Old 08-13-2008, 05:55 PM   #1
big_al_71
big_al_71's Avatar
Al's 71C10 Rebuild...updated with new additions
Well after going back and forward on my mind I decided to do an upgrade which turned out to be several at the same time... My truck is a 71c10 3spd manual bottom of the barrel with power nothing.
1971 Chevy C-10 fully done from top to bottom.
The list of upgrades are as follows:
*Classic auto Air A/C kit DONE
* Chevy 400 small block motor FULLY BUILT DONE
*Convert to automatic fully built(turbo 350) DONE
*Brand New steering column assy (DONE
*Replace engine wire harness and dash wire harnes DONE
*New Griffin Aluminum Radiator DONE
*Flexalite Electric Fans DONE
*Replace the radiator support DONE
* Brand new inner fenders DONE
*NEW battery Tray DONE
* Add power steering DONE
*Shaved the firewall DONE
*Repaint the engine bay DONE
*Repaint the interior of the Cab DONE
*Redo the rear differential and install auburn unit DONE
*Install new wheel combo 18/20 DONE
*Shaved antenna hole off cowlpanel DONE
*Smoothed firewall DONE
* ECE 4/6 Drop DONE
*Early Classics panhard bar DONE
*Install tonneu cover DONE
*ECE Hidden hitch DONE
*Replaced mirrors DONE
*Tinted Windows DONE
*New rear bumper arms DONE
* Replaced all Door Handles inner and outers DONE
*Replaced all weatherstrips and seals DONE
*Change Steering wheel DONE
*Rewired the complete truck and not a wire to show in the engine area or a/c lines DONE
*March Pulley Set DONE
*In dash am/fm cd player DONE
*Kick panels with speakers DONE
*Early Classics Front Sway Bar DONE
*Early Classic Trailing Arms on the rear DONE
*Billet Specialties valve cover and Air cleaner with K&N filter DONE
*Brand new calipers and rotors DONE
*Brand New Drums seals and rear shoes DONE
*Brand New auburn posi unti and 373 richmond grears DONE
*Completely rebuilt the rear differential seals bearings DONE
* Doug Thorley ceramic coated headers DONE
* Dynomax Mufflers with brand new exhaust DONE
* Tailgate chevrolet band DONE
* Autometer Gauges DONE
* Four wheel Wilwood brakes DONE
* Wilwood manual master cylinder DONE
*C-notch DONE
*Air Ride technologies DONE
* Billet Specialties Wheels 20x8.5 and 20x10 DONE
*New Tires DONE
* Exhaust redone (2nd time) DONE
* Painless under dash lights DONE
*Billet hood hinges DONE
The list keeps growing every time I look at it,, well I will post picts of the progress to share with you all....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
