#326 |
Re: 67 C10 "Green Gobblin" straight from the field!
Time for a few more updates! Since I put in the radiator and hooked up all the hoses I figured it was a good time to run do a little carb tuning and check over everything. Good thing as after about 20 mins running i had about 1 cup of oil on the floor under the rear of the pan!
![]() So we crawled under and yanked the pan off and took it over to the solvent steam cleaner and put a nice new 1 piece gasket in! While the pan was cleaning i decided to instal the new booster and master/prop and run the brake lines. Just a little to shiny for me but I will figure something out? lol |
#327 |
I moved onto a little interior work since my dash pad and carpet came in from brothers. I had ordered that from lmc but it showed up in olive green that didn't match at all! So I decided to try brothers and just go blk dash pad and try their lighter colour green carpet. Carpet Green is good but they messed up and sent me a high hump carpet! So instead if returning I just put a high hump tunnel in i had kicking around (future plans anyway). My daughter is now happy as she can play and sleep in the cab while I work! lol
#328 |
Unreal, awesome work. I just picked up a cab with new floor that I have to weld in. Your pics will surely help. Going for that patina on a 67 factory utility bed c10 like one that was at sema last yr. Keep pics coming!! Unreal talent you have for metal work
#329 |
Very nice work...
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
#330 |
Time for a few more updates! I decided to run the 72 EEC style tank with the vapour canister to try and cut down on some gas smells so we shall see how that works? I had the tank steam cleaned and pressure tested so its ready to go. I also tracked down the correct canister and fender bracket. Heres a few pics!
#331 |
Next up gauges! I wasn't happy with my LMC cluster since I was kicking myself for not ordering it with the vac gauge. So I returned it and ordered the one I should have got in the first place! :wash:
I also wanted to convert the amps to volts so I grabbed a similar size volt gauge (sun pro) and an old GM amp gauge and swapped the guts. Turned out pretty good as you can't even tell and works perfect! |
#332 |
Back side of gauge and installed into the truck with the dash wiring complete.
#333 |
Wow amazing job looks great
#334 |
Nice work on the truck. In a world of LS engines,love the big block. Do you remember where you got the canister? My 72 is in need of one.
Yeah' well sometimes nothin' can be a real cool hand Lucas Jackson |
#335 |
Thanks guys!
KingNothing I crossed reference the factory canister #s to acdelco #171131148 and i ordered from gm parts direct. |
#336 |
Great work with the gauge swap, I'm a sucker for proper looking retrofit work
![]() Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
#337 |
Everything's looking amazing. I'm really looking forward to seeing this one finished.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
#338 |
Any updates on the build?
#339 |
I've been on this build thread for hours...HOURS! *not kidding* Your build should be a staple of "How to build a C10"! Thanks for all of the information, lit a fire under my a$$ to get into the garage!
#340 |
Ahahah thanks ilikethewoods I’m glad you like the build! I’ve had to take a break from it for abit and while doing that plans have changed! When I get some time I will update to where I left off last year.
#341 |
Lookin forward to any updates. This is one of my favorite ongoing builds.
#342 |
Just ran through your build. Was looking at projects with blending new paint and patina and found yours. Great progress so far.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
#343 |
Ok it's finally time for an update! It's almost a year since I put any progress or pics up but a lot has changed in that time. To much time sitting and looking at awesome builds online has had me change my direction (again). I will finish off with a few pics I never got a chance to put up before I stopped and went into full teardown mode. Here are a few of the front end sheet metal going together.
#344 |
Front bumper on and checking out the front stance.
#345 |
More Stance! lol
#346 |
I Finally got the 275s mounted onto the 15x8s for the rear so I could see where it will sit. Unfortunately it was just not low enough for me with the notch I put in so thats where I stopped to rethink the build. Heres a few pics of the rear.
#347 |
Totally understand stand the changing of directions while reading about builds on here. The same thing cause me to buy another truck to drive over the course of the build.
#348 |
LOL Ya this is the truck I bought so I wouldn't modify my other (original) 68!
#349 |
So over the winter I gathered up some parts from a few board members here. Mirror arms, Green belts, visors, etc... put a few orders in to brothers, lmc and ordered up the Accuair E-level Air ride system. My boy was pretty excited to go through all the air ride parts!
#350 |
I pulled the (best) seat out of one of my parts trucks (72) since the seat frame in this 67 was pretty beat/bent. Plus I wanted a 71-72 seat to be able to have the Green Houndstooth style. Sent it off to the upholster with the cover and it turned out pretty good.
