#326 |
1969 Short, Fleet, and Beat
Re: project (sweet pea)
Bro, that shade of green look amazing! Good call on the color.
#327 | |
C10 Club Tennessee
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
#328 |
That's awesome Tony...congrats on the little sweet pea. I have two daughters myself..both over 20. They are the best part of me without
a doubt. Dano |
#329 |
Luv the Crewcabs
Congrat's on the Little one, You Have the Right Attitude , Family 1st................
Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
#330 |
Taylor Layne Hot Rods
Small update.....Was a little slow at work today....Our paint booths have been down for 2 days (Gas Issue)......Anyways....i took my driver side door to work.....Got the lock hole shaved and all the E-coat blocked...Its in ok shape but will need some glaze work.....I got it all ready to wipe in the A.M.....hopefully i will have it in Primer tomorrow ......Then its off for the same treatment to the passengers side......Will Post pics when i get it all done....I have a few now but its cell phone......
#331 |
Well here we go.....First i blocked the whole door (in E-coat) with 80 grit with my long block.....Found a small crown in the door that is not supposed to be there......It probably would never been seen....But it was driving my crazy so after i got the lock cylinder welded up and ground smooth...i wiped the center of the door end to end with glaze.....i would have used some polyfill primer...but i am out so i went this route.after about an hour of blocking from 80 to 180 then to 220 i was ready for some primer.....
... Last edited by bad6772; 09-20-2008 at 09:32 PM. |
#332 |
in primer...i still would want to block this primer out with some 180 ....then Re-prime.....And block again when i am ready to spray......
#333 |
One more little update... got the column and steering shaft mocked up....Kinda sucks though i scratched the hell out of the shaft so i will need to spot it back in....i also chipped my upper control arm so i will spot that in also....i do Expect to get chips on these and other pieces .......But when it does its maiden voyage...it will be chip and scratch free....LOL..And for anyone that is doing or has done the tilt conversion.....Does the main steering shaft look to close to the upper control arm....?? The truck is setting on the ground at the moment...And i am pretty sure it wont ever hit.....But it looked close to me......?
#334 |
Hey Tony,
I just went out and looked at mine and I would say yours if fine. Mine would fall in the same place as yours. Dano |
#335 |
its all about the +6 inches
yeah Tony... I just looked at the one ton and the longhorn... same way.
#336 |
Thanks Man....And thanks Dano
#337 |
Got the passenger side door lock shaved today and everything glazed up....I am going to go back out in the A.M and give it a blocking and prime....I also picked up a new trans cooler....FOR CHEAP....Went to my local Napa Store and they had one that some one returned ....And they took most if not all of the Mounting Hardware and hoses...SO they could not sell it or return so i got it for $10.00.....Its a heavy duty unit And is $40.00 new so WOOHOO...It will replace my canister style i bought... i just do not think the canister style will be enough......I also bought a pair of the after market headlights (H3) bulbs i think....I got them from a junk yard this A.M for 5 bucks each....They look exactly like the ones i bought for my 67....And those dudes was 80 bucks ....So score again......I will Post some pics up tomorrow ....
#338 |
As usual ,looking good.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
#339 |
Under Construction
Tony,
looking sweet, keep up the awesome work..... Wish i was this far along on our father/son project.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 09-28-2008 at 12:29 PM. |
#340 |
Pics of the scores.....I got to get mowing...I got the pas side door in primer....Just need to block both doors again...Re-Edge with the water born and get to the fenders..
#341 |
On the fast track to nowhere..
Cool! I replaced my left inner rocker today
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
#342 |
Slacker
#343 |
#344 |
Just so mike dont flame me.....There are no updates.....LOL .....as i am enjoying my newly arrived 1 month old daughter.....Although i do plan to go out in the shop in the am......
#345 |
heck yeah man,
cherish every moment, they grow up way too fast
CHEVY ONLY
#346 |
Well i did get a little work done....Got the new trans cooler mounted with some S.S flat bar i had laying around........Looks pretty good....And i think it will function just fine....i also am going to use my old trans cooler as a P.S cooler.....I already drilled the holes in my frame....So i will utilize them.....I will get some pics in the A.M....Its dark outside....
#347 |
No flaming here, I know what it's like to have a new little one
#348 |
Aw......Is this OUR moment....lmao
#349 |
#350 |
mike i hope missy dont get mad....lol
| Bookmarks |
