-2014, 05:57 PM   #3259
yossarian19
Picking at it, trying to get it to start after a long time sitting. No luck yet. Becoming concerned.
"Over my head"
Old 03-15-2014, 08:40 PM   #3260
capnduane
capnduane's Avatar
Previous owner had installed a Aoogah horn and put the button under the dash, below the radio. I have the stock column and wheel on my 55 2nd, it does not have the horn wire down thru the column. So I relocated the horn button to one of the bolt holes on the column for the shifter handle.. OK for now, alot easier to sound the horn for the kids that I pass on the road, most get a big kick out of it!
'55 Chevy 1/2ton pickup w/ Pontiac 350 and Muncie M21 close ratio 4speed "Red Ryder"
capnduane is offline
Old 03-15-2014, 09:01 PM   #3261
Mac the Yankee
Found some bad repairs, holes, and a new crack in the windshield :
Mac the Yankee is offline
Old 03-15-2014, 09:48 PM   #3262
OrrieG
OrrieG's Avatar
Tried to fire it but having starter issue. I think its shimming issues. One time it did try to run back fired thru the carb, so timing is a little to advanced. Will hit it again tomorrow.
OrrieG is offline
Old 03-16-2014, 12:30 AM   #3263
mechanixman
mechanixman's Avatar
Not much with the truck,
But I did get a minibike!
not bad for $80
-Nick
Projects:
1952 Chevy 1 ton = The Build page
mechanixman is offline
Old 03-16-2014, 09:08 AM   #3264
crossfire84
crossfire84's Avatar
sold my motorcycle yesterday now i have enough $$ to finish it off this summer and hit the road!
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline
Old 03-16-2014, 10:55 PM   #3265
58CameoAZ
Well after 6 weeks of being laid up with an infection in my Right leg i was able to go out in my garage and get the rear end out of the 85 Corvette i got!
My Son came up for the day and spent it with me and that was the best Part!
he helped me pull the rear suspension out.
Next i need to get the front suspension out and motor and trans out as well,
But it really felt good to finally do something after being laid up!
Allen
58CameoAZ is offline
Old 03-16-2014, 11:26 PM   #3266
SCHRUMGMC
SCHRUMGMC's Avatar
Trying to figure out if my Vacuum Advance is the right one or not..Have a new Inline fuel filter one it though, hoping to get things sorted out as soon as possible
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline
Old 03-16-2014, 11:32 PM   #3267
Dan in Pasadena
Dan in Pasadena's Avatar
Not very much. Took her out front and washed her. Threw a Mexican blanket over the seat back cause it's really in poor condition. Took her on a run over to Orchards Hardware and got a few thumbs up - always a nice reminder to get back to work on her.
Sorry for lousy photo with the reflection on the glass:
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline
Old 03-17-2014, 01:30 PM   #3268
OrrieG
OrrieG's Avatar
Minor victory. After shimming the starter 4 times I got it to where the bendix engaged and turned over twice. The second time the engine fired and ran for about 30 seconds, enough to drain the carb bowl, but not enough to start drawing from the tank. Good news is no fluid leaks. Did sound like it has a slight miss, but could be the timing or carb sorting itself out. Tried to get it going again and the bendix just will not engage. Its a used starter. I'm going to get a new one and hopefully that will solve the problem.
OrrieG is offline
Old 03-17-2014, 02:12 PM   #3269
55metalmonkey
Went out and got new plates and insurance in an effort to give the ol girl a shake down cruise. Found an oil leak off the timing chain cover that I have to deal with so I put the test drive on hold, it was pouring rain anyway and the last thing I wanted was to run into a problem on the side of the road in crap weather on my first drive.......... this waiting is killing me
55metalmonkey is offline
Old 03-17-2014, 05:18 PM   #3270
58-GMC
58-GMC's Avatar
Finally started disassembly of the front metal to make way for some Porterbuilt and Accuair goodies.
58-GMC is offline
Old 03-17-2014, 06:22 PM   #3271
OrrieG
OrrieG's Avatar
Found out if you are a good customer of local NAPA store you can walk in with a FUBAR starter with their id tag and number and no receipt on it and walk out with a new one under life time warranty.
OrrieG is offline
Old 03-20-2014, 08:52 PM   #3272
tbrown5079
After all the stressing out over the fuel system I went to the local guy that does my hoses and got it started. All that stress over nothing. I pick up the hard line tomorrow, then measure for the braided hose to the fuel rail.
tbrown's 56 Cameo Build
tbrown5079 is offline
Old 03-20-2014, 09:16 PM   #3273
la hi
I bit the bullet again and had my inner fenders installed by Gods hot rod shop. I tried it once and said forget it.
57 swb
la hi is offline
Old 03-20-2014, 09:19 PM   #3274
lgoodso1
Worked on disassembling my leaf springs on my 57 TF sandblasted and primed the springs.
lgoodso1 is offline
Old 03-20-2014, 11:20 PM   #3275
Kodiaks53
Finally got the power steering pump pulley off the shaft and cleaned up the pump. Got the pump located on the engine and the new March pulleys should be here tomorrow from Summit
Kodiaks53 is offline
Closed Thread
