03-23-2012, 06:54 PM | #3601 |
67cheby
Re: 67 cheby's Dropmember build thread
caught up nothing.....you are flying past me !!
03-23-2012, 07:06 PM | #3602 |
lol......seriously I want your honest opinion on body drop when your done...I looked into that but looked like a lot of work for 3/4 inch--when I 1st heard of it from Nate--I had visions of MUCH lower but then it basically got the pinch welds to touch---JMO!!.......How's jr??.............jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
03-23-2012, 10:12 PM | #3603 |
Still plays with trucks
The raised panel infill piece looks great. That helps give that big flat area some character it needs when the stock stuff is filled in.
The square body tubs are looking good too. Nice work Mike.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
03-24-2012, 09:09 AM | #3604 | |
67cheby
03-24-2012, 09:11 AM | #3605 |
67cheby
thank you and yes i agree, when Porter came out with that i thought WOW, that really does give the pass side a little something extra !makes it pop !
03-24-2012, 09:13 AM | #3606 |
67cheby
speaking of that here is the progess on it last night, and then a little progress welding up some of the extra frame holes, and then a pic of the rear at full lift !
03-24-2012, 09:17 AM | #3607 |
67cheby
i am also in the process of trying to follow N2billets and JTP67-72 lead of tucking the ac unit up far enough behind the dash that it is hidden, the only problem is that i think my unit might be a little bigger, luckily my hoses do come out to the side so i can do this just still trying to figure out what and where the cutting needs to start !
03-24-2012, 09:29 AM | #3608 |
Yours is definitely different from mine but looks like it will tuck --my dash is 2 1/2 " lower than stock dash which helps...that hose configuration would have made mine easier..........jim
03-24-2012, 09:35 AM | #3609 |
67cheby
i am trying to decide if i should slide the whole unit towards the drivers side and then go up ?
03-24-2012, 09:49 AM | #3610 |
you could raise the gutterpart above the unit so it can slide up a little more
you can hardly see that on the outside , not sure if the wiperunit would be in the way of that though and you prolly need to make an extra drain for the rainwater
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
03-24-2012, 09:57 AM | #3611 |
hey 67cheby, great job on the firewall
03-24-2012, 10:00 AM | #3612 |
67cheby
raising it up into the gutter is what i am thinking about doing. Thanks mightymouse !
03-24-2012, 10:14 AM | #3613 |
good job mike , moving along , keep it up !!!!!
check out my build thread 71 c/10 step side 5.3 twin turbo http://67-72chevytrucks.com/vboard/s...d.php?t=485320 raul |
03-24-2012, 02:17 PM | #3614 |
Glad to see your moving along on your truck. Turning out awesome!!!!!!! Hoping to get started on mine today. Pretty excited. Full porterbuilt.
Posted via Mobile Device Posted via Mobile Device |
03-24-2012, 02:18 PM | #3615 |
67cheby
thanks, looking forward to seeing your progress also !
03-24-2012, 06:48 PM | #3616 |
That "shoe" right above fan motor is what i cut out and refabbed--but it may work if U do move to drivers side a little and up...mock and stand back and take a look.....when the truck is low alot of the underdash clutter disappears....jim
03-25-2012, 11:17 PM | #3617 |
i like that A/C unit. seems like the only time my truck is derivable is in the summer when its 100+. and in a black truck no less... the problem is i have to sell a car to afford one. haha great progress man, keep it up!
03-25-2012, 11:54 PM | #3618 |
Still Learning
Nice work on the firewall Mike. I'm interested in the v/a setup tucked. I am in the process of figuring mine out right now. I never even considered raising it. I probably won't now since I already cut the hole in the firewall. I know you are routing your hoses throught the fender well. I'm not doing that modification. Keep up the hard work.
03-26-2012, 12:21 AM | #3619 |
Firewall looks wicked! Very clean
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
03-26-2012, 02:49 AM | #3620 |
Laid Back
Nice work on the firewall looks very clean!!
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
03-26-2012, 09:33 AM | #3621 |
67cheby
thanks guys ....after much consideration this weekend , i dont think i am going to cut into my the channel to raise the ac unit i can raise it about 2 inches without doing much of anything just a little bracket work so in order to keep progressing and not going backwards with my build (and i am a little scared to cut that part) i guess you will just be able to see mine a little !
03-26-2012, 09:38 AM | #3622 |
With the pinch weld on the ground, I'm pretty sure no-one will notice (or even see) your A/C box under the dash.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
03-26-2012, 09:59 AM | #3623 |
67cheby
LOL, maybe not, i will probably just dye it the color of the carpet so it dissapears !
03-26-2012, 10:48 AM | #3624 | |
03-26-2012, 10:54 AM | #3625 |
67cheby
LOL..i dont really know if i have learned yet, but i think that this is ones spot i will just step back and leave it alone !
Tags |
fiberglass inner fenders, pb hood hinges ", w/pb 4 link |
