Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 01-11-2006, 02:00 PM   #1
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
Color Wiring Diagram FINISHED
Please download and print this color coded version of the 67-72 wiring diagram.
I set it up on a legal sheet. Print it front and back or two pages.
Low res
Here is the link for the largest version
4200x2550
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 01-11-2006, 02:00 PM   #2
boundstaffpress
Re: Color Wiring Diagram FINISHED
V8 engine and cab
Link for the largest version
4200x2550
Justin
Old 10-23-2015, 04:42 PM   #3
70gmc4d
Originally Posted by boundstaffpress View Post
V8 engine and cab
4200x2550
I don't see the three wires to the trany. I see the one green and one black to the reverse switch. My 70 GMC has three wires, dark green and light green to the switch and the black wire I just assume is a ground. But you know what they say about assuming. Thanks for the diagram it helps a ton!
70gmc4d is offline   Reply With Quote
Old 10-24-2015, 02:48 PM   #4
chuchito
I have a 1972 GMC suburban, and the wiring is driving me crazy. The diagrams I found on here look similar to what I see under the hood but not exactly. Also, I don't see the blue wire that is supposed to be to the oil pressure on my harness but my guage cluster does have a oil pressure guage. The engine harness actually only has 5 wires. I unplugged it and looked at the female plug on the firewall and it also only has 5 inserts. The five wires I have are the tan, dark green, purple,pink, and brown with white. Can someone chime in?
chuchito is offline   Reply With Quote
Old 11-02-2015, 03:32 PM   #5
70gmc4d
My 70 GMC has a mechanical oil pressure gauge that is plumbed in the block next to the distributor. And the 70 gmc has 4 headlights up front.
Old 11-02-2015, 10:43 PM   #6
chuchito
Maybe that's how mine is too. There is a metal line that looks like it would go next to the distributor.
Old 11-02-2015, 03:11 PM   #7
TOYDOC
TOYDOC's Avatar
Thank you for taking the time to make a diagram like this! if possible could you e-mail me a copy at ctoydoc@gmail.com
Thank you!!
TOYDOC is offline   Reply With Quote
Old 11-09-2015, 10:15 AM   #8
70gmc4d
Just a heads up I'd anyone else had the same issue. I did ground the black wire to the fire wall and when I fired up my truck this weekend the backup lights work awesome.
Old 01-11-2006, 02:22 PM   #9
Looks very good.
You have a PM
Old 01-11-2006, 02:27 PM   #10
chevyfarmer
chevyfarmer's Avatar
This looks great, I will try to print this out, Thanks
67 short wide 355ci 3 on tree
69 short wide 250ci 3 on tree
68 long wide 283 3 on tree
72 2wd Blazer project 454 5 speed
chevyfarmer is offline   Reply With Quote
Old 01-11-2006, 02:46 PM   #11
farside847
farside847's Avatar
nice!!!!
Do you have larger versions that we can view online?
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 01-11-2006, 02:58 PM   #12
boundstaffpress
Edit: This is now available in a much larger format on my flickr page. follow the link in my signature. :Edit
Justin
Old 01-11-2006, 03:03 PM   #13
Deuce
Deuce's Avatar
Can you please send me a larger version to: lockard@telusplanet.net
Thanks and AWSOME work!!
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 01-11-2006, 03:40 PM   #14
CST*TEN in Katy
I would like the larger file. please, to lookinaroun@sbcglobal.net
My tired old eyes thank you.
1970 CST-10 owned it 26 years, finally back on the road after a 10 year rest.
1989 Suburban
1971 Sleekcraft 455Olds Berkeley
1992 SC400 pimp ricer
CST*TEN in Katy is offline   Reply With Quote
Old 01-11-2006, 04:21 PM   #15
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Thanks for the nice work.
May I please have a copy sent to: frankeham@comcast.net
PICKMUP is online now   Reply With Quote
Old 01-11-2006, 05:30 PM   #16
meathead95
computer illiterate
meathead95's Avatar
could you please send me the larger one sent to meathead95@hotmail.com
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 01-11-2006, 05:44 PM   #17
svgould
Active Member
svgould's Avatar
Hi,
Can I get the larger one sent to svgould@hotmail please......Thanks
1971 SWB SOLD
  • LT1 motor / 4l60E transmission
  • ECE front dropped spindles with stock height springs
  • 4" rear springs
  • Coys Wheels 18 x 8 all the way around
  • Hydratech hydroboost brake system
svgould is offline   Reply With Quote
Old 01-11-2006, 05:45 PM   #18
Mark B
Mark B's Avatar
That is just what I have been looking for. Could you please send the larger file to me at mbenson@dialonewolfedale.com
Thanks very much
Mark
Mark B is offline   Reply With Quote
Old 01-11-2006, 05:46 PM   #19
cory321
Problem Child
cory321's Avatar
Hi looks nice could you send me a larger copy to coryostendorf@sbcglobal.net
1972 gmc sierra grande
350/350 a/c soon`to get a new 350
I Survived Norwood
cory321 is offline   Reply With Quote
Old 01-11-2006, 05:49 PM   #20
shifty
Questionable
shifty's Avatar
you know, i can temporarily host the larger files for you if you want.
my email is in my profile.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 01-11-2006, 05:55 PM   #21
boundstaffpress
Shifty I looked, didn't see your e-mail. Mayby I just skimmed over it. Send a PM if you want, or post again.
Justin
Old 01-11-2006, 05:58 PM   #22
boundstaffpress
I would love to have someone temporarily or permanently host a high res. image on their web site. Let me know if you do this, and I'll edit the first post in this thread
Justin
Old 02-06-2011, 05:13 PM   #23
actconstruction
I could probably host it if someone sends a hi-res to actconstructiononline@yahoo.com
I also have the original CAD documents from Edmond a few years back. I can't vouch for their accuracy but all looks well, and it's an AutoCAD so you can always modify (which is why I wanted it with all my junkyard upgrades). If anybody wants the AutoCAD version, just PM your e-mail address to me and I'll get it to you.
Or, somebody could e-mail the high-res versions of these to me at the e-mail address above and I'll just host these files along with the high-res pdf's. (Edmond just gave me permission to host the CAD files, so long as he keeps the credit, so: THIS PROFESSIONALLY RENDERED CAD DOCUMENT AND ASSOCIATED FILES ARE ENTIRELY THE PRODUCT OF EDMOND'S HARD WORK. WE ALL OWE HIM AND ONLY HIM OUR DEEPEST GRATITUDE. So there it is. Credit where credit is due. Thanks again. You're a lifesaver.
"Did you seriously just ask me what I need more power for?"
"You're stupid, cause I've smoked plastic."
Last edited by actconstruction; 02-08-2011 at 01:41 PM. Reason: Got permission to distribute AutoCAD freely. Thanks.
actconstruction is offline   Reply With Quote
Old 02-07-2011, 10:07 AM   #24
Edmond
Edmond's Avatar
Thank you Chuck, and I'm glad you are happy with it.
Cya,
Edmond
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb
1974 Chevy Camaro Z28 (Original)
The Netherlands
Edmond is offline   Reply With Quote
Old 02-18-2011, 12:14 AM   #25
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Originally Posted by actconstruction View Post
....snip....
...snip....THIS PROFESSIONALLY RENDERED CAD DOCUMENT AND ASSOCIATED FILES ARE ENTIRELY THE PRODUCT OF EDMOND'S HARD WORK. WE ALL OWE HIM AND ONLY HIM OUR DEEPEST GRATITUDE. So there it is. Credit where credit is due. Thanks again. You're a lifesaver.
Agreed. Thanks sooooo much for the diagram.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
