11-25-2009, 03:22 AM | #326 |
Re: What did you do to your truck today?
Drove the beast to work in the AM. came home in the dark and lost both the low beams. People really like the high beams, i know cause they flashed their lights at me, a lot! Got home and checked the dimmer switch and all is ok, so in the AM I will start the wire tracing. This ought to be fun.
11-25-2009, 11:48 AM | #327 |
Sunburst C10!!!
wow your first post
you will like it here lots of good information i hope you figure out your lights
Gage 1967 C10 Shortbed Stepside |
11-25-2009, 12:04 PM | #328 |
NelsonMahrt:
Welcome to the forums from Kansas City, KS. Don't forget to post some pictures of your rig or the "polaroid police", aka Joe, with issue you a ticket. Enjoy the ride...this site is the foremost location for all things '60-'66 Chevy truck related. P.S. - you look very young in your avatar photo to be posting on the internet...you must be a child prodigy! Last edited by LILRED66; 11-25-2009 at 12:05 PM. |
11-25-2009, 12:09 PM | #329 |
Sunburst C10!!!
11-25-2009, 12:43 PM | #330 | |
Rods
Just keepin it simple. 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
11-25-2009, 01:36 PM | #331 |
Thanks for the greatings! You will more than likely regreat it cause this is my first project truck and I know I will ask a ton of questions. The ride is a bomb, bad wiring, lots of body work needed, sloppy stearing, wiper that dont work and park in the up position, heated by the holes in the firewall, loud, but the good side is, it has a 350SB with a 2 speed powerglide that run, ok. I think I will try to write and photo the rebuild, but it will take some time as this and a Harley are the only transportation I have and like most of us money is tight, (girl friend, 2 dogs, a cat, and an Ex.) As far as the "child prodigy" thing goes it's just this Texas Air and lots of burbon.
11-25-2009, 01:42 PM | #332 |
Took the beast out on its maiden voyage yesterday...SWEEEEEET...lots of stuff left to d0...figure out all the vacuum lines and get it shifting properly...
Thought at first that tranny was leaking out the dust pan and was not to happy about that....BUT with a little more research i found that the oils pressure sensor wasnt screwed in tight enough and was leakin down into the pan..... BIG SIGH! We'll be drivin it daily soon.... HIGH FIVE! Jory |
11-25-2009, 03:10 PM | #333 |
Fixed the oe turn signal switch swaped out antenna, and started sanding down dash
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " Last edited by slepysal; 11-26-2009 at 01:16 AM. |
11-25-2009, 09:05 PM | #334 |
Watch out for your cornhole !
I got the 63 rear suspension all finished up today. Installed ECE shock relocator kits. Built all new brake lines for the back half of the truck.
I also rigged up a temporary fuel tank so I could start the engine. Found bad deal. When I assembled the new engine into the truck, I forgot to change the throwout bearing. The original throwout bearing was the long one and my new clutch needs the short one. So, my clutch is stuck disengaged. Friday I will have to pull the trans and swap the bearing to the right one.
11-26-2009, 12:15 AM | #335 |
HOW long until spring??
UPS guy came bringing more parts. He always has to check out the progress as he stops here fairly often. Happy Thanksgiving everybody!!
69 chevelle convertible 71-C-10 short-wide and low 64 C-10 custom shortbox "Bubba"s Recycling project" |
11-26-2009, 01:11 AM | #336 |
I'm happy to see such a great response to this thread!!
Keep them coming! Happy Thanksgiving everyone!
1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
11-26-2009, 01:15 AM | #337 |
It's been almost 7 years and I finally started the old wore out bone stock 350........cough, cough.
Run it for about 20 minutes tonight and broke the cam in, motor sounds very, very, healthy. Last edited by 198plus; 12-03-2009 at 11:53 PM. |
11-26-2009, 01:35 AM | #338 |
Sunburst C10!!!
is that carb workin good
Gage 1967 C10 Shortbed Stepside Last edited by jgh64pkup; 11-26-2009 at 01:36 AM. |
11-26-2009, 01:51 AM | #339 |
Oh yea........very quick throttle response........
11-26-2009, 02:06 AM | #340 | |
60-66 Nut
My '66 C20 used to do that once in a while. A couple of the wires to the dimmer switch would burn in two. I attributed it to my typical leaky windshield dripping water onto the dimmer switch all the time. I finally got that fixed.....then the engine locked up.
11-26-2009, 05:41 AM | #341 |
Loaded Jon C's big back window cab and some other items. Headed from KC to Alabama on Thursday night/Friday morning at 1:30 am. Twenty-one hours, round trip. Should be lots of fun.
11-26-2009, 09:09 AM | #342 |
Started installing new bucket seats in my 65 SWB SS. Made seat brackets out of 11 ga. 1-1/2 square tube and 1-1/2 x 1 rectangular tubing.
Next up is retractable seat belts..... then interior paint. Happy Turkey Day Gang! (and thanks to Markeb for his internet help with the seats) |
11-26-2009, 07:26 PM | #343 |
OK here are the pics I put the bumper on painted it remounted the plate remounted the drag plate and got some 65 style caps
And my lil girl on her girly Lowrider bike...
96 Burban Sold 99 Z71 Sold 65 C10 Sold 72 C10 Sold 87 Short Bed Lowered Daily Driver http://s623.photobucket.com/albums/tt314/sswagon/ http://www.chevygmcofkc.org/forums/forum.php |
11-27-2009, 02:22 PM | #344 |
Drove the farm truck for the first time today. I still need to finish the gas tank and install the seat, bleed brakes, align the front end and install the wheels. New wheels and powdercoated grille and bumpers are going to make the difference.
MarK bed wood and strips to be here some time next week.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 11-27-2009 at 02:23 PM. |
11-27-2009, 07:04 PM | #345 |
Twenty years ago when I started goofing with old trucks, I would put Saddleman saddle blanket type seat covers on my trucks. They were very durable and lasted forever.
On this farm truck, I wanted to run one like I did back then. Everywhere I looked though, all I can find is thin versions of the old saddle blanket covers. Finally, I found a guy on ebay who makes them. I was pleasantly surprised when it arrived. It's at least the weight and thickness of the ones I bought in the 80s. The downside is that it has some funny corner flaps on the front sides of it. The girlfriend says she will sew them down for me. The seat is a 73-87 Suburban middle seat I think. It's a bit narrower than most bench seats, allowing a bit of room between the edge of the seat and the doors. I spent some time lowering the brackets even more. I like my seats real low.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 11-27-2009 at 07:06 PM. |
11-28-2009, 12:07 AM | #346 |
I changed the oil on my '46 for the first time since I've owned it. Good thing I did because it was BLACK! Whoever the A-Hole was that put the oil filter on last time put it on SO FRIGGIN TIGHT, I destroyed the filter; well, I caved it in with my filter wrench and broke the wrench in doing it! Anyway, its belly is full of nice clean oil now. NEXT...
11-28-2009, 12:35 AM | #347 | |
Senior Enthusiast
My big truck adventure today was pulling the car cover off and taking a 15 minute drive to make sure the STA-BIL got circulated up to the carb. |
11-28-2009, 02:13 AM | #348 |
I know that guy gets so much crap done i feel lazy over here lol I need to get off my @$$ and off this site that keeps me up all night!
Tx Firefighter love that Avatar
11-28-2009, 02:32 AM | #349 |
Once again, I am not able to download photos because my Sprint MiFi card can't keep the connection long enough...note to everyone, don't give Sprint a dime of your money...this and their other phone services are terrible. I can't wait to be done with my contract!
Anyway, I left Kansas City at 8:30 pm on Thanksgiving evening and drove 655 miles in 11 hours to Moulton, AL, to deliver the big back window, A/C cab to Jonathan Cross. I arrived at 7:30 am, took a few hour power-nap, drove to his place, unloaded, chatted about trucks for a while and headed back to KC. I just walked in the door at 12:00 midnight. 1,330 miles and 21.5 hours of driving in the last 27.5 hours. I should sleep good tonight. |
11-28-2009, 02:32 AM | #350 |
Brian:
Your rig is looking good. |
