Closed Thread
Old 08-07-2011, 08:31 PM   #3551
J.Cagle
J.Cagle's Avatar
Re: What did you do to your truck today?
I picked up an awesome running and driving 84 suburban for $800 yesterday. My 64 is getting ready to get a major trans plant of v8, auto, PS, PB and a new rearend! Its eventually gonna be a more user friendly daily driver than what it is now with manual everything, a straight six, and 3 speed!
1964 c-10 Long stepside, 230 I6 ,3spd, dealer add-on air.
J.Cagle is offline
Old 08-07-2011, 08:38 PM   #3552
CVA59
Originally Posted by towersddg9 View Post
tranny and fuel lines today, used 6an line holders need to add one at the rear
Dang it brother! That is looking saweettt and i am jealous, LOL. Nice job, keep the pics coming.
Zack
www.23t.weebly.com
_________________________________
CVA59 is offline
Old 08-07-2011, 09:42 PM   #3553
samuellg1977
samuellg1977's Avatar
I installed some new-to-my-truck seats today. Now, I can see what is going on OUTSIDE the cab while I'm driving!!! Although, I wasn't counting on the shifter NOT WORKING anymore.
samuellg1977 is offline
Old 08-07-2011, 09:50 PM   #3554
Leadfoot Lambert
Leadfoot Lambert's Avatar
Over the last week or so, New Champion aluminum radiator installed, Engine and tranny installed and test fired for the first time, new CCP tranny cross member installed
65 Chevy short fleet 350 5 speed, soon to be LSX powered
65 F100 short fleet
91 Heritage softail
94 Fatboy
11 Softail Deluxe [wife's bike]
13 Streetglide
http://www.youtube.com/watch?v=yMFMw...eature=mh_lolz
Leadfoot Lambert is offline
Old 08-07-2011, 10:48 PM   #3555
HEI451
I built a second battery box, and hold down, from an old bed frame, so I can run an AC converter without having battery issues. Found another oldie in my shop, Cobra 18 Ultra CB with 3 weather channels, works, and a good CB antenna, so, that is tomorrow's project. Mounted the new mud flaps today, laid out the plan for the box above the trailer hitch on the back of the frame for the hitch ball holders and chains. Just got done detailing the inset background color on the C30 fender emblems (red). Lots more projects to do on the truck.
HEI451 is offline
Old 08-08-2011, 02:12 AM   #3556
fryer1979
Redneck Hillbilly
fryer1979's Avatar
I just took her for a drive today with my wife and pups, but yesterday I was in the pick 'n pull in Sparks Nv., and pulled out a nice brake booster from an '89 Chevy 1/2 ton for my brake conversion. They wanted $25 for a master cylinder, so I stopped by the parts house on the way home and picked up a brand new one for 22.99! Now all I need is steering linkage, and some new hard line for the brakes and I'll be all ready for the swap.
fryer1979 is offline
Old 08-08-2011, 09:47 AM   #3557
kieth
kieth's Avatar
Got is driving under its own power, getting it ready to load on the trailer to go tho the muffler shop......forgot to tighten the power steering return line, DUH !!!! but it does sound good with open headers......
http://kieth.smugmug.com/Trucks/66-G..._ZP6N2xH-X2-LB
kieth is offline
Old 08-08-2011, 02:17 PM   #3558
hopped up
hopped up's Avatar
drove mine for the first time also! great feeling. installed a tranny cooler ,ran lines , new master, bled brakes. need to get a kickdown cable. but hey i drove it!!
hopped up is offline
Old 08-08-2011, 11:54 PM   #3559
hardwaa
hardwaa's Avatar
Painted grill and "surround area".
Before and after pics.
I LOVE BURNOUTS:metal
NO BOZO's
hardwaa is offline
Old 08-09-2011, 08:51 AM   #3560
jbgroby
jbgroby's Avatar
The blackout looks really great, I wonder why Chevy vs. GMC did not follow the same plan/pattern. I understand why GMC did it as the GMC letters appear to "Float". I wonder IF any trucker found letters and tried to have CHEVY float in the area?
jbgroby is offline
Old 08-09-2011, 01:06 PM   #3561
steverino66
made more progress on the weekend project:
removed rusty driver side rocker, welded in some small sheetmetal repairs underneath, test fit the new outer rocker
steverino66 is offline
Old 08-09-2011, 02:25 PM   #3562
kieth
kieth's Avatar
I DROVE IT BACK 6 MILES FROM THE FRONT END SHOP TO MY SHOP !!
DROVE LIKE A DREAM,,,,,,,,,,,,,
Now we have it back in the shop finishing up the wiring and 1000 other small details. I am ordering the A/C system today--------it is 99 and it needs to be cooled offffffff.................Kieth
kieth is offline
Old 08-09-2011, 02:43 PM   #3563
HEI451
I just received a PM about my second battery and box. IN it, the sender didn't want to blow his electrical system up with the "24 Volts" it would then have.
PLEASE, LET ME MAKE THIS VERY CLEAR, I DO NOT WIRE THE BATTERIES TO GIVE 24 VOLTS, BUT WIRE THEM TO STAY AT 12 VOLTS, POSITIVE TO POSITIVE, NEGATIVE ON BOTH BATTERIES TO ENGINE AND CHASSIS GROUND.
I use high amperage large case GM alternators, producing 130/140 amperes, and single wire them, one per vehicle. This alternator/battery configuration maintains each battery in top charge.
I do run a diode between the positive posts of both batteries, with the current flow TO the second battery, and not OUT of it. This way, the one alternator will charge both batteries fine, with each battery being able to single output to different accessories.
My neighbor with the Dodge dump truck built his own hoist/winch, and simply wired both his batteries to give high amperage and 12 volts, no diode. He needs the high amperage for his winch motor, virtually a starter motor that uses a lot of cranking amperes.
My battery box is an ole bed frame, L shaped steel angle, cut to clear the battery I am using, with each end of the angle cut at 45 degrees, so they match at 90 degree angles. I then use a thin sheet of steel plate set into the box, with a liner made of an old rear floor mat, just cut to fit, leave sides so they will cushion the battery in the box. The hold down is simply, round steel rod, bent to fit, and brackets made of strap steel. One end has a bracket welded to it, and bolts to the core support bolt at the battery, the other end is threaded, and sits into a hole in a bracket welded to the bottom of the box. I then also add two large long nuts, bolted together, thread the rod on the top of the battery, so I can change the length of the rod, for different width batteries.
The fellow wanted pictures, and I will take some, and will need help posting them, because when it comes to adding pictures to a web site, I am a real dummy. I really enjoy looking at the pics on these pages, and will have to learn how to post 'em.
HEI451 is offline
Old 08-09-2011, 02:48 PM   #3564
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Man I love bed frames.. You can build almost anything from one.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline
Old 08-09-2011, 03:17 PM   #3565
A.T. RockDriller
A.T. RockDriller's Avatar
HEI's doin' it right....
No reason to be scared.....
Parallel = Two 12V DC batts wired + to + / -'s to grd. = 12V with combined CCA
Series = Two 12V DC batts wired - to + / - to grd. = 24V with combined CCA
Three for 36V and so on and so on and.......... whatever
Sounds like a safe system with redundant safeties....and a ton of amps.
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline
Old 08-09-2011, 04:14 PM   #3566
lwb66step
lwb66step's Avatar
Drained the fuel tank, installed new battery, changed oil, new plugs, wires, coil, cap, rotor, AAAAAAAAAND.......no start all i can think of is it needs a new fuel pump.....
1966 LWB Stepside......SOLD
1963 SWB Fleetside.....Current Project
I hate all fords.
lwb66step is offline
Old 08-09-2011, 08:25 PM   #3567
HEI451
When we built the winch on the dump truck across the street, it would work OK for large logs and railroad ties with the idle sped up and one battery, but, if it was any heavier, no dice, the electric motor on the winch wouldn't do well. This winch is mounted on the side of the dump bed, is changeable length, and uses the same cable to lift itself up to higher angles.
With both batteries and the engine rpms risen to 1,600 idle, we lifted a tree trunk that was over 3 feet in diameter, and longer than the 9' 8" dump bed, with NO problem. We came across the street and lifted a complete Yamaha XS1100 motorcycle, over 8 feet in the air, no problem. We were going to lift the front end of his son's Dodge Neon, but the kid chickened out and left in a big hurry before we could hook it up, DANG.
HEI451 is offline
Old 08-09-2011, 09:54 PM   #3568
62 Bowtie
62 Bowtie's Avatar
Hey that looks killer dude what color is that and was it ralttle can thanks, Tony
62 Bowtie is offline
Old 08-09-2011, 10:36 PM   #3569
kfreeman1966
Talking Re: What did you do to your truck today?
I finally gave my daughter the keys to her 66 that that we did a frame off on.... here is the finished product.
kfreeman1966 is offline
Old 08-09-2011, 11:10 PM   #3570
samuellg1977
The donor for my 63 stepper was a 84 Suburban. I had to use the old drive shaft from the straight six. O gutted it all out from radiator to chunk, steering cloumn too. a 350/700r4 combo and Man, you wanna talk about GIDDY-UP!?!?!? That thing will flat-footed, git it now!!!
Old 08-10-2011, 10:57 AM   #3571
steverino66
Dude, that's beautiful!
You may have just decided my paint scheme (I have the same truck/same Cragars on mine as well) - what color/code/paint brand is that blue if you don't mind?
Old 08-10-2011, 11:38 AM   #3572
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Lucky girl for sure!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline
Old 08-10-2011, 05:13 PM   #3573
kieth
kieth's Avatar
Well we got the rear bumper on, wired the rear lights, set the timing, it sure runs better and actually idles at a stoplight. tomorrow we will install the grille and get the front turn signals and running lights working.........it is coming along.....finally
ps I bought a 66 C10 today BBW, factory air, power steering , custom, 283, powerglide
How will I ever finish them ??
kieth is offline
Old 08-10-2011, 08:18 PM   #3574
markeb01
Senior Enthusiast
markeb01's Avatar
I never appreciated how puny and undersize the rims look on VDO gauges until I mounted the vacuum gauge in the same accessory panel with two Autometer gauges. The new Autometer vacuum gauge arrived today and was installed a few minutes later. Both are 2 1/16" but comparing the two, the Autometer version is certainly more impressive (IMHO). The fun part being my wife inspired the upgrade. She insisted after all the work that’s gone into the project the gauges all need to match, so the new 160 mph Autometer speedometer should also arrive Friday.
Here’s the before shot with the VDO gauge in the center. The rims are so small they will fall through the hole if it's cut slightly oversize:
And here’s the after shot with the Autometer matched set:
markeb01 is offline
Old 08-10-2011, 09:25 PM   #3575
steverino66
Much better - looks great.
Closed Thread
