#3276 |
Re: What did you do to your truck today!
Finally put in my new carpet the wife got me for Christmas!!! I also put down some sound dampener, took the gas tank out to clean it and replaced the cab mounts.
Before: ![]() During: ![]() ![]() ![]() After: ![]() ![]() ![]() ![]() |
#3277 |
got the tail light trim and bottom of tailgate trim back on...just need to finish top of tailgate... ran out of sun shine.... after that the tach goes in... then the stereo and carpet and we are done.... time for the 16 year old to start driving it to school....
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
#3278 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Pulled the bed off and finally put the truck up on car dollys..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#3279 |
I am trying to figure out how to install my new seats in my truck. I bought new leather seats. They are the second row out of a new Honda Odyssey. If anyone has any information on how to attach these, I would really appreciate it. They have hooks on the rear portion of the seats and slots in front. Help. Thanks much.
"Arrive, Raise Hell, Create Confusion, Leave". |
#3280 |
I have used my old seat brackets and just redrilled them to fit the new seat but that worked for me on my seat, may not be as easy on yours.
#3281 | |
![]() Join Date: Mar 2007
Good luck Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#3282 |
I painted my bed and installed a drop down battery box.
#3283 |
I knew all that sanding would pay off.
Paint job looks really good! Dano
![]() ![]() It ain't yours, if you didn't build it! |
#3284 |
Eat, Sleep, Drive a Chevy
Picked up the cab from the body shop, got it to bubba's and we sat it on the frame. looks good huh?
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
#3285 |
Looks great Randy,
do you have any pics or other info on the battery box you installed?
#3286 |
![]() Join Date: Dec 2006
Did some more work on my doors. First pic is of Passenger door after spraying boom mat on. I had already sprayed rust converter, rust encapsulator and bedliner before the boom mat. Now its ready for the skin to go on.
Next couple of pics are of the rust work on the Drivers side door. Replaced the inner door bottoms, fixed the rusted out upper hinge area and fixed the upper part of the door on the latch side.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#3287 |
yoohooo, got new HEI distributer and yellow wires installed, took out the old air conditioning pump and hoses while we were working in the engine compartment yesterday. next item on honey do list .... rear leaf spring bushings and u bolts
1969 GMC Custom Camper 1995 GMC Jimmy 4wd 2k Suzuki LC1500 |
#3288 |
Finally started mine for the first time
#3289 |
hell yeah i cant wait to start mine up again. just threw on the new performer intake and 650 carbourator and the old filter, i have a 9inch filter on its way
#3290 |
Took advantage of the break in the weather to fix a couple of things and change the oil. Figured as long as I was at it, I would install the new radio antenna that I bought a while back.
I got the cowl off, new antenna install installed and the wire run though the firewall. All I had left to do was plug it into the back of the radio and I'd be done. Three hours later....
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
#3291 | |
what do you have for exhaust on that thing lady bird
#3292 |
all the trim is finally on, cleaned the inside to get ready for carpet and sound barrier. adjusted the carb.... and some other small tinkering... next the tach and stereo
#3293 |
Collector of Projects
Put some white grease on the wing windows... wow what a difference...
I think I stopped a horrible squeek.. The passenger side latch on the Blazer hatch has broken fiberglass and I htink that was the casue.. I just put a screw in it so it can't move... |
#3294 |
#3295 |
#3296 |
Installed an overflow tank for the radiator. I got it at Autozone.
#3297 |
Got this idea from a board member.
![]() And this. ![]() And this. ![]() |
#3298 |
C/10 junkie
Finally swapped from an idiot light gauge cluster to a regular gauge cluster.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#3299 |
New Rubber went on this weekend. Will post up pics when it gets daylight and i can get a break from work!
#3300 |
Not sure why but the PO welded up every seat mounting hole... So I had to drill new holes... SMH!!!... Cleaned up the engine bay and gave her a bath to only realize its gonna rain this weekend ... I was planning on driving her to work ..
Posted via Mobile Device |
