Old 09-01-2011, 10:22 AM   #3326
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: Project Vitamin C-10
looking good Alan...that bed wood is gonna be really nice....did you ever decide on doing anything else with the tailgate, or are you just gonna leave it painted solid?
Thanks and I will leave the TG plain and simple. The only accents to the outside will be the custom trim. I have a thing against emblems and pin stripes. I like them on others, but i like a simple look.
I called the drive line shop (Ron's driveline in Gainesville) Steve was super nice and helpfull. He lives close to my work and will bring home a yoke and U joint tonight and I will pick it up in the AM. He told me to slide the yoke in til it bottoms and back it out 3/4" and measure center of cap to center of cap.
Alan's Classic is offline   Reply With Quote
Old 09-03-2011, 04:44 PM   #3327
Alan's Classic
I measured the driveshaft like the shop told me and it came to 59" to the CL of the caps.
Also applied the peel and seal. Boy, that stuff is sticky. Better make sure it doesn't conatct something you don't wantit to, because it's not coming back up in one piece. I haven't done around the passenger side firewall yet. I have to see where my AC and heater lines will be.
Also got the majority of the carpet done. Some might say it is too soon and it might be. It will be more comfortable to lay on when I'm under the dash.
Old 09-03-2011, 05:25 PM   #3328
Strodder
Daring to be Different
Strodder's Avatar
What are you going to use on the firewall under the dash?
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 09-03-2011, 05:56 PM   #3329
Alan's Classic
Not sure yet. Any suggestions?
Old 09-03-2011, 08:47 PM   #3330
Alan's Classic
Quick question, I'm starting to run wire and I'm at the brake light switch. I used a ohm meter to check the switch. It's got constant continuity unless it is depressed. That is opposite of what I think it should be. I think it should get continuity when depressed so it energizes the brake light. Am I smoking crack?
EDIT: I think I'm wrong I was thinking wrong as usual.
Old 09-03-2011, 10:17 PM   #3331
Strodder
Strodder's Avatar
When it's compressed the switch is off if it's on the bench. Or are you checking it in the truck by depressing the brake pedal?
I didn't see that last sentence. DOHH also.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 09-03-2011, 11:45 PM   #3332
Alan's Classic
Thanks for the reply anyway.
As mentioned before the wiring has begun. At first it was a little overwhelming with a hand full of wires. Once you break it down to one wire at a time it's not too bad.............yet. Got the steering column done in the cab and I'm almost done with the ignition in the cab. Loosely running things as I go and will secure everything last.
Old 09-04-2011, 07:25 AM   #3333
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I think just a repro firewall pad.... they are perforated for the different acc. but nothing is punched out.
Old 09-04-2011, 11:22 AM   #3334
Strodder
Strodder's Avatar
That's what I used on the 57 Sedan Delivery I'm working on.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 09-04-2011, 11:37 AM   #3335
bubba327
HOW long until spring??
bubba327's Avatar
Wiring is the best part!! the brake switch is a normally closed switch and will have continuity through the contacts.
A switch or relay is referred to as having contacts normally open or normally closed. This is the contact position of the switch or relay ,UN-installed and no interference with the operating mechanism, in the at rest position .
Some switch's and relays can also be a double pole or triple pole with one set being open and one set being closed.
When installed the brake pedal arm holds the contacts open, until you press on the brake allowing the contacts to close and the light to come on.
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 09-05-2011, 11:54 AM   #3336
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Of course an electrician would make a comment like this!....Oh wait, an electrical inspector now!
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline   Reply With Quote
Old 09-06-2011, 08:16 AM   #3337
shortbed70
shortbed70's Avatar
Looking good Alan and I'm with you, Carpet is much more cozy to lay on... And I hate wiring!
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 09-06-2011, 09:54 PM   #3338
chas350
134 pages wow!
What a great build thread Alan. Very humble for such a talented guy!
"I'll Procrastinate Tomorrow"
quote by LEEVON
71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's
70 K20 long fleet
98 G3500 work van
chas350 is offline   Reply With Quote
Old 09-06-2011, 10:09 PM   #3339
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Finally getting back on it. Decided to work on the hood. I cut the problem areas out so the sand blaster can get to the inside of the corners.
The right corner was the worst of the two sides.
I'm holding a chunk of filler that was packed in the corner.
This is the Left side.
It only had pin holes. I will clean the rust and weld the holds and reinstall.
I'm going to use extra cowl side panels to cut out patches. The contour is already there. Since I couldn't give them away I figured why not put them to good use. They can also be used to repair door check strap damage.
I'm glad when I run across these kind of repairs.
It restores hope.
I have an extra hood that isn't any good on the outside, but has a good inner structure. I'll cut patches out of it to repair the bad areas.
This is where I am.
I now have two hoods.
I just picked up a hood nice on the big open surface across the top, but needs some help around the inner supports.
My hood is pretty banged up all across the top but is rust free.
So between your post and Bugeye's thread, I think I can make one really nice hood.
http://67-72chevytrucks.com/vboard/s...d.php?t=415609
66 C20 Service Truck:
Old 09-06-2011, 11:00 PM   #3340
Alan's Classic
That's definately a thought. I might have the upholstery shop try something. When I get it all done.
Thanks for the explanation.
The carpet does help. I wish i knew more about wiring. It's kind of like wanting to learn another language. Maybe I'll get around to it someday. Wait that someday is here as far as wiring.
Originally Posted by chas350 View Post
134 pages wow!
Thanks and I can't believe it has taken me this long to get it done. Heck, it's not done yet.
It restores hope.
This is where I am.
Good luck, I will check out the link.
I'm back after being without power for 26 hours due to a EF1 tornado that was spawned from tropical storm Lee. It had a 24 mile track and passed within a mile from the house. We didn't have any damage at the house, but 400 other homes had damage or were destroyed. Things are getting back to normal.
I did get 2 light coats sprayed yesterday. It was looking very nice until it started drying. it sunk in some, but still looks 100% better than before. I have to get another quart and lightly sand and spray again.
I also pick up my drive shaft tomorrow.
Old 09-06-2011, 11:06 PM   #3341
bubba327
bubba327's Avatar
Glad you are okay!!!!!
Alan you are an inspiration for all of us to continue on our projects.
I wish mine was finished but I realize that we are having too much fun driving it now to pull it off the road ...
Remember---- no hurricanes in Montana!!!!!
Old 09-07-2011, 03:38 PM   #3342
Strodder
Strodder's Avatar
Yeah, glad your OK. Close call huh?
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 09-07-2011, 11:18 PM   #3343
Alan's Classic
Thanks Bubba, I wish I was was driving mine now. No hurricanes, but they have had frost already in northern MT. It was 58 this morning here and I put on a long sleeve shirt.
Too close for me.
The first pic shows a close call. I installed the wiper motor and realized it will be close to the radio, thinking the radio might not fit. It does clear, not by much.
Drive shaft is in for a test fit. I will be removing it to paint it later.
Also installed the 175 amp maxi fuse. This should be a safe place and out of the way. The wiring is not secured yet. Once I get everything inplace and working. I'll try to clean it up some. It won't be as nice as I would like it, but I'll do my best.
Old 09-08-2011, 01:59 PM   #3344
6772owner
Gearhead
6772owner's Avatar
The truck is coming along great, keep it up, I love the routing of the wiring so far, nice and clean!
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 09-08-2011, 09:30 PM   #3345
Alan's Classic
Thanks, I was hoping to work on the truck tonight, but I've got a bad headache. Time to rest. I was able to sand the wood down with 600 today. So it's not all lost.
Old 09-08-2011, 09:55 PM   #3346
chad64chevy
chad64chevy's Avatar
its like you have said progress is progress right!!
chad64chevy is offline   Reply With Quote
Old 09-09-2011, 11:58 PM   #3347
Alan's Classic
That's it in a nut shell.
I cracked open another bag of wires tonight (late) and studied the diagrams for a few minutes. Bubba or any other elctrical guru stayed tuned. I will study them tomorrow and see if I can figure it out. No matter if I figure it or not I will post pics of the schematic and my crazy idea of how I think i should do it. Then get graded. My problem area is the fan relay and all related parts.
Old 09-10-2011, 12:54 AM   #3348
bubba327
bubba327's Avatar
tuned in!!! I wish I was closer .... I'd come over and help!!!
Old 09-10-2011, 10:47 AM   #3349
Strodder
Strodder's Avatar
Yeah me too, between all of us, we can really f*ck it up.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 09-10-2011, 12:14 PM   #3350
bubba327
bubba327's Avatar
I can't scratch the paint from here!!!!
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange
