Old 02-05-2016, 12:25 PM   #351
Evoracer
Re: Post Pics of your Static Drops!!
Originally Posted by chopper john View Post
my 65 big window
I haven't seen this one around town yet. Cool.
Evoracer is offline   Reply With Quote
Old 02-05-2016, 12:48 PM   #352
forestb
forestb's Avatar
Originally Posted by Slambone View Post
6/9 drop! 3" drop coils in front with a coil and a half cut and 5"drop coils outback with 4"blocks.
http://https://www.flickr.com/photos...posted-public/
How do you keep your front cross member form scraping on the ground when you go over speed bumps and dips with a 6 inch drop up front?
forestb is offline   Reply With Quote
Old 02-10-2016, 12:53 PM   #353
chopper john
chopper john's Avatar
Originally Posted by forestb View Post
WOW! If that is a static drop you are a braver man than I
haha. thanks i live in anaheim and go a lot to toluca lake and lots to palmdale... low n slow
chopper john is offline   Reply With Quote
Old 02-10-2016, 12:54 PM   #354
chopper john
soon soon. its feen my daily driver since feb of last year.
Old 02-10-2016, 10:29 PM   #355
sharkskinman
So give me the lowdown on adding different bolts or requirements when lowering the front with lowered springs ?? In the idea of alignment I mean
Thinking
http://m.ebay.com/itm/63-72-CHEVY-TR...-/171830253705
sharkskinman is offline   Reply With Quote
Old 02-10-2016, 10:45 PM   #356
sharkskinman
Has anyone given stock height measurements yet??
Old 02-11-2016, 10:45 AM   #357
halfadeuce
Camaro front clip with 1 inch drop springs, qa1 upper control arms, leafs in the rear with 3 inch lowering blocks and all but 2 leads removed.
halfadeuce is offline   Reply With Quote
Old 02-26-2016, 02:09 PM   #358
arky hauler
Here is my GMC. It has 3 inch lowering springs and 2 inch drop spindles in front. For the rear it has a c-notch and a flip kit for approximately 6 inch (just guessing) drop. Had to cut out a square section of the wood bed directly over the differential for travel clearance in rear suspension.
arky hauler is offline   Reply With Quote
Old 02-26-2016, 02:20 PM   #359
Paul Y
Now that looks fantastic!
What are the details, would like to replicate this if possible with my set up.
P.
Paul Y is offline   Reply With Quote
Old 02-26-2016, 06:24 PM   #360
flynn
flynn's Avatar
That looks great Which flip kit did you use?
flynn is offline   Reply With Quote
Old 02-26-2016, 09:38 PM   #361
arky hauler
Thanks flynn, it was a flip kit for 1973-87
Old 02-26-2016, 11:04 PM   #362
62stepside longbox
62stepside longbox's Avatar
Wow the stance on that gmc looks great!
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 02-27-2016, 07:46 PM   #363
50bomb
50bomb's Avatar
My work in progress daily driver. Had 2/4 drop for the last 10 years and today I added 2" lowering blocks. She is stuck up right now. I am working my way for disc conversion up front to add 2" drop spindles to give it that 4/6. Baby steps.
Stovebolt-It is painted
50bomb is offline   Reply With Quote
Old 02-27-2016, 10:26 PM   #364
sharkskinman
Originally Posted by Nacho_Paras N.L.;7335251.
5.5" up front-- 3" drop spring and 2.5" drop spindles----- and 7" drop in he rear---5" drop springs and 2" CPP angled aluminum drop blocks..
That's a real nice stance
I'm thinking towards these
http://m.ebay.com/itm/63-72-CHEVY-TR.../171830253705?
Old 02-27-2016, 11:44 PM   #365
60chevyjim
60chevyjim's Avatar
nice truck I like the colors
60chevyjim is offline   Reply With Quote
Old 02-27-2016, 11:48 PM   #366
JYSaint
I read the part about the axle flip. But for the drop spindles did you have to convert to disc? Or where did you get them?
JYSaint is offline   Reply With Quote
Old 02-28-2016, 08:03 AM   #367
50bomb
50bomb's Avatar
Thanks. The color is starting to fade but I still like it.
Old 02-28-2016, 10:01 AM   #368
arky hauler
Jysaint, I used a later model front end with disc brakes then drop spindles for 73-87
Old 02-28-2016, 10:23 AM   #369
JYSaint
Thanks Arky for the quick reply!
Old 03-06-2016, 03:03 PM   #370
txinliner
txinliner's Avatar
7 6 1/2 drop
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390
txinliner is offline   Reply With Quote
Old 03-06-2016, 09:44 PM   #371
Eric15chevys
Eric15chevys's Avatar
Another cool Arkansas truck. I am from Conway. My 62 came from there.
84 GMC One ton 4x4 454 4 speed
62 Chevy C10 short fleet
plus about 13 previous gm trucks
from 1960 to 2000
Eric15chevys is offline   Reply With Quote
Old 03-08-2016, 12:21 AM   #372
JYSaint
Originally Posted by 66clow View Post
ccp drop springs, notched in rear
Could you post more pics and tire specs?
Love it
http://www.junkyardsaintscc.com
1966 GMC 1000
Old 03-08-2016, 09:24 PM   #373
C/10 King
C/10 King's Avatar
My latest.... a 66' with a 63' grill....
The Blue Leopard with its new look, a bunch of coils cut in the front and 2 inch blocks with 5 inch dropped coils in the back... all the work done by forum member "Kev's Classic's"
BTW.... I do not call this "PATINA" the sand down job was not my idea, this is good candidate for a paint job.
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 03-08-2016, 10:28 PM   #374
60chevyjim
60chevyjim's Avatar
this is a true static drop .
I took out all the springs and bump stops so it's sitting bottomed out .
there is no driveshaft in it . the engine runs real good , im not shore what year it is
the valve cover don't have Chevrolet embossed on it
and it has a vent hose on the left front side of the valve cover.
the engine compartment wiring and dash wiring is totally trashed
so it won't even yard drive yet .
I just wanted it to look cool until I get a chance to start on it.
I picked up a complete 79 front 5 lug cross member and the 5 lug rear with highway gears. I got 2 eight inch 5 lug truck rallys for the back ,
now I want to find 2 seven inch 5 lug truck rallys for the front
I need to pancake the 79 cross member before I put it in and get some C notches
before I put some springs in it.
Old 03-08-2016, 10:43 PM   #375
JYSaint
I took measurements on my truck today. As far as I know it hasn't been dropped at all. It's a 1966 GMC with rear leaf springs. Front from middle of rim to fender front was 19 inch and the rear was 22 inches.
1966 GMC 1000
