#326 |
Re: Barn raising
I am so down to run down to L.A. with that kind of foloowing I need a real road test for my truck anyway it's kinda stuck to local events the past few years so I think that would be an awesome test and always a great place to grab some ideas ;D Awesome hinges gotta love handbuilt Fab work
![]() Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
#327 |
Re: Barn raising
Lookin sweet dude killer job on the motor and hinges. Let me know if you need a hand with anything.
#328 | |
![]() Join Date: Apr 2008
Re: Barn raising
You know I thought of you when I was trying to find an extra hand for the hood install but then my neighbor came home. I sure I will need an extra hand soon. Thanks for being available.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
#329 |
She's Alive!
For those of you still subscribing to my slow as molasses engine rebuild, I fired it up today, Still got the same gas in it from the Brothers show and shine last year. I thought about draining it and putting new in but I figured what the heck I just try it.
It took about 10 minutes to get the carb primed because the line was dry all the way back to the tank but she fired up and I ran it for the recommended 20 min at 2000 rpm while I checked for leaks. There was a small one on the fuel line, another one on the oil pressure line, Trans cooler had a steady drip and the P.S. pump almost ran dry as it pumped all the reservoir into the empty rack and cooler lines. After 8 months I figured I was bound to forget to tighten something. The good news is the most everything was small and easily tightened. Some I just let leak while I kept the engine running because I did not want to get my hands near the fan. I did not put any antifreeze in it for the first fire so I could check for leaks with just water. After a few laps around the block I will drain it and put the real coolant in. I will post a video of it running in the next day or so, work is busy now, and I am really kind of surprised that I was able to get a few hours to attempt the start up tonight.
#330 |
Re: Barn raising
project: "my happy mess" |
#331 |
Re: Barn raising
rock on man
#332 |
Re: Barn raising
Hurray! Always a good feeling. Congrats!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#333 |
Re: Barn raising
That's good stuff. Congrats on the milestone.
1969 C10 SWB Project Charity Case AKA "Roscoe" 1971 Cheyenne Super A Combined Effort The Service Station-A practical ministry for those in need |
#334 |
Re: Barn raising
I'll never forget the first time I fired up my BB 402 in my chevelle after doing a top-end rebuild in my parent's garage when I was 17... I had just put headers on and had no exhaust pipes. That thing sounded mean! It's a great feeling to see it run after so much work.
1968 LWB C20 / AC / Wood Bed |
#335 |
GEARHEAD
Re: Barn raising
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#336 |
Re: Barn raising
Congrats on the fire up buddy now... a burnout video
#337 |
Re: Barn raising
The heart is always in the throat when it first fires up "congrats"
94 k2500 EXCab Long Bed 350ci New Toy 95 K2500 Suburban New PlowTruck 454ci Support our Troops @ http://anyairman.com http://www.woundedwarriorproject.org/ |
#338 |
Re: Barn raising
Well my heart was not in my throat until this morning, I had a bit of trouble today, sadly I am not sure of the condition of my newly rebuilt 700r4. I had it rebuilt in 09 and it sat in my garage for three years while I waited for an opportunity to upgrade the transmission from the fairly reliable TH400. After I got all the fluid levels toped off I shifted the tranny into reverse to back out of my drive to take it for a lap around the block. No reverse at all, I have forward drive gears but no reverse. Bummer, I am towing it to a tranny shop on Tuesday for them to diagnose. Hopefully it is just a stuck valve but I fear that it will have more serious issues than that. I do not think I can or want to take it back to the shop that did the first rebuild because I am starting to not trust their workmanship.
#339 |
Re: Barn raising
Hey!
I just noticed my build got a five star rating! cool thanks guys, just learning as I go.
#340 | |
Re: Barn raising
#341 |
Re: Barn raising
Ok here is a little video of my engine running (sorry it is a phone video, my wife took the video camera to palm springs for the weekend), and how the new cam sounds. Other than the annoying rattle of the stupid air cleaner half way through that sounds like a frog, I think it sounds tons better than it did a year ago.
One thing I did point out in the video for you guys smarter than me regarding engines, when I start it I get a normal oil pressure level at idle, then when I throttle up it spikes. This is a new oil pump not the old one. I did install a larger diameter braided line in the engine compartment but then it reduces to the original size when it goes through the firewall. Could that larger size be the culprit? Or could it be that there is air in the line causing the bubble to give a false read. Not sure if I should be concerned about this or not. ![]()
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 Last edited by Mike Bradbury; 05-20-2012 at 05:25 PM. |
#342 |
GEARHEAD
Re: Barn raising
Sounds good. Looks like the gauge is working normal, the line size or even air bubbles should not change the reading, it is a closed system and all parts of it will feel the same pressure. The difference may be that the output pressure of the new pump is much higher and you have a standard oil pressure gauge. There are OEM oil pressure gauges that are rated for higher pressure. I think standard is a 0-60 psi and the other is 0-80 psi. It says on the gauge if you take it out of the bezel. Most high flow or high press oil pumps will go to 80 or more, especially on a cold engine.
#343 |
Re: Barn raising
Yeah when I put the tach in I think it was a 60 psi gauge if I remember. Maybe I will pick up a numerical gauge and see what it is pumping
#344 |
GM Addicted
Re: Barn raising
Hope its something small on your transmission man. Engine looks good. Going too see you at brothers this year for sure??
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
#345 |
Re: Barn raising
Oh yeah I'm still going, but I too hope it is something small, I have spent enough on this truck already
#346 |
Re: Barn raising
Ok,
well the damage on the stupid tranny cost me $700! trying to save money and go with a local guy to rebuild it, ended up costing me a ton of money. Turns out there was some sort of shim or bushing that was too big and was preventing the reverse from engaging. Had to yank it out and re build it again. This time a guy I trusted and came highly recommended. In the end it all worked out and it is working fine now. I took it to the local street show tonight for its maiden voyage. On the freeway I am turning around 2000 rpm at 70 mph. I am curious to see what my gas mileage will be. Now for you Mustang rack and pinion converts; Did you notice a loss of turning radius? I thought I was going to be ahead of the game by being able to turn faster since the Mustang rack had One less turn lock to lock. The Chevy box was 3.5 lock to lock and the stang is 2.5 Turns out it is the same ratio just one half less turn in either direction. I think that the turning arms on the spindles is shorter on the mustang so it pick up the 1/2 turn in the shorter arm. I am bummed about that to the point I might just yank the entire system out and go back to stock if this is as good as it is going to get.
#347 |
GEARHEAD
Re: Barn raising
Mixed message there. Congrats on getting it back on the road. Sorry to hear the disatisfaction with the steering. I guess you could swap out the front suspension for the mustang style or maybe you can replace the rack with one that has the longer throw, like what no limits sells. Might bolt right in with the mods you made to fit this one. He might be using a variant of the chevy truck rack.
#348 |
GM Addicted
Re: Barn raising
Glad too hear the beast is on the road.
#349 |
Re: Barn raising
Well I just read the entire thresd, you are an awesome fabricator the work is supper. I would like to hank Josh for stepping in as the pool was turning an ugly shade of yellow. there is more todo and I will gladly watch. I do agree with other members that some of this stuff you should either make or have made to sell, I think the monetary rewards would be high and that is my 2 cents worth
#350 |
Re: Barn raising
Thanks Tink for the kind words, I do love to fabricate but the rest of the story is my better half
![]() This truck started out as a fun project that I could play around on an occasional weekend. Ha it has turned into an up at all hours fourth job. I already have three jobs that take most of my time, now that I am done with Phase II for the most part I will be making a concerted effort to focus on my "tryingtobepatient" wife. As I have said, This truck is my therapy, if I had to do it for a job it would not be very therapeutic. The better reward for me is to see you guys like an idea and copy it, I am a teacher afterall.
