Old 04-13-2014, 08:29 PM   #3626
Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
Can't wait to see the next adaptation of the Frankie.
Old 04-13-2014, 08:48 PM   #3627
FL71C10
You can say that again!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 04-13-2014, 09:19 PM   #3628
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Been forever since I have been on the board but I'm back for this build...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 04-13-2014, 11:43 PM   #3629
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Today's progress includes making 4 frame rail sides and welding them in. Next up will be tops and bottoms and patch plates over the connection of old and new for extra beefiness. I've got a project to bring home on a car hauler trailer and I can't have my tow vehicle's frame break in two!
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 04-15-2014, 08:40 AM   #3630
drewskiren
drewskiren's Avatar
Welded in 4 patch plate reinforcements where I connected to the front of the old frame last night. Also cut and fit up the tops and bottoms of the new frame, sorry no pics though.
Drew
Old 04-15-2014, 10:37 AM   #3631
jbclassix
Junk Yartist
jbclassix's Avatar
looking forward to the pictures!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 04-15-2014, 10:52 AM   #3632
mcbassin
Still Learning
mcbassin's Avatar
Hey Drew, are you going to have to cut your bed floor to accommodate the new braces? Looks like you are beefing up the frame considerably.
mcbassin is offline   Reply With Quote
Old 04-16-2014, 08:34 AM   #3633
drewskiren
drewskiren's Avatar
Yes, the frame will protrude through the floor about 5 inches, I'm currently thinking I'll get a new set of wheel tubs and tub it out to hide it. But the tubs may be short to just cover the frame? Kinda stair stepped.
Drew
Old 04-16-2014, 07:01 PM   #3634
drewskiren
drewskiren's Avatar
Pictures as promised and new work showing top and bottom plates fitted and welded in.
I have to be done by Easter Sunday, my son is taking his car back to school and I'll have no ride!!!
Drew
Old 04-17-2014, 12:23 AM   #3635
mcbassin
Still Learning
mcbassin's Avatar
Nice work on the frame Drew. Should be plenty sturdy
Old 04-17-2014, 09:28 AM   #3636
oldman3
oldman3's Avatar
Looks good...Jim
oldman3 is offline   Reply With Quote
Old 04-18-2014, 12:28 AM   #3637
drewskiren
drewskiren's Avatar
Two nights worth of work here in these pics.
I raised the frame so much, I had to mount my snubbers on raised blocks. Later if I decide it needs to be lower I've got an easy inch and a half by taking them out. I even welded a nut inside the frame to screw the snubber straight to the frame. I know I'll want to play again!
Also I have my airbag helpers set up with mounts on the frame and axle.
These Afco coil-over shocks are a tight fit with the quadrasteer, but I managed to make room for them. I'm still working on the upper mount in these pictures.
I think by tomorrow I'll be done welding and can throw some black paint on. Gnande my helper will be home for Easter and I'll have him cutting the bed floor while I'm painting the frame. Maybe get everything hooked back up on Saturday and then be ready for family members here for Easter lunch to help me set the bed back on.
Drew
Old 04-19-2014, 12:19 PM   #3638
drewskiren
drewskiren's Avatar
Stayed up until 2 am getting plenty of paint on the frame so I could reassemble today.
Drew
Old 04-19-2014, 12:38 PM   #3639
drewskiren
drewskiren's Avatar
Here you can see the upper and lower suspension mounts I crafted to mount the coil overs.
Can't wait to get this thing back together!
Drew
Old 04-19-2014, 07:56 PM   #3640
drewskiren
drewskiren's Avatar
See where I'm going with this?
Limiting straps, snubbers, coils, shocks, air bags - all done.
Now to rewire the rear and reinstall the Quadrasteer computer.
Oh and of course, what started this all, A Straight Panhard Rod!
Drew
Old 04-19-2014, 08:00 PM   #3641
drewskiren
drewskiren's Avatar
Most importantly though,
edited by staff: You must be a paying vendor to advertise on this site.
Drew
Old 04-20-2014, 07:17 PM   #3642
drewskiren
drewskiren's Avatar
Whew, got that done in the nick of time.
Tonight I can hook up the lights and pop on the tailgate and be rolling tomorrow.
I'll still have a lot of sheet metal repair to do, but I can drive it while messing with that at night.
I just tested it over the one bump that always bottomed me out and it sailed right over it no problem.
Drew
Old 04-21-2014, 12:13 AM   #3643
oldman3
oldman3's Avatar
Congrats, and keep us posted...Jim
Old 04-21-2014, 09:12 AM   #3644
Low Elco
Looks tight! Nice job. Are you just gonna make double-width tubs?
Low Elco is offline   Reply With Quote
Old 04-21-2014, 07:07 PM   #3645
drewskiren
drewskiren's Avatar
Pretty much, just not quite double the width.
I've got a question for anyone: If your truck is completely level, are the wheel arches exactly the same distance off the ground?
Drew
Old 04-26-2014, 05:14 PM   #3646
drewskiren
drewskiren's Avatar
Originally Posted by ThreeQtr View Post
At
PS The wife needs a pink Mrs Frankenstein.
This was an old comment, but I like it.
Drew
Old 04-26-2014, 06:01 PM   #3647
drewskiren
drewskiren's Avatar
Originally Posted by pacman1967 View Post
Seeing this truck almost complete makes me slightly sad, whose truck am I going to follow when Frankie is done? Great work Drew, the quadrasteer is a killer touch. This is just Awesome.
Awwww, poor fella. Maybe we can find you something else to watch.
Drew
Old 04-26-2014, 11:27 PM   #3648
67ctener
67ctener's Avatar
Those coilovers look niccceee
67ctener is offline   Reply With Quote
Old 04-28-2014, 10:42 PM   #3649
drewskiren
drewskiren's Avatar
One coil over had to come off tonight. Brand new and it sprung a leak at the rebound adjustment screw. Oil is all over, good thing I haven't buttoned up my tubs yet. That also sure made it easy to remove. You can see I am suspended on my backup airbag suspension - What? doesn't everyone have 2 types of suspension ready and usable at all times???
Actually I am able to drive it this way on my overload airbag, it just rides a little low on that corner.
Drew
Old 05-09-2014, 10:58 PM   #3650
SGTHohensee
SGTHohensee's Avatar
Just found this thread while searching for CCSB builds. Holy smokes. Absolutely amazing. I secifically remember seeing this truck in Hot Rod Magazine, because my first thought was, "Dang, that thing's broken!" Took me 6 solid hours to read it all thoroughly. I giggled like a girl when the quadrasteer was revealed.
Favorite parts of the truck: Kids inside hamming it up, brake dust on the wheels, dirt on the frame and the dirt in the box.
It means you use it. That's what it's there for. It's why you built it in the first place.
If I ever run down through west Tennessee I'll PM you and see if I can come get a picture of this awesome machine.
Of course, if you ever run through Smyrna, I'd love to see it!
P.S. Are you running out to Knoxvegas for the power tour this year?
Josh Hohensee
1979 Midnight Black SWB
I'd attach a picture, but photosucket sucks.
SGTHohensee is offline   Reply With Quote
