Closed Thread
Old 05-01-2016, 11:40 AM   #3626
35boulder
35boulder's Avatar
Re: What did you do to your truck today? Chapter II
So far spent most of the morning tracking down a rattle in the drive train. No luck so I'll keep looking as I watch the race!
35boulder is offline
Old 05-01-2016, 11:55 AM   #3627
firedemon
Originally Posted by Possmguts View Post
Looks nice ... how did you get them to stick to the ceiling like that? That would help make more room in my garage if I could do that lol
i was thinking it must be a pain painting from a ladder lol
firedemon is offline
Old 05-01-2016, 10:52 PM   #3628
Bowtiguy
Bowtiguy's Avatar
If someone would have told me it would 5 days to cut, dado, router, drill, mock up install, reinstall, reinstall then get my custom 68' short wood bed on the frame ( after lifting it off to drill the gas filler hole) i'd say they were crazy. not anymore..
Bowtiguy is offline
Old 05-01-2016, 11:20 PM   #3629
mud.man.rj
mud.man.rj's Avatar
Well by the looks of it perfection takes a few days, sure looks good.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 05-01-2016, 11:37 PM   #3630
RINC
RINC's Avatar
Nice Sunday spent in the driveway.
New starter hooked up on my Dad's C-10.
Shocks, front and rear greased on my C-20.
Chris
'69 C-20
'04 Jeep TJ
RINC is offline
Old 05-01-2016, 11:42 PM   #3631
JG67
Sure looks good though.
JG67 is offline
Old 05-02-2016, 11:17 AM   #3632
matthamby
Last night - cleaned out my buddy's garage (moved his jeep out, and equipment) got the C10 on the lift and took wheels off to start replacing brake cylinders, he's going to work on that this week while he is "slow" on other work, hopefully have the exhaust put in this week!
Got my insurance on it this morning and getting ready to head to DMV to get tags - woohoo!
here's some pics of the original bed and tailgate, then the replacement I found for $200!
I didn't realize it had an original wood bed - the plate steel has always been in it as long as I can remember, when we lifted it up to do the brakes, some of the wood fell down, it's almost like one of those house shows where they pull the carpet up and "hey you have wood floors!" - only problem here is that I can't simply remove the covering and be done! My friend said something to me a few weeks ago about how my grandpa put that in, because there was some ply-wood under the steel that was rotted, upon closer inspection last night we realized it wasn't plywood but the original wood floor.
matthamby is offline
Old 05-02-2016, 12:05 PM   #3633
snipescastle2
snipescastle2's Avatar
Talking Re: What did you do to your truck today? Chapter II
working on an Electric Vacuum Pump install on mine for a solution to the low vacuum due to my "Lumpy" cam.......tested it at work and got 25" of Vacuum...it's off a 2003 Audi A4, some Volkswagen cars had them too....cost me $26.00 at Pick n Pull.
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline
Old 05-02-2016, 12:49 PM   #3634
Wasted Income
Boosted Member
Wasted Income's Avatar
Re-routed my downpipe
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline
Old 05-02-2016, 01:21 PM   #3635
KEL
72 GMC
KEL's Avatar
Front springs and shocks. Seperating the
ball joints from the spindles was NOT
easy ! But, its done !
KEL
Members I have met :
2014.02.01: bruceman1968, Mr Handy, colgad, RenoKeene, CaptRMW
KEL is offline
Old 05-02-2016, 01:25 PM   #3636
JG67
That's going to be crazy loud! That's BadA$$.
JG67 is offline
Old 05-02-2016, 01:30 PM   #3637
Wasted Income
Boosted Member
Yea it's pretty loud. I'm gonna make some baffles to slip inside. I drove it around for quite awhile with a very similar setup back when I first got it running.
Turbo diesel
Old 05-02-2016, 01:44 PM   #3638
XwalkerX
oh hell yes!
XwalkerX is offline
Old 05-02-2016, 07:53 PM   #3639
Possmguts
Possmguts's Avatar
lol.. I bet it cuts down on the over spray doing it upside down on the ceiling though
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 05-04-2016, 11:55 AM   #3640
BugzC10
BugzC10's Avatar
Just about to finish new water pump install...waiting on new pepcock, put on upper hose and add 50/50.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 05-05-2016, 09:50 AM   #3641
Bowtiguy
Bowtiguy's Avatar
Thanks guys it was my first bed job. worked out pretty well using off the shelf composite decking material. spacing is bigger between boards but the strips lined up factory once I used the larger center board in place of the factory style skinny center boards. I eliminated the offset top washers and am using allen-button head SS bolts instead.
Bowtiguy is offline
Old 05-05-2016, 05:27 PM   #3642
Dave K.
Dave K.'s Avatar
Got the grill guard installed--bought it from a fellow member here. Okay, I drilled two holes--have left the outboard ones for now.... Thanks Al, great meeting you and thanks for your patience! Dave
Dave K. is offline
Old 05-05-2016, 06:36 PM   #3643
In The Ten Ring
Glad you put one on. I have hit two animals in the last couple of years (both with my Honda Accord) and I took damage each time.
With the '72's plastic grill, I have decided to sport a grill guard once she's mobile.
In The Ten Ring is offline
Old 05-06-2016, 09:15 AM   #3644
Econman
Econman's Avatar
I didn't do anything to it (yesterday) except pay the paint/body warden for his work to date..
Econman is offline
Old 05-06-2016, 09:16 AM   #3645
Econman
Econman's Avatar
Econman is offline
Old 05-06-2016, 10:21 AM   #3646
Dave K.
Dave K.'s Avatar
I just really dug the look of the early guards. It's probably the only thing non-original on the truck at this point but it was worth a couple of extra holes in the bumper!
Dave K. is offline
Old 05-06-2016, 10:34 AM   #3647
tlman
I feel your pain
tlman is offline
Old 05-06-2016, 12:25 PM   #3648
DaHos
DaHos's Avatar
Gots wood, doing some ripping today......
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline
Old 05-07-2016, 12:23 AM   #3649
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
What did I did to my truck today? Well its like what have I been doing all week. Did some under hood detailing and it was easy with the hood off. Installed my LED plug and play tail lights I bought from Wes at Classic Heartbeat last summer. Realized while poking under the hood my A/C clutch needs replacing
http://67-72chevytrucks.com/vboard/s...d.php?t=706266 Changed my upper tailgate mouldings myself and learned they only go on one way, yes there is a top and bottom to them. I knew the left front fender on the truck had been damaged and discovered it was replaced with used one, but I don't think one from a 72. I'll stop now , but let me say its been a great week and I learned some things about my truck and that I can do things I thought I couldn't.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Old 05-07-2016, 01:06 AM   #3650
seekhunt
Lit up the tires in public!
seekhunt is offline
Closed Thread
