#3551 |
![]() Join Date: Jan 2012
Re: 67 cheby's Dropmember build thread
Looks great !!!
Stocker to Rocker http://67-72chevytrucks.com/vboard/s...=1#post5148380 "THE GRADUATE" http://67-72chevytrucks.com/vboard/s...08#post5763408 JohnnyC http://instagram.com/texpinstriper/ |
#3552 |
67cheby
![]() Join Date: Sep 2008
thanks guys , i think it will look much better and use a lot less filler !! LOL
#3553 |
needs more $$$
That looks great!!! You picked up that bead roller technique really fast!
1970 2wd Blazer |
#3554 |
67cheby
My friend teaching me has a really nice automatic drive bead roller !! I want it , but for now I will just borrow his !
Posted via Mobile Device |
#3555 |
sorry mike have to ask , the sick part of my mind its cracking up
check out my build thread 71 c/10 step side 5.3 twin turbo http://67-72chevytrucks.com/vboard/s...d.php?t=485320 raul |
#3556 |
67cheby
Needs viagra, lol, a rubber boot grommet for my EFI wiring out of driver door of 2009 Malibu
#3557 |
i've seen a couple of beadrollers they motorized themselves , the eaziest way i can think about in therms of a one stop partsource is using a 24 volt electric motor and motronic out of an immobilitycart
![]() (i know this one is chaindriven and has forward and reverse on one handle) or a big kids toycar driving a cycle-chain and sprockets you could use the handle of the cart and beef it up to a two way footpedal and have forwarth and reverse (depending on wat cart you happen to find )or buy am old pedal from a tig welder or a volume pedal for a guitar to regulate the motronic (you only need a liniar potmeter for control of a motronic on a inmobillitycart ), doing it that way you can drive it at any speed the electric motor is powerfull enough to move a person up the hill at a little over walking speed and can be driven of two batteries if needed i wouldnt be suprized if a windowmotor out of a car would be strong enough too if a lot slower but you wouldnt have the speedcontroll
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts Last edited by watahyahknow; 03-20-2012 at 12:30 PM. |
#3558 |
I used a winch from Harbor Freight and sprockets and chain from McMaster-Carr. I bought the 110v winch so there no need for a battery, just plug into the wall. I work in a machine shop so I remade the cable drum for the sprocket. It works great. I now can do my panels by myself and do not have to worry of having someone cranking to fast or far or even getting someone to crank it at all.
Shannon
48 Panel Truck 1948 Chevy / S10 1954 Chevy / S10 1951 Chevy / C4 47 Step van Lowered 1996 Dually |
#3559 |
67cheby
great ideas !
#3560 |
the winch or any electric motor would work but you cant controll the speed its either on or off it would help to be able to slow down in tight corners and when you need to follow another bead
i wonder if an old chevy cam drive/chaindrive is big enough for the job then you can even use the camdrive cover
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#3562 |
67cheby
thanks David
#3563 |
67cheby
wanted to share a little of today's excitement with you !! SLOSH TUBZ SQUARED !! COMING ALIVE !
#3564 |
![]() Join Date: Mar 2011
Those look good, nice job....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#3565 |
gotta love the progress you have made
#3566 |
some guys are gona lov ya !!!!!!!
#3567 |
That flush trim with the bead roll looks tight!
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
#3568 |
Still Learning
I'm loving the firewall filler plate. I did the full replacement on mine and got a nice bow in it from the welding. I tried to shrink it out. Got it better but it is still not close to flat. you shouldn't have to much warpage on yours with the bead rolled. Are you using Vintage air kit ? I cut my pass through for the heater hoses and a/c lines. I'm not real happy with how it came out. I'm just curious how you are going to route your lines?
The new tubs look Killer! |
#3569 |
VA72C10
![]() Join Date: Mar 2008
Nice work on that firewall! And the STx2 look good
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#3570 | |
Looking good. ![]() |
#3571 |
67cheby
Thanks guys I am extremely excited about all of my current progress, it seems like for a change everything is actually going right !! Yes I am running vintage air and my hoses will come out far on the passenger side so I can hide them over the inner fender
#3572 |
67cheby
For anyone who wants to buy a set , if you want to pay now the first set can be yours !!
#3573 |
Does vintage air provide enough hose to do this??? I am very curious to see how this will work!
#3574 |
67cheby
No I will have custom hoses made, look up ES67 build thread he ran his this way SUPER CLEAN !!
#3575 |
Looks nice. Will you have to trim the inner panel for suspension clearance?
94 k2500 EXCab Long Bed 350ci New Toy 95 K2500 Suburban New PlowTruck 454ci Support our Troops @ http://anyairman.com http://www.woundedwarriorproject.org/ |
Tags |
fiberglass inner fenders, pb hood hinges ", w/pb 4 link |
