Old 05-15-2011, 12:53 PM   #326
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Project -underfunded - '68 shortstep/carb'd LSx/200-4r build
you're going to need to put a posi or locker in that rear axle if you want to get the most out of it. peg-leg is only for stockers.....
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-15-2011, 04:28 PM   #327
85burb
85burb's Avatar
I have a detroit truetrac sitting in my closet for it. I think i really need to put it in cause when i stop then take off at a light something makes loud pop noise and i have changed trans, engine, engine mounts, hole rear breaks and none of it has helped the noise. My dad had same noise and it was his diff. I have it for sale in parts section but if no one buys it i will have it installed buy a shop here cause i dont want to mess it up. I have never done one and dont want to learn on my daily driver. I even have master install kit. One day....one day.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 05-15-2011, 05:06 PM   #328
68GMCCustom
That will get you hooking a bit better. I need more tire with a stickier compound. I'm getting to where I don't want anyone to touch my truck but me. Then if I have a problem I can only blame myself. If I can't build it then I'll r/r it...which is what happen with my torque converter.
Kurt -
Old 05-15-2011, 05:12 PM   #329
85burb
85burb's Avatar
I hear you on the no one touch it. I just had mine inspected and was very nervous the hole time. Deff no one on yours. Mine will hook most of time but i am sure yours wont as good. All it takes is one stupid person to goose it and there it goes smooth into a wall side ways. I like working on mine my self but will never do a trans or diff. That is way to easy to jack up. I am allison certifyed and still dont want to ever go into one. I took converter apart other day at work and tryed my hardes to find something wronge with it so i did not have to reseal it. I found the thing was trash and it was cheaper to buy reman trans then rebuild the converter.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-11-2011, 11:25 PM   #330
Chevy4Life
Chevy4Life's Avatar
How bad was the fit of the truck manifolds? Could they be made to fit with more grinding or notching the frame? Did they fit better in the I6 or V8 position? I'm dropping in the LSx tomorrow and I'm really hoping to make them work.
THANKS!
Jay
Chevy4Life is offline   Reply With Quote
Old 06-12-2011, 10:36 PM   #331
68GMCCustom
Oh you can make them work...and the farther back the better.
Kurt -
Old 06-12-2011, 11:12 PM   #332
Chevy4Life
Chevy4Life's Avatar
Thanks. today was a long day of cutting and welding. We modified the I6 stands a lot.
Old 06-13-2011, 12:32 PM   #333
68GMCCustom
anything to help out another enthusiast. I'll have to check your build!
Kurt -
Old 08-26-2011, 12:23 PM   #334
68GMCCustom
finally got around to ordering some more parts Wed. night to "fine tune" the truck a bit. Ordered some new 15X10" truck rallys, MT ET Street d/r's (traction was major issue), some .025" longer p-rods (oops), a 1" open and 1" 4 hole spacer to test with, Holley 50cc pump upgrade (will require a 1/2"-1" carb spacer anyway), and a couple hundred dollars worth of other Holley parts (air bleeds, jets, adj. linkage for the secondaries, secondary adj. idle bracket, etc) to fine tune my trucks Holley HP Street 750.
I'm thinking cost wise... I'd have been better off just ordering a custom built carb in the 1st place.
Shipped ground and still looks like most of it will be here tomorrow! Thanks Summit! If this 100*+ heat would let up for a few days I could even go out and work on it and take it out and baseline it at the track! Hopefully soon I'll have some et numbers for it.
Kurt -
Old 08-26-2011, 11:29 PM   #335
85burb
85burb's Avatar
I figured it would be best to start with a custom after playing with mine for a bit and reading up on them. All the little parts add up after a while. Glade to see you back over here!
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 08-30-2011, 11:23 PM   #336
68GMCCustom
well....traction issue is resolved. I think.
should be on the truck tomorrow.
Kurt -
Old 08-30-2011, 11:32 PM   #337
85burb
85burb's Avatar
Those look sweet. Now you may need a wheeli bar....
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 08-31-2011, 12:20 AM   #338
mcbassin
Still Learning
mcbassin's Avatar
Great looking ralleys and tires! Can't wait to see your numbers.
mcbassin is offline   Reply With Quote
Old 08-31-2011, 12:45 AM   #339
matthew20061
69' Chevy Stepside
matthew20061's Avatar
That will fix that problem!!! Mine needs the same thing! Looks awesome.
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 08-31-2011, 11:06 AM   #340
68GMCCustom
Thanks guys. Yes they are soft and sticky.....hopefully they bite with no more tire spinning!
getting ready to pull the carb apart, swap out the p-rods, and get it ready for the track...well, and the night drive back home.
Kurt -
Old 08-31-2011, 07:35 PM   #341
85burb
85burb's Avatar
It looks like you got a busy day!
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 08-31-2011, 09:09 PM   #342
68GMCCustom
Well.....kind of like when I'm really hungry...and I order too much food...that illustrates my wheel/tire purchase I think. They are a BIG. Traction shouldn't be an issue though! They fit....though that's a relative term. They stick out like 33's on a stock height 2WD mud truck. pics later
got the carb back together with several mods. I also noticed upon inspection that I had been running the transition slots exposed...ooops....so I pulled the idle adj. back and verified both sides were covered up as they should be. I changed pri (-2)/sec(-1) jets, upgraded pri. 30cc to 50cc accel. pump, added an adj. sec. linkage and an adj. sec idle bracket, swapped out old carb studs for new longer carb studs to add a 1" spacer (at least 1/2" needed to clear bigger accel. pump & arm) and got it back on. Figure I'd made enough changes already so I'll screw with the air bleeds if needed with it back on the motor.
About to tackle the p-rods...maybe some wiring...or not. Might just grab a bowl of ice cream and start again tomorrow.
Kurt -
Old 08-31-2011, 09:45 PM   #343
85burb
85burb's Avatar
Sounds like time for icecream and push rods. I used to eat lunch when working at ford. The customers would look at me funny when i was taking drian plug out and eating sandwich at same time. I hope all these mods work good and you get to test the grip of them rubbers.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 09-27-2011, 10:54 PM   #344
68GMCCustom
well I still haven't made it to the track yet do ton trans issues. So, today I bought a TCI super servo kit for it to hopefully stiffen the 2-3 shift, 1-2 is fine but harder would be OK there too. Also bought a Hughes aluminum pan for it, and another rear seal. It leaks in a couple of places....after replacing gaskets and seals once (or twice?) already.
If I can't get it to seal up this time and not leak....and the servo doesn't help 3rd enough to race it...I guess I'm sidelined (for racing) until I buy a better built 200-4r...like the art carr 500-750hp version I think since TCI doesn't make a super street fighter (for >450hp) in a 200-4r.
Anyway....with any luck I should have some time slips from at least the 1/8mi track...and hopefully soon after one of the 1/4mi.
Kurt -
Old 09-27-2011, 11:11 PM   #345
85burb
85burb's Avatar
What about goodguys this weekend? I may drive my burb up there.
I am looking at upgrading to a 4l80e. Trans may be starting to slip. The wife says she felt it slip so....looks like its time to look in to it atleast. Hope you make it to goodguys i want to see the truck in person.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 09-28-2011, 12:24 PM   #346
68GMCCustom
well....my family scheduled a get together in remembrance of my grandfather, and to remove things from the ranch. I'll wind up busy with that al weekend. On one hand its something I need to do...on the other hand considering I'm getting everything in I need to stop the trans leaks tomorrow, and will likely use the truck to haul things this weekend.... missing GG is killing me.
Oh well....I'll have all the bugs worked out and ready by spring?
Kurt -
Old 09-28-2011, 03:10 PM   #347
85burb
85burb's Avatar
Dang it. At least there is two of them a year here.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-06-2011, 11:36 PM   #348
68GMCCustom
installed new Hughes deep aluminum trans pan today w/filter and gasket. also installed a new (again) rear seal. hopefully this buttons up all the leaks.
servo/pin kit comes tomorrow! then with any luck I'll get it to the track sometime this weekend for a few runs to establish a base line... since I know there will be more changes.
Kurt -
Old 10-29-2011, 10:15 PM   #349
68GMCCustom
okay....finally made it to the local 1/8mi track. Only got in 2 runs but it gives me a starting point at least. managed some 8's with trans troubles and all. Seems to be sticking halfway decent. I feel confident with some carb tweaking, timing map adjustments, a new trans/converter (mine leaks, slips, and shifts way too early) some more runs to dial it in....and better numbers should be in its future next spring. Maybe high 7's if I'm lucky?
1st run - slow out, shifted 1-2 early - 8.63@81.71 w/1.97 60'
2nd and best run - better out, shifter 1-2 higher but still early - 8.46@82.80 w/1.944 60'
it hits 3rd right at the finish line
car# 5
Kurt -
Old 10-29-2011, 11:26 PM   #350
matthew20061
69' Chevy Stepside
Very nice! I'm not sure familiar with 1/8 mile but it sounds pretty good.
-Matthew
