03-13-2016, 03:58 PM | #3351 |
Old member
Re: What did you do to your truck today? Chapter II
What did you end up doing to get the hood to close. Good job!
03-13-2016, 05:29 PM | #3352 |
Wow,that looks great .
03-13-2016, 06:37 PM | #3353 |
I took the radiator back out... dont need that anyway
Ill get to that part later on... Probably get a different radiator and if I have to I'll move the fill to give the clearance needed
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
03-13-2016, 06:54 PM | #3354 |
getting started
03-13-2016, 10:56 PM | #3355 |
FINALLY got my hood off the truck, let the fun began. This frees up a lot of parts . Spent a weekend building the bench. The platforms front and back have a gripping rubber sheet on top (recycled rubber and not expensive). I really like using this stuff. It makes for nice padding, and holds things in place. I just used the existing nuts in the hood and some hardware to four-point underneath. I really need the room. There's lots of storage underneath, and will easily push it into the driveway and onto a trailer. Over-kill, pretty much all 3" screws and 350 lb. casters.
The bow tie is the original off my truck. Until today it hasn't been cleaned or seen water in decades. The image doesn't do its justice. I couldn't make out any flaws in the chrome, though my eyes aren't great. It's good enough for my build, and I'm kinda picky.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
03-13-2016, 11:38 PM | #3356 |
Didn't do to much but got few little things done and it's always fun working on the truck painted head light bezels and washer fluid bracket tryed shining up the grille but it have todo here's few pics because I know everybody loves pics lol
03-14-2016, 11:12 AM | #3357 |
I spent the entire day yesterday in the barn working on my 71 SWB 4x4. Got lost of the wiring finished, Just the fuel pump left to do today. Also worked on getting mounts/risers built for the ProCar Low back buckets.
This deal has been a 3 year process for a bad transmission.... But I'm almost to the finish line!! |
03-14-2016, 11:14 AM | #3358 |
I used Westley's Bleche White and an old brush from a carwash; ya know where the foamy soap comes out and you have to manually brush? I did not take it to the carwash. I used to own a carwash and I kept the brush when I sold it. That brush is one of the best brushes I have; soft enough where it doesn't scratch the paint, but enough stiffness where if you need a little "oomph", it'll cut thru it.
03-14-2016, 11:23 AM | #3359 |
Tried to clean up firewall, but hard to reach some places and hated to mess w/the grease pencil markings. Wetsanded roof w/2000 grit. Had nice weather here in OK on Sat and Sunday, but had to work on the yard....ugh!!!
Helper lurking in upper right corner. Too bad she can't push a lawn mower!!! |
03-14-2016, 12:57 PM | #3360 |
That hood is awesome!
Ryan... 1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain http://67-72chevytrucks.com/vboard/s...11#post5532411 |
03-14-2016, 01:22 PM | #3361 |
Well, actually it was yesterday, but I got my frozen wipers working again. Just have to get some new blades and I can drive in the rain again.
Whenever it rains here... |
03-14-2016, 01:34 PM | #3362 | |
03-14-2016, 01:56 PM | #3363 | |
03-14-2016, 07:42 PM | #3364 |
I finally got the console all painted up and ready to go in
I put it in my blazer but it'll fit in the trucks too I'm happy with how it looks and works |
03-14-2016, 10:10 PM | #3365 |
That console looks sick! Love the bowtie emblem. What's it out of?
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
03-14-2016, 10:54 PM | #3366 |
Like that console too. Looks good.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
03-14-2016, 10:58 PM | #3367 |
Removed the inner grille from the outer. Don't know if there's an easier way, but unless you're willing to risk breaking the inner, seems the only way is to use a small cutting wheel and cutter piers on the plastic anchors. I was going to hang the inner on the wall, but realized that's asking for a break as well, so "we" sacrificed some Xmas storage for that and more. Really could use more storage around here, but I'll make it work.
Say, anyone know if there's a part number on the outer grille, other than a sticker that's no longer legible?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-14-2016 at 11:04 PM. |
03-14-2016, 11:03 PM | #3368 |
03-14-2016, 11:19 PM | #3369 |
Ha, sorry. The web was acting up, so I typed fds in etc.....Accident.
03-15-2016, 12:56 AM | #3370 |
Installed my push-on weatherstrip excellent fit... Thank you GMCPauls
03-15-2016, 08:37 PM | #3371 |
(007) aka Houdini
I like the looks of that hood, u did a awesome job
Live life one day at a time! |
03-15-2016, 09:19 PM | #3372 |
possumgut is doing a awesome job too the whole truck the hood is just the iceing on the cake. keep up the good work dude.
oh that console is incredible nice work. front clip off and disconnected engine in the k20.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
03-15-2016, 10:07 PM | #3373 | |
lol.. that finish line is not to be confused with the light at the end of the tunnel...
Thank you Thank you sir... almost there. Good luck on the k20!
03-16-2016, 12:56 AM | #3374 |
Rolled her outside so I could clean the shop. Also picked the cab up from my paint guy today!
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296 |
03-16-2016, 01:03 AM | #3375 |
Got the timing dialed in and did my first 100' burnout on the new build and drove it for a good hour. Everything runs great and all the gauges and floor shifter are awesome. First time builder, the engine build was done with the help of the guys on this site, I couldn't have done it without em'.
