#3426 | |
Re: What did you do to your truck today? Chapter II
#3427 |
![]() Join Date: Dec 2012
Well, the outer surface of the bumper was already like new - really only metal polish and some wax on it.. the inner had the start of rust and that is where I really cleaned things up. After the Coke and foil there, I used metal polish and wax as well.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
#3428 |
Old member
Installed the Lokar billet gas pedal and the brake cover for the truck. I also installed a new chrome rear diff cover for the 12 bolt.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#3429 |
Installed new bumper, front and rear lenses, rebuilt doors with all new rubbers, added armrest, matching ignition and door locks, and new outside door handles. Busy day. Only have pics of bumper. Started getting dark, so I didn't get look real good but I think I may need to adjust my bumper.
Boyd -67' C10 SWB FLEETSIDE LS 5.3 4 speed muncie ![]() |
#3430 |
Just looked at it for a bit wondering what color its going to end up being when I get to that part... my garage is in shambles... where the heck is my cleaning lady??
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
#3431 |
I'm in the middle of changing my differential oil and cover (old one was a nice, rusted chrome unit). Draining overnight. Now I can see my gear ratio. Wife just loves that gear oil smell in the garage! Well, not really!
#3432 |
Now is the time for that posi unit
#3433 |
3.07 ratio, not the best unless a lot of highway, so gear set and posi.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
#3434 |
Took ol Samson to a car show today to stretch his legs and let the B horses run free. Been a great day.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
#3435 |
![]() ![]() Join Date: Feb 2009
Took my evap. out and cleaned up the box to see what I've got. Apparently when more careless (ha!@) and dropped the engine in 1993, I sprayed along the outer edge of the box when I painted the firewall. Really a good five inches worth on the RH truck side. At any rate, it's a great box otherwise, so I'll try removing the paint. From what I've seen, I prefer not to paint the box. Worst "case" scenario I'll have to. Any suggestions how to remove that paint with no affect on the plastic evap. case is appreciated.
Also appears the A/C-Heater door in the evap. box doesn't want to close all the way. Don't know if that's common, but sure was a lot of dirt in there despite being garaged and little use. BEAUTIFUL truck CST10
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#3436 |
How are leaves always findinf there way in my cab?
#3437 |
What is the A/C-Heater door and Drain Tube in the Evap. box, and the Air Shut Off Valve Door in the cowl, for $300 Alex.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-27-2016 at 12:59 AM. |
#3438 |
Hauled way too much gravel...from just down the road.
1972 GMC C1500 350/350 1965 Mustang 2+2 289 4spd, show-car 1965 Mustang Coupe 289 4spd, stoplight racer 1/2 dozen Wheelhorse Tractors ![]() |
#3439 |
wow.. how did you keep it in the bed with it upside down like that? lol
Its a good looking worker
#3440 |
Down force and speed. lol
Brad handshoe |
#3441 |
Installed upper trim holding and some interior work.
I give up, i can't get the pictures right side up. |
#3442 |
Even upside down it looks great .
#3443 |
Installed my 3/5 static drop
1972 C10 - It might be old, but it's not slow |
#3444 |
Old member
If using a I phone and you turn your phone long ways. Bottom of phone pointing right with volume buttons pointing down. Use the regular button for pictures and they should be right side up when you upload them.
#3445 |
Pulled out my radiator on the 69 to get checked out.
Buncha parts on order. Got cleaned up an spent time with the family. Happy Easter.
Chris '69 C-20 '04 Jeep TJ |
#3446 |
Old member
Here you go!
#3447 |
Thanks!
#3448 |
Old member
#3449 |
Took my cargo light out to find this great work
#3450 |
Made a temporary electrolysis tank, seems to be working ok so far!
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296 |
