Old 06-23-2013, 10:39 PM   #326
williamsboys
williamsboys's Avatar
Re: 66 c10 first timer build
Went to the salvage yard today and got a grill support that was in better shape then mine. Also I wanting to get power steering stuff, I found a bunch of the power steering pumps but not very many reservoirs with only a v belt pully. I also meet to get that bracket from captainfab. Which set up would be better for my application or are they all pretty much the same?
http://
http://
Williamsboy
williamsboys is offline   Reply With Quote
Old 06-24-2013, 07:12 PM   #327
williamsboys
Which power steering setup would work better on my motor? Any suggestions?
Williamsboy
Old 06-24-2013, 08:39 PM   #328
Bomp
Bomp's Avatar
The one for the v8 but your running a serpentine belt. There might be some differences to look into.
Bomp is offline   Reply With Quote
Old 06-24-2013, 10:03 PM   #329
williamsboys
Well with the Gilmer drive set up it has a spot for a v belt on the bottom pully to go to a power steering resivior. So do I just get any set up that has a v groove pully then just get the correctmounting bracket? Are the puns about al the same too iike 70-87 chevys or so.
http://
You can see the groove for the belt on this pic.
Williamsboy
Old 06-24-2013, 10:05 PM   #330
williamsboys
Also shout out to captian fab. Do have the mounting bracket I need for the pump to the frame ? If so will message me about it so I can get one from ya?
Williamsboy
Old 06-25-2013, 08:36 PM   #331
Bomp
Bomp's Avatar
If you mount the power steering pump up to the block and the pulley lines up with the crank groove I don't see any problem. The pump should be adjustable to tighten the belt.
Like that crank pulley.
Old 06-25-2013, 09:20 PM   #332
williamsboys
Yea that's what I was thinking.
Williamsboy
Old 06-30-2013, 01:05 PM   #333
williamsboys
Do yall just order a new mounting bra key for the pump to the frame or doesn't captain fab sale them?
Williamsboy
Old 07-04-2013, 10:44 AM   #334
williamsboys
So I finally got brothers to send me the correct nuts for my inner tie rods. But when I took one side off to put the new nut on it by the sleeve but when I went to put the nut on the end that goes threw the steering cross bar or what ever it's called. But here's ny problem, bothr tie rods turn when I'm trying to take the not off one side and put it on Tue other side. There brand new, well never been driven. Bought new.any suggestions on what to do in this situation? Thanks
Williamsboy
Old 07-04-2013, 11:39 AM   #335
chad64chevy
chad64chevy's Avatar
I bought an after market power steering bracket for mine, I also have the gilmer belt drive like you have! do you have a long water pump or a short water pump? thats what kind of brackets you will have to buy, I went with a key way pump cause I found the aftermarket v groove pulley was cheap then the press fit
chad64chevy is offline   Reply With Quote
Old 07-04-2013, 11:51 AM   #336
williamsboys
Awesome chad thanks.
Williamsboy
Old 07-04-2013, 12:16 PM   #337
williamsboys
The threads look a little damaged at the beginning I think I'm going to cut the one nut off so I will have both tie rods off the truck and try rethreading them.
Williamsboy
Old 07-04-2013, 02:01 PM   #338
williamsboys
I got it.
Williamsboy
Old 09-02-2013, 08:59 PM   #339
williamsboys
Could I get some pics of exhaust routing with a fuel tank in the back. Really would apriciate it. Thanks
Williamsboy
Old 09-02-2013, 09:04 PM   #340
pimpston65
pimpston65's Avatar
Originally Posted by williamsboys View Post
put on the new disk brake kit and cleaned up a arms and repainted them, but now im probly gana take it all back off. i would like to get the frame powder coated, any one knows what that runs?[IMG][/IMG][IMG][/IMG][IMG][/IMG]
here is where we are on taking the motor out and putting in the new one [IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG]
save every piece of that truck and start buying parts now cuz its getting harder to find them at a cheap price also educated urself of workings cuz some parts can be tricky getn off and on while building and pack ur patience
pimpston65 is offline   Reply With Quote
Old 09-02-2013, 09:42 PM   #341
williamsboys
Ok. I've saved every thing put all little parts in labeled bags too. Thanks for the advise.
Williamsboy
Old 09-02-2013, 10:02 PM   #342
Jeff La
Looks like ya'll been busy, good job
Jeff La is offline   Reply With Quote
Old 09-11-2013, 07:40 PM   #343
williamsboys
Well I got 2 more pieces to this money hungry puzzle. Hooker headers
http://
http://
http://
http://
Williamsboy
Old 09-11-2013, 07:43 PM   #344
williamsboys
I need to get some different plug wires though. In some spots the wires are right up against the headers. Next I'm getting the electric cutouts. Should be Awesome. It will be nice to just flip a switch and go to the gnarly roar of open headers.
Williamsboy
Old 09-12-2013, 07:43 PM   #345
pimpston65
pimpston65's Avatar
looks like your well on ur way, nice job on the exhaust cutouts love em to scare folks with just a flip of the switch!!!!
Old 09-12-2013, 08:28 PM   #346
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
That thing looks cool! Nice 8 you got for it.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 09-12-2013, 08:47 PM   #347
williamsboys
Thanks guys!
Williamsboy
Old 09-12-2013, 10:19 PM   #348
pimpston65
pimpston65's Avatar
http://
http://
http://
http://
quick question i noticed you didnt have a shifter, where u gonna mount the bracket for the shifter ?
Old 09-12-2013, 10:24 PM   #349
williamsboys
Learning as I go but I'm going with a new steering column shift so I guess I'll get what I need from there unless you know somethen that could help me out. Like I said just learning as I go.
Williamsboy
Old 10-13-2013, 12:01 PM   #350
williamsboys
Went cruisen the coast in biloxi this weekend and got some prettys! Oil dipstick to match trans dipstick, air breather, valve covers and the little breathers for the valve covers. Still need to do a little polishing but just wanted to share.
http://
http://
http://
Williamsboy
