#3326 |
Re: What did you do to your truck today? Chapter II
rad support on ,one fender for stability checked wiring location ,rad too big ,found one right size in storage trailer out back hoses from 85 fit perfect
cant wait for it to roar to life |
#3327 |
![]() Join Date: Nov 2008
Installed a new fuel pump and bed
Before: During: After:
1970 ![]() 1971 ![]() 1971 ![]() 1972 ![]() 1972 ![]() 1999 ![]() |
#3328 |
![]() Join Date: Sep 2005
Got a couple things done.
#3329 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
I just love the details. Did you just wash under the hood or respray it?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#3330 |
![]() Join Date: Oct 2014
Got the passenger side inner rocker fit up and welded in.
#3331 |
Well it seems I caused myself more work. I went to move the truck the Sunday night and found the dash lights not working. I dug into it last night figuring it was just a ground. After checking all the grounds I also noticed no parking lights, running lights or break lights not working. It really surprised me because I have been driving it and didn't notice it. Come to find out when I installed my new door sill I screwed through the wire for the dome light and grounded it out and blew a fuse.
#3332 |
installed modified brake booster from a 1980 1500 ,where most of my drive line conversion and parts came from, fabbed new linkage and installed master cylinder ,now the fun of plumbing all the lines
overhauled alternator and cleaned it in blaster made all new battery cables and installed and began connecting harness |
#3333 | |
Old member
![]() Quote:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#3334 |
Old member
I took the old cut off on the negative side of the battery off and put a regular mount back on it. The local car audio guy said it was what was making my lights go deem at night. I also polished up the new inserts I bought last week.
Oh I fixed the power steering leak also. ![]()
#3335 |
it takes a lot of research to build one of these ,my second in 30 years ,a lot more options in parts you just have ti take time and match up parts ,there are too many variables to answer that
#3336 |
seat and steering wheel today
#3337 |
Today I blacked out the custom grille to better hide Ole Blu's missing tooth as you can see in the before picture. Also I removed the bug screen the previous owner had on there and installed the hood emblems. At first I had just removed the billet grille, but I didn't like the emptiness. So I sandblasted the chrome off and painted it black. There was too much chrome anyway, and I was never really happy with the way it looked. I'm happy with the way it looks now. Still working on the bed. I'm finally done sanding now. I just need the rain to stop so I can stain and seal it.
1969 GMC C/1500 LWB Wideside 355 SBC/TH400/3.73 posi-traction Daily Driver. Carburetors, because I don't care to consort with that of the robot race. |
#3338 | |
![]() Join Date: Feb 2011
#3339 |
![]() Join Date: Aug 2009
Much better, looks good
#3340 |
received my exhaust tips yesterday, not to get the brakes bled, the E brake cables strung and Fire the beast up!!! Then it's off for my exhaust, alignment and then my safety inspection and finally, plates!!! here's a few shots of my exhaust tips and mufflers...
Yeah!!! ![]() ![]() ![]() ![]() Ben ![]() |
#3341 |
![]() Join Date: Jun 2005
Made a bracket to hold my fuel pressure regulator in place. Gotta remove for paint and it will be done.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#3342 |
Scrounged these things from the jy for the k20 not bad for A Couple of dollars.
of course a lil' clean up is necessary. Still need 2 frame brackets that won't be easy to get off.
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
#3343 |
got a sweet set of wheels and tires on a barn find
#3344 |
Stuck these stainless steel headers on because its the only new part that was waiting on me when I got home this week... meanwhile I'm still working on that hood....
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
#3345 |
THANK YOU ALL for the wonderful pictures !
![]() They keep me motivated even though my truck is just sitting in my driveway inoperable and I have the bed full of parts as it's blocking one of my daily work spaces.... I walk past it multiple times a day and curse the body shop but I do have a plan , a long and slow one but I want to drive it again so badly..... I look at everyones hard works and dream of clattering and wheezing down the road again with a load on and my elbow out the driver's side window . I see one removed the stepside bed and installed a fleetside ~ I cannot imagine this but I'm a Farm Boy who loves and needs those steps for work / loading =8-) .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#3346 |
Today I put the new fuel line from the pump to the carb on and when I was tightening the line at the pump, I apparently over tightened it and the pump started leaking. So I also installed a new fuel pump. I guess I don't know my own strength. Hey Rocky, watch me pull a rabbit out of my hat!...
#3347 |
![]() Join Date: Jun 2015
Got it running today. had some electrical issues, thanks to the replies and older post with wiring diagrams, Awesome Chevy & GMC site
#3348 |
#3349 |
picked up one of these today now to find someone to go through it
#3350 |
Got this a few steps closer to being done...
