Old 09-11-2014, 09:56 PM   #326
msgross
msgross's Avatar
Re: Project "Shifted"
very cool project, good luck if you do go through with a sale...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 09-18-2014, 04:36 AM   #327
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
In my sleep deprived and caffeine driven trolling of the board tonight (this thread specifically) I think there needs to be a conversation about sending Shiro down the road and dragging this one to Niceville. I'll give you a shout.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 09-18-2014, 07:59 AM   #328
jmedero
jmedero's Avatar
That actually makes a ton of sense.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 09-19-2014, 07:34 AM   #329
Coursey
Coursey's Avatar
Do you have a run down of what all needs to be finished?
Coursey is offline   Reply With Quote
Old 10-21-2014, 09:19 AM   #330
Hart_Rod
Hart_Rod's Avatar
I've had a lot of interest, but no $$$$$$...... So I decided to make me a list of what I need to do to finish the project up. I tried to be as specific as I could, but will add more as I get back into it. As all of you know, it's the little details that add to the time and the money on finishing one of these projects....
Shifted do list: (UPDDATED 15DEC2015)
Chassis:
Grease front ball joints/install cotter keys
Bolt on front and rear bumpers
Mount F/R Accuair level sensors DONE!
Paint Borgeson steering joints and rod DONE!
Mount bumpers
Paint rear bumper white DONE!
Brakes:
Run line from rear to master cylinder/ weld tab for rear line DONE!
Run line from front to mastery cylinder DONE!
Bleed brakes
Motor:
Change oil and oil filter
Install oil pressure sending unit
Plug in EFI Harness (connect power wire/mount fuse block)
Connect PS hoses (made)
Connect radiator hoses (purchased)/hose clamps
Connect steam hose to radiator (purchased)
Install air filter/MAF (purchased)
Connect throttle/cruise control cable (purchased)
Mount battery
Install exhaust/ Flowmaster mufflers (purchased)
Transmission:
Install transmission fittings
Run transmission lines to radiator
Change fluid and filter
Mount Lokar dipstick (purchased)
Install Lokar shift linkage to column (purchased)
Body:
Install the new core support (purchased)DONE!
Drill holes in core support for Vintage AC DONE!
Paint radiator cover black and attach SS plate (purchased)
Modify fenders for Hill’s tubs (purchased)DONE!
Fiberglass, liner and paint tubs
PB hinges DONE!
Mount custom ECM bracket (purchased)
Repaint firewall black (original green??)
Bed:
Build bed frame (1” square tubing purchased) to raise bed floor DONE!
Order complete bed kit with stainless strips from Mar-K DONE!
Shorten wheel tubsDONE!
Modify bed sides to lower bed DONE!
Paint bed DONE!
Interior:
Install AAW body electric harness (Purchsed)DONE!
Wire Dakota Digital gauges (purchased)
Mount evaporator/ cut holes for AC vents
Wire AC
Reupholster seats with Highlander plaidDONE!
Install Buddy bucket seats (purchased)
Install gas pedal and Lokar cables DONEDONE!
Paint Flaming River stainless steel steering column (purchased)
Install fatmat DONE!
Install floormat/carpet
Air Ride: (Accuair)
Mount tank/compressor/manifold (Accuair EXO mount) (purchased)DONE!
Mount level sensors with aluminum collars DONEDONE!
Connect wiring kit (purchased)
Electrical:
Install AAW interior electric harness (purchased)
Wire A/C
Mount EFI fuse panel (underhood) (purchased)
Mount ECM (underhood) (purchased)
Connect in-tank fuel pump to EFI harness (purchased)
Connect Entropy dual electric fans to EFI harness (purchased)
Hart_Rod is offline   Reply With Quote
Old 10-21-2014, 09:34 PM   #331
C10_ustacould
"...or PB hinges"
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 11-02-2014, 01:38 PM   #332
Hart_Rod
Hart_Rod's Avatar
Made a little progress over the last week. The first thing I did before jumping back on this project was to get my garage somewhat organized. I think that might have been one of the reasons I was dragging my feat on this thing. Once I got that done, I was able to finish the power steering lines for the rack and pinion (thanks Buck) and I cut out all of the holes for the AC vents (Vintage Air). Not big steps, but working on these projects is like eating an elephant, the only way to do it is one bite at a time.......
Old 11-06-2014, 02:36 PM   #333
Hart_Rod
Hart_Rod's Avatar
Moved on to mounting the Accuair level sensors. With the help of the board, I think I have the fronts figured out. I'm hoping the rear should be fairly simple also....
Old 11-06-2014, 07:02 PM   #334
harleyhouser
harleyhouser's Avatar
good looking build, I sure hope you continue on. I seen earlier in the build where you was raised in Smithville, I am born and raised in Valliant, OK its about 30 miles west of Broken Bow. I am currently in the process of a frame off build on a 72 short wide. Keep up the good work.
harleyhouser is offline   Reply With Quote
Old 11-06-2014, 07:29 PM   #335
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Looking great Rob,
hopefully progress helps rekindle a desire to finish and drive this thing..
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 11-06-2014, 10:29 PM   #336
Hart_Rod
Hart_Rod's Avatar
Thanks! When did you graduate? I went to Smithville High School from 83-87. We used to play Valliant in basketball, they always had good teams. I used to have some friends that worked at the paper mill. Looking forward to seeing some pictures of your truck.
Rob
Originally Posted by Twisted78SS View Post
Looking great Rob,
Thanks! Getting my garage organized and making a to-do list really helped.
Old 11-06-2014, 11:29 PM   #337
harleyhouser
I graduated in 94. I plan on making a build thread when I get further along. I just took the frame to the sandblaster today gonna be a long night tomorrow night applying POR-15
Old 11-25-2014, 01:15 PM   #338
Coursey
Coursey's Avatar
Updates?
Old 11-25-2014, 01:23 PM   #339
Hart_Rod
Hart_Rod's Avatar
Originally Posted by Coursey View Post
Updates?
Currently working on mounting the rear level sensors. I plan on working on the bed over the holidays.
Old 12-14-2014, 12:52 PM   #340
Hart_Rod
Hart_Rod's Avatar
Worked on the bed some this weekend. Pics...
Old 12-14-2014, 02:00 PM   #341
DKclassis72
sweet build man! question for you... what hose kit did you buy for your power steering hook up? I have the corvette style accessory drive on the front of my motor as well.
DKclassis72 is offline   Reply With Quote
Old 12-14-2014, 04:48 PM   #342
Hart_Rod
Hart_Rod's Avatar
It's a Russell setup. You can get the fittings and line from Summit or Jegs.
Old 12-14-2014, 09:15 PM   #343
nlped
nlped's Avatar
I just read the whole thread... Don't sell it!!! It's so close! If you're burned out, reread this thread and look at what all you've accomplished. I'm going to be watching.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 12-14-2014, 10:11 PM   #344
Number98
Prestige Worldwide
Number98's Avatar
Those Vintecs shore look sweet under this truck Rob!
Number98 is offline   Reply With Quote
Old 12-26-2014, 10:04 PM   #345
Hart_Rod
Hart_Rod's Avatar
Making a little more progress. I finally have both bed sides cut. So tomorrow, I'm going to try to get it back on the ground to see what it looks like laid out.
Old 12-26-2014, 11:33 PM   #346
jmedero
jmedero's Avatar
Sell them all and get a KIA!!! Lol
Always nerve wrecking cutting up those nice new bed sides.
Old 12-28-2014, 12:17 AM   #347
Bowtie468
Bowtie468's Avatar
Looking great Rob !!
Chris
click here to see my buildpage
http://67-72chevytrucks.com/vboard/s...d.php?t=394656
1979 C10 Silverado Big10 SWB
Factory 454/400
Cardinal Red/Santa Fe Tan (original paint)
1969 Camaro X44 LS swap
1968 C10 SWB Fleetside (SOLD)
468BBC MultiPort TPI / Dynamic EFI P4
Black/Black
1963 Nova SS convertible (SOLD)
194 I6/ PowerGlide
Bowtie468 is offline   Reply With Quote
Old 12-28-2014, 12:19 PM   #348
67ChevyRedneck
67ChevyRedneck's Avatar
Originally Posted by Hart_Rod View Post
Making a little more progress. I finally have both bed sides cut. So tomorrow, I'm going to try to get it back on the ground tomorrow to see what it looks like laid out.
It's past "tomorrow"... how's she look?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-29-2014, 12:49 PM   #349
Hart_Rod
Hart_Rod's Avatar
Working on it...I prefer it over cutting up rusty stuff...
Thanks Chris!
As requested....
Old 12-29-2014, 01:02 PM   #350
slowcpe
slowcpe's Avatar
sweet!
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
