Closed Thread
Old 02-13-2012, 04:45 PM   #3401
dliving69
dliving69's Avatar
Re: What did you do to your truck today!
Took my truck out for a drive in the snow for the first time since ive owned it..its almost been a year.
dliving69 is offline
Old 02-13-2012, 06:31 PM   #3402
midniteblues
midniteblues's Avatar
rebuilt the carter 600 couple of weeks ago it was full of crap and the acc pump was worn out so before i fire it up again i figured i'll pull the tank too clean it out im thinking a chain and some clr should do it its not real rusty but lots of white evap gas residue
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline
Old 02-13-2012, 06:33 PM   #3403
fuzzy23
fuzzy23's Avatar
Swept the snow off of her so I could go to work.
1972 K1500 Longbed 350 w/3 on tree.
1976 Chevy Nova 350 auto
1972 C10 (donor)
fuzzy23 is offline
Old 02-13-2012, 09:56 PM   #3404
mud.man.rj
mud.man.rj's Avatar
Come on Fuzzy23, your freezin us out with those smowy pic's. Poor truck.
mud.man.rj is offline
Old 02-13-2012, 10:28 PM   #3405
fuzzy23
fuzzy23's Avatar
It was 60's last week. Truck looks good covered in snow.
1972 C10 (donor)
fuzzy23 is offline
Old 02-13-2012, 11:31 PM   #3406
68 IRON
68 IRON's Avatar
Today, I finally took the advice of a friend and removed the dealer (or factory) overload springs. Everytime I would go over a speed bump, the back end would bounce two or three times off the ground...but thats what a tree leaf overload will do! Nice and smoooooth now!
68 IRON is offline
Old 02-13-2012, 11:34 PM   #3407
ryanroo
ryanroo's Avatar
removed more paint. tried more bodywork. i need more practice.
ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline
Old 02-13-2012, 11:55 PM   #3408
Newtz67
Newtz67's Avatar
You guys are getting some snow in Ks. I see. We have a place about an hour from Wichita. I love it over there.
Newtz67 is offline
Old 02-14-2012, 09:30 PM   #3409
glider_6969
Actually haven't done much other than stare at it in the Garage, I don't take it out in the snow I like keeping it on a no salt diet.
So I have just been doing some looking around for some new shoes for the truck, hope to get some before the spring.
What do you guys think about these. Any one seen these on our trucks before.
68 Long stepper
My other ride ,,, 07 Streetglide..
glider_6969 is offline
Old 02-14-2012, 11:50 PM   #3410
Delo69
Delo69's Avatar
Got new tires on my newly finished steelies and topped with my refurbished hubcaps.
_____________________________________
Dennis
1969 C10 250 w/3 on the tree - project/weekend warrior
2010 Subaru Impreza - daily driver
Delo69 is offline
Old 02-15-2012, 12:59 AM   #3411
mud.man.rj
mud.man.rj's Avatar
Glider 6969, nice rims, what are they priced like, simular to the MT Classic Lock rims but black edge. Today I actually used my truck to go get a haircut, man was that a nice cruise, don't use it enough.
Old 02-15-2012, 03:35 AM   #3412
mmmBoost
Ordered my black powder coated power brake booster bracket from Captainfab, CPP Tubular trans crossmember w/poly mount, LMC headlight bulb retainer rings, and LMC clear front blinkers. Can't wait till the parts start Rollin in.
Always remember those that had your back
Never forget those that turned it
Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt,
Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner
mmmBoost is offline
Old 02-15-2012, 06:01 PM   #3413
ffk
ffk's Avatar
closed off fire wall.going to have vintage air...also shorten up the vents..they will have a 6 1/2 speaker and the wirering harness going out thru it..
my build thread -- (http://67-72chevytrucks.com/vboard/s...d.php?t=438604)
ffk is offline
Old 02-15-2012, 09:39 PM   #3414
glider_6969
I just got the pricing back, the wheels are a 16in rim.. they priced out a $194 US. dollars. on the web.
Going to look locally if I can get them.
68 Long stepper
Old 02-16-2012, 08:38 AM   #3415
wrwelton
wrwelton's Avatar
Took apart the spare doors yesterday and going to have the vent windows chromed. I am getting a delivery from LMC todau and will start insulating cab.
I know I can! I know i can! 72 K20 Restoration
wrwelton is offline
Old 02-17-2012, 08:18 PM   #3416
ffk
ffk's Avatar
made a filler panel for firewall on driver side to match passenger side..hand formed the old fashined way...a small torch , hammer and a round bar ..heated and hammered radius on panel...also cut vent cowl shorter..no need will have vintage air...im going to put a 61/2 speaker in there and a rubber grommet for the wireing harness
ffk is offline
Old 02-17-2012, 08:30 PM   #3417
67cheby
67cheby
67cheby's Avatar
Nice work
67cheby is offline
Old 02-17-2012, 08:37 PM   #3418
Newtz67
Newtz67's Avatar
Got my tires remounted on the rallyes and got them on the truck. Much better!
Newtz67 is offline
Old 02-17-2012, 08:50 PM   #3419
74baggedbug
Started custom kick panels for my truck ... Will post pics later
74baggedbug is offline
Old 02-17-2012, 09:23 PM   #3420
midniteblues
pulled my tank out to clean it and found this
Old 02-17-2012, 09:25 PM   #3421
Newtz67
Newtz67's Avatar
Patch work?
Newtz67 is offline
Old 02-17-2012, 09:41 PM   #3422
midniteblues
then i found a nice tank with all the 3/8th fuel line to replace the 6cyl lines and the patched gas tank. all the sending units harnesses for the tach dash vent visors n clips, great fan shroud on cl an came back with all this 4 $60 heres a pic of my very dirty seat and one of the high hump i made up for the shifter,and finally the dash i'll be taking out the 5" autometer just looks soooo outa place time to go
Old 02-17-2012, 09:42 PM   #3423
midniteblues
dang forgot the dirty seat
Old 02-17-2012, 10:06 PM   #3424
74baggedbug
Coming together
Old 02-17-2012, 10:14 PM   #3425
Newtz67
Newtz67's Avatar
74, that blue looks killer!
Newtz67 is offline
Closed Thread
