Closed Thread
Old 09-25-2011, 07:33 PM   #1
flatbed51
flatbed51's Avatar
What Did You Do With Your Truck Today ?
Ok, the 60-66, 67-72, 73-87, and 88-98 guys have a thread called "What Did You Do To Your Truck Today". Well I say it is time the 47-59 forum has a similar thread, so I decided to start one. Anybody want to join in ?
My Build Thread
51 chevy
http://67-72chevytrucks.com/vboard/s...d.php?t=437496
48,49,50 Chevy trucks. 41 Olds
flatbed51 is offline
Old 09-25-2011, 07:41 PM   #2
alden
alden's Avatar
Re: What Did You Do With Your Truck Today ?
I started sanding down the rusted beat up front bumper it came with, too muggy to paint today though.
alden is offline
Old 09-25-2011, 08:18 PM   #3
Rude Dude
Rude Dude's Avatar
Absoultely nothing today see my build what I did friday and saturday!
Made rear bumper brackets and brake handle cable set up plus cut down original handle and helped my neighbor dissamble his recently acquired project.
http://67-72chevytrucks.com/vboard/s...d.php?t=436442
Rude Dude is offline
Old 09-25-2011, 07:57 PM   #4
Maximus
Maximus's Avatar
today i installed my accelerator pedal assembly (aftermarket), finished installing my windsheild with the deluxe trim, and started installing my doors (after getting the first one hung I realized I cant effectively adjust the door alone, will put that one off until i can get help.
Windshield looks good though!
Still havent got my back glass in all the way... pounded and pounded and I cant get it in far enough to install the bead lock... grr....
Maximus is offline
Old 09-25-2011, 08:17 PM   #5
flatbed51
flatbed51's Avatar
Well I guess since I started this thread I should post what I did to my truck. Went out and looked at the frame work me and my buddy got done yesterday. We got the Malibu clip spot welded in. Did some more measuring/ re-checking to see if we got it right , and to make plans for next move on it next weekend. It was great to finally get the frame rolling again.
My Build Thread
51 chevy
Old 09-25-2011, 08:17 PM   #6
brikar
brikar's Avatar
sand blasted my inner fenders
brikar is offline
Old 04-21-2013, 07:40 PM   #7
Rude Dude
Rude Dude's Avatar
Paint stripped, etch primed,epoxy painted white and color sanded too!
Old 04-21-2013, 07:54 PM   #8
lowdownstar
big guy
lowdownstar's Avatar
All that paint work in one day damm your good!!!! and it looks good too
Ray
lowdownstar is offline
Old 04-21-2013, 09:15 PM   #9
OrrieG
OrrieG's Avatar
bunch of small stuff and got the auxiliary dash leds mounted in the old ignition hole. Boxes are starting to arrive!
OrrieG is offline
Old 04-21-2013, 09:48 PM   #10
mknittle
mknittle's Avatar
Looks nice Orrie.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline
Old 09-25-2011, 08:20 PM   #11
coralhead
coralhead's Avatar
I rolled the cab onto its back and finished welding the new floor, cab mounts and interior cowl panes and undercoated the complete bottom.
coralhead is offline
Old 09-25-2011, 09:03 PM   #12
FFredo
Finished boxing in and painted new the C-notch I started last week, built and painted a cradle for the new gas tank, installed new rear bumper, then I painted it.
Dont get too excited, when I say "painted" I mean I pointed a spry can and it and held down the button 'till it was all the same color of black...
FFredo is offline
Old 09-25-2011, 09:40 PM   #13
lazypineapple
lazypineapple's Avatar
Got my wheels and Tires done today. on my 52
lazypineapple is offline
Old 09-26-2011, 05:57 PM   #14
mknittle
mknittle's Avatar
I like.
Mark
My GMC build.
mknittle is offline
Old 05-09-2012, 05:30 PM   #15
Jesse49chevy
Jesse49chevy's Avatar
I want to do something similar to my 48, if you dont mind sharing the info, where did you buy and how much did you spend?
by the way, they look GREAT!!!!
Semper Fi
Check out my project:
http://67-72chevytrucks.com/vboard/s...d.php?t=559086
Jesse49chevy is offline
Old 05-09-2012, 05:53 PM   #16
lowdownstar
big guy
i painted my rear fender! This is my first time doing my own body work and paint.
Thanks Ray
Old 05-09-2012, 07:21 PM   #17
mknittle
mknittle's Avatar
Thanks Ray
Looks great Ray
Mark
My GMC build.
mknittle is offline
Old 05-15-2012, 04:08 PM   #18
Dan in Pasadena
Dan in Pasadena's Avatar
Thanks Ray
Looks pretty damned good in the photo. Does it look that flawless in person? If so, you might just have a future as a painter, huh?
Is it satin or are you clear coating it?
Dan in Pasadena is offline
Old 05-15-2013, 10:13 PM   #19
mknittle
mknittle's Avatar
I got the cutting and drilling done on my motor mounts. these bolt to my Camaro clip replacing the clamshell mount. I made them to use 70s Camaro shackle bushings.
Mark
My GMC build.
mknittle is offline
Old 05-16-2013, 08:49 AM   #20
lowdownstar
big guy
wow those look great, you do some nice work!!!!
Ray
Old 05-16-2013, 09:17 AM   #21
mknittle
mknittle's Avatar
Ray
Thanks Ray,
They just didn't look right without holes. But next tome I will drill the holes BEFORE I cut the parts out. Some days I get the cart ahead of the horse.
They replace these. the plate welded to the frame under the motor mount is to move the mount to the rear a couple inches.
Mark
My GMC build.
mknittle is offline
Old 05-17-2013, 02:04 PM   #22
1-ton of fun
polishing a turd
1-ton of fun's Avatar
Thanks Ray,
i think i need to do that as well. do you have any more details on the plates you made?
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline
Old 05-17-2013, 06:28 PM   #23
crossfire84
crossfire84's Avatar
nice job!
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is online now
Old 05-17-2013, 08:44 PM   #24
mknittle
mknittle's Avatar
Originally Posted by crossfire84 View Post
nice job!
Thanks crossfire!
Mark
My GMC build.
mknittle is offline
Old 09-26-2011, 11:02 AM   #25
Russell Ashley
Russell Ashley's Avatar
I have removed all old wiring and just starting installing an EZ-wire harness in my 57.
Lazypineapple: wheels and tires look great. I can't wait to get my whitewalls.
Russell Ashley is offline
Closed Thread
