Re: Used Parts Build
This was my weekend.
![]() ![]() I'll post up a bunch of pics tomorrow. I'm beat.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
Here are the pics and write up from this weekend: http://www.67-72chevytrucks.com/vboa...d.php?t=713378
Got this on Friday
![]() They have a 30 day rent back. So I wont be moving in for a month. Which also means I need to get my truck a roller in 30 days.
Got my bed assembled and on the truck
![]() ![]() Started making the mounts ![]() Lots of props and clamps ![]() ![]() ![]() ![]() Got four done before it got too dark and ran out of steel.
Looking great man!
83 Crew Dually build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=686192 Instagram: lofab77 |
nice work.
![]() Join Date: Aug 2013
congrats on the house...nice work
Congrats on the house.
remind me...you cut down a long bed right? Are you not cutting the 6" off of the back of the bed?
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
Thanks guys. I cut down a long bed but took all 20 inches from the front and left the rear long.
Making more mounts
![]() ![]() The idea ![]() Cut. The other pieces are to support the 4 link crossmember. ![]() Holes drilled ![]() Bought a new tool. Need to weld some braces to it and build a stand
SWEET!
Reinforce the frame (the arms want to splay) Also make a wheel for it, instead of a crank. I bent 1" 16ga tubing around an S10 rim, and made spokes out of 3/4". Steering wheels work well too. ![]() ![]() Got a skateboard wheel? I made a tipping wheel with a Princess Auto (Harbor Freight) sprocket with the teeth ground off.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
#12 | |
![]() started bracing it. Need to get a steering wheel still. Good idea for the tipping wheel. Do you know anyone who makes extra dies for it?
#13 |
Filled a bunch of holes on my tailgate:
![]() Got my bed mounts done: ![]() Bed is all bolted on and together. Made some shims to get it to the proper height. Didn't get any pics though. Then this happened: ![]() Grinding some metal and had a bit get behind my safety glasses. By the way they use a bur to remove the rust ring that forms where the metal was.
#14 |
Been trying to get the truck together enough to tow it to my new place.
![]() And I had to puppy sit this guy again ![]() Anyway, on to the truck stuff. Got my steering all together. ![]() I went to put a set of wheels on that I got as take offs from the Cannonball C10 but they were too wide and the backspacing wouldn't let me even get the wheel on the lugs. I pulled a wheel off my 66 just to give me an idea of what wheels I can run. I am probably going to get some inexpensive steel ones just to get me rolling. ![]() ![]() These wheels are 205/60/15 so they are only 26''. I am probably going to run a 235/65/17 to give me a 30'' tire (which I should lay out on).
#15 |
I'm just glad to be here!
Congrats on the new place!
I have been to the eye doctor to many times for my own good to get metal and rust out of my eye. Its not real fun, but the tools are cool!
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#16 |
I know the pieces fit
I had a co-worker once that had previously worked as a welder, he said he got stuff in his eyes pretty often. He said they'd put a Q-tip gently against the eye next to the metal and twist it slowly, the fuzz would grab the metal and pull it out. It's no substitute for professional medical treatment, but might help in a pinch. Congrats on the house.
#17 |
I had my right eye removed. Now I am 50% less likely to get metal in my eye.
Because of that, I wear glasses with the foam around them to make a good seal and also use a shield whenever possible. When you only have one left you need to take care of it.
#18 |
Doc let you have the 8-ball eye?
#19 |
I hope he does. I get the new eye on the 12th.
#20 | ||||
That would be pretty damn cool.
#21 |
I think Eastwood sells fancy dies for the same machine. The dies yours and mine come with are really just for rolling beads. Eastwood has fancier.
I have a lathe, so I tend to make my own
#22 |
I epoxy coated my garage floor last night: http://www.67-72chevytrucks.com/vboa...d.php?t=716686
#23 |
Sweet build and very informative! I'm anxious for you to start on your 66. I have a 63 I need ideas for.
#24 |
Thanks. I want to start on my 66 but don't have the space to work on two at the same time. I have a couple ideas for the 66 but don't really have any plans for it yet. I really want to sit down and plan it out so I don't end up redoing a bunch of crap like I did on this one.
#25 | |
| Bookmarks |
