Old 01-25-2014, 08:29 PM   #326
oldman3
oldman3's Avatar
Re: My version of the s10 swap
Very nice work...Jim
oldman3 is offline   Reply With Quote
Old 01-25-2014, 08:54 PM   #327
Cape Codder
Cape Codder's Avatar
Just want to say I am impressed with the fab work and the imagination to solve the problems with this swap to your advantage. Nice work.
Cape Codder is offline   Reply With Quote
Old 01-25-2014, 09:17 PM   #328
xpickup
xpickup's Avatar
BlueJeep, that should keep the dirt contained. Nice job.
Shannon
xpickup is offline   Reply With Quote
Old 02-03-2014, 12:36 AM   #329
BlueJeep
BlueJeep's Avatar
Just a little more work this week. I came up with a different solution than most for supporting the front clip. I made some outriggers to capture both ends of the grille, this ties in the strongest section of the front end securely to the radiator support. By doing this I don't feel that I need to reinstall the fender braces, and I'll re-purpose those holes for mounting the inner fenders.
Driver's side:
More to come....
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 02-09-2014, 11:52 PM   #330
BlueJeep
BlueJeep's Avatar
Now that my radiator support has more to it, I can use it to mount the front of the inner fenders.
And some bracing for the rear of the inner fenders:
My newly widened wheel tubs:
And welding more up:
A little more finish work on this one and it'll be about done, then just carbon copy it for the other side and on to the next task.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 02-10-2014, 12:05 PM   #331
99 to Life
99 to Life's Avatar
looking good
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 02-10-2014, 02:02 PM   #332
xpickup
xpickup's Avatar
BlueJeep, I can not wait to see them in the wheel well. I will look good.
Shannon
Old 02-10-2014, 02:11 PM   #333
Mater/10
Mater/10's Avatar
This Build is Awesome bud Keeper Rollin!
1964 Chevorlet Custom 10 350/350 ,ps,mb,A/c,BBW -Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=608625
1969 Chevy Nova 2 dr I6 250/powerglide
1967,68,69,70,71,72 Chevy Frankenstein
Mater/10 is offline   Reply With Quote
Old 02-11-2014, 10:05 AM   #334
skymangs
skymangs's Avatar
Awesome work man...
skymangs is offline   Reply With Quote
Old 02-16-2014, 10:56 PM   #335
BlueJeep
BlueJeep's Avatar
Finished welding up the first inner fender, and bolted it back in. Since I still have the coil spring removed I was able to cycle the upper control arm and trim as needed to get it to full stuff.
All the way down:
And all the way up:
Here's a shot looking up and back:
Here's up and forward:
And this is what I had hoped for the entire time. No longer should this truck get road grit spraying up on the cowl, fender mounting flanges, etc. I think I'll hang a little mud flap off this too, just to keep the bottom of the running boards clean as well. With all this prep, I'd better put some miles on this to make it all worthwhile....
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 02-16-2014, 11:10 PM   #336
99 to Life
99 to Life's Avatar
looks good, whats your plan to access the headlight buckets/wiring?
Old 02-16-2014, 11:34 PM   #337
BlueJeep
BlueJeep's Avatar
It'll be much easier than stock my friend! I now have access to it from the engine compartment. I have new lights for it that have the replaceable bulbs that pull out of the back, so I'll cut the backs out of the original buckets and I'll be able to reach in from the engine compartment and change them, just like on newer cars.
View from engine compartment:
Plenty of room right here for the wires to run. On the passenger side I'll route my heater and AC hoses up and over the inner fender:
And lots of room at the back to run them wherever I need/want to:
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 02-16-2014, 11:43 PM   #338
ghettoluxury
ghettoluxury's Avatar
Very nice way to fix the only real problem with this body style.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 02-16-2014, 11:45 PM   #339
99 to Life
99 to Life's Avatar
aiight, yeah those pics help me out. should be a nice set up then. good work.
Old 02-17-2014, 12:34 AM   #340
oldman3
oldman3's Avatar
Really like what you did, nice job...Jim
Old 02-20-2014, 09:23 PM   #341
BlueJeep
BlueJeep's Avatar
Here's the plan for the ECM. This will go between the new inner fender and the firewall on the driver's side. Just need to pull out the wiring harness and make sure it's long enough before I mount it solid.
s10 ECM bracket part 15995679
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 02-20-2014, 09:26 PM   #342
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Very nice work, love the tubs.
--Josh
Old 02-23-2014, 01:40 AM   #343
BlueJeep
BlueJeep's Avatar
2nd side is far easier and quicker than the first. I hope to finish it up tomorrow so that I can move on to other things.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 02-23-2014, 01:44 AM   #344
99 to Life
99 to Life's Avatar
nice work, 2nd time around yeah always nicer aint it!!
Old 03-02-2014, 10:40 PM   #345
BlueJeep
BlueJeep's Avatar
Now that I'm over my cold, I was able to get something done. Inner fender is now in. Now there is plenty of room for the A/C compressor.
Now I have to find room for the battery here:
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 03-03-2014, 12:13 AM   #346
skymangs
skymangs's Avatar
Damn that's nice looking work!
Old 03-04-2014, 11:48 PM   #347
BlueJeep
BlueJeep's Avatar
It feels so good to be working on something other than inner fenders for a change.
Next up is figuring out where I want to mount the A/C. I need to make sure my cowl vent still functions, the wipers have room to work, and I can get at the bolts that hold the hood hinge on. Shouldn't be too tough. There really isn't any reason to not mount it up close to the firewall, so I'm going to go as close as I can. There also really doesn't need to be anything but wipers above it.
I think this is getting pretty close:
Also, I think I'll be re-using the OEM metal defroster ducts. I'll have to expand them from 1.75" to 2" but that isn't a big deal. They have a more favorable angle than the Vintage Air ones for tucking the unit up high, plus they're not cheesy plastic.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 03-05-2014, 12:23 AM   #348
oldman3
oldman3's Avatar
bluejeep, I used my original def. vents also with my VA system, gives you room for other stuff...Jim
Old 03-05-2014, 12:39 PM   #349
99 to Life
99 to Life's Avatar
cool you'll be keeping cool. I won't be!!!
Old 03-05-2014, 08:20 PM   #350
BlueJeep
BlueJeep's Avatar
What did you do to bump the diameter up to 2"?
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
