05-10-2016, 08:17 PM | #3676 | |
Old member
Re: What did you do to your truck today? Chapter II
I used the brackets from the 8" booster. It does sit a little closer to the fire wall but not much. http://www.ebay.com/itm/BLACK-1967-7...item4d3183d855
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 05-10-2016 at 08:30 PM. |
05-11-2016, 06:58 AM | #3677 |
My grandpa made that bumper, he did a good job with it, it did match the "v" in the front end, that is 2"x6"x1/4" channel, pretty solid, but someone has bent that!
05-11-2016, 08:08 AM | #3678 |
Mounted my benchwork steering box
05-13-2016, 01:57 AM | #3679 |
I mounted driving lights (I have a thread about it). Cost $3.49 for stainless allen screws, lights were taken off my dying MINI.
1968 Long Bed 2016 Honda Civic Coupe EX-T ticket magnet |
05-13-2016, 08:44 AM | #3680 |
I fixed my non-working license plate light on the right side of my step bumper. Replaced the wire and connector on that side (non-factory bumper) and now it works! Also swapped out my faded side markers for new aftermarket units.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
05-13-2016, 01:52 PM | #3681 |
I stained the bed... (I don't usually brag about that, but... )
68 C10 SSB 383 12 Charger 6.4L 12 Accord 3.5L (Wife's ride) 05 Ram 1500 5.7L My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=676545 |
05-13-2016, 02:21 PM | #3682 |
Nice deep color..what are you going to do next? Spar?
1970 C10 Short Stepper with 71/72 front clip. |
05-13-2016, 02:40 PM | #3683 |
Thanks - Minwax Red oak.
Trying to decide between spar varnish, or a few people have recommended exterior urethane. Anyone have any experience either way? Other than clear... any certain type? Satin, gloss?
05-13-2016, 03:03 PM | #3684 |
I used Minwax Polyurathane clear satin. 4 or 5 coats... It's been a couple years and holding up great. The truck is always garaged, however.
05-13-2016, 03:19 PM | #3685 |
Looks great. Someone recommended Minwax Helmsman Spar Urethane, clear gloss.
I think I'm going to give it a try. 4 or 5 coats sounds about right.
05-13-2016, 03:25 PM | #3686 |
Now that you wrote it out..that's exactly what I used. Hey..I'm over 65, I get a pass now and then. I looked in my garage and found the poly satin, but I had a feeling that it was not what I used.
05-13-2016, 07:52 PM | #3687 |
Changed the water pump gasket and water neck gasket on the ol 250 in goldilocks. They had a slight seepage.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
05-13-2016, 09:51 PM | #3688 |
put a gas peddle in my project super short c10 4x4 |
05-13-2016, 11:09 PM | #3689 |
Pulled my engine outside in the rain.
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
05-14-2016, 06:55 PM | #3690 |
Sometimes I have to pinch myself after having removed parts. 45 years on the truck and better than new. Personally, I like some stain in the mirror. I'll hit the chrome one last time before I mount this in 2018, just because. By the image, I did a sloppy job on that boot. I should have drenched it in treatment and used a toothbrush religiously. My eyes failed me, followed by me brain. EDIT: That was a stand in, I took a pic. of the right one:
BTW, 3M chrome/metal polish is great stuff.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 05-14-2016 at 08:51 PM. |
05-14-2016, 07:27 PM | #3691 | |
05-14-2016, 08:57 PM | #3692 |
replaced my windshield gasket with a precision gasket don't buy the lmc gasket that thing leaked so bad and I couldn't get the trim in to save my life . the new one I bought dosent have the trim and I'm glad I was able to put it in in 20 min with just my brother for help pouring rain here today and leak free
05-14-2016, 10:04 PM | #3693 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
05-14-2016, 10:15 PM | #3694 |
By hand. I hit it 3-4 times with a flat hand, polish and a layer or two of small terry cloths. These rub out rather well. Removed a nice layer of black, possibly tarnish. That may have worked out to be a good thing......I didn't expect this at all. The rubber is great as well. Pleasantly surprised to say the least. Especially after handling the mirror far too often, because the arm was stripped where the mirror attaches. I had different priorities.
Note: That polish does rub out fine scratches in chrome, which may vary on piece (I'm no expert). Removes light scuffs as well.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 05-14-2016 at 10:45 PM. |
05-14-2016, 10:50 PM | #3695 | |
I thought a gasket is a gasket with a 30 dollar difference went the wrong way learned a lesson |
05-15-2016, 02:48 PM | #3696 |
The Highlander's water pump was making noise and seeping a bit, the timing chain cover was dripping oil and the radiator was dripping antifreeze out of soft spots on the drivers side tank. So I pulled it all apart yesterday afternoon and put it back together this morning. I couldn't believe the number of loose bolts I found. Basically if it wasn't a bolt for belt adjustment it was slightly more than finger tight. It makes me wonder about the internals. I also found a freeze plug that was seeping so I replaced that too. The belts are in great shape and so is the upper radiator hose but the lower hose is pretty soft and the spring inside is badly corroded and a piece bike off. Are the radiators hoses readily available?
05-15-2016, 04:29 PM | #3697 |
checked still getting drips on floor near clutch pedal but dash is dry as a bone think I have another issue never ends
05-15-2016, 06:24 PM | #3698 |
got my 4x4 shifter and trans shifter bolted up today, took the hump from a1983 k5 blazer and cut out about 4 inches of the length out and welded it back together so it would fit on the floor. |
05-15-2016, 07:07 PM | #3699 |
Spent today trying to figure out why my seat felt so "lumpy"...Answer found! looks like the perimeter frame has broken off on the driver side, two of the flat looking springs are loose at the coiled end,one has been replace by simple wire, and the side support springs are broken on the passenger side
05-15-2016, 07:22 PM | #3700 | |
https://www.epifanes.com/page/clear-finishes Really good stuff...
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
