#351 |
Re: Power Brake Booster Adapter Bracket
Sent you an email about a purchasing a power brake bracket for a 66 c10. Thanks Ryan.
#352 |
My Gmail is messed up it wouldn't let me open your message, I sent you my wifes email if you could resend your email that would be great sorry for the screw up. Thanks Ryan
#353 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
I have sent you 2 emails..........
#354 |
Paypal sent, thank you!
#355 |
60-66 Nut
Your booster bracket shipped today as promised.
#356 |
Received my bracket, thanks for a really nice product and fast shipping!!
#357 |
60-66 Nut
Thanks for the compliments........ I appreciate the purchase
#358 |
Captin,if you get a letter from me do not open it,its from my wife!!!! I opened the box you sent in the kitchen........ the shredded paper you used as packing went flying....whoops
#359 |
Captainfab,
Just finished the brakes on my 62 C10 that has a hydraulic clutch - drum/drum. I want to add a booster using your kit including the mounting bracket and wilwood clutch cylinder. I just picked up an early 90's Booster and master cylinder setup from a Chevy 1500. Bolts measure 3 3/8x 31/2 so booster should be fine. Wondering if I can use the mc that is already on it or do I need a different mc. Also from reading previous posts it appears that I can eliminate the proportioning valve since it is drum/drum? Posted a picture of the booster assembly if that helps. Will get my order in as soon as I am sure I have the right parts. Thanks for your help, Paul |
#360 | |
60-66 Nut
This for sale thread is for the '63-'66 standard booster bracket. Here is the thread for the '60-'62 trucks with the hydraulic clutch.
http://www.67-72chevytrucks.com/vboa...d.php?t=362375 You can not use a master cylinder designed for a disc/drum braking system on a truck that has a drum/drum braking system. You need a drum/drum master cylinder and the appropriate booster. With that booster you would have to use a master cylinder for a 1970 Buick Estate wagon with power brakes. Are you still using the original slave cylinder? Quote:
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 05-18-2017 at 11:07 PM. |
#361 |
60-66 Nut
Here is an excellent video showing a power brake upgrade on a '66 C10 using one of my brake booster brackets shown in this thread.
https://www.youtube.com/watch?v=XhVxzGUjq-g
#362 |
How much is your hydroboost brackets? And what hydroboost do you recommend?
Posted via Mobile Device |
#363 |
60-66 Nut
The hydroboost mounting plates are exactly the same price as in post #1 of the for sale thread that is linked in my sig line. Here is the for sale thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=347480 All GM hydroboost units are interchangeable once you remove the factory mounting bracket and install my hydroboost mounting plate. You might look thru the for sale thread and see what application others have used for a hydroboost.
#364 |
I saw you have a master/clutch master adapter for the 60-62 trucks, but do you have a similar setup for 64-66? I've got a 66 gmc that I'm putting a t56 in and your bracket looks like a cure for the headaches I'm having getting the clutch master figured out.
14 Silverado- 4/6 drop daily 66 GMC short wide Custom Cab- building to be low and cruise. 4.8/t56 swap occurring now. Stupid low static drop ![]() 66 GMC 1 ton stepside looooong bed- the tow pig/work truck. |
#365 |
60-66 Nut
Yes I do make a booster bracket with a hydraulic clutch conversion for the '63-'66's. Here is the for sale thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=651200
#366 | |
#367 |
60-66 Nut
Here is a thread with some good info on lengthening the booster pushrod and some plumbing pics.
http://www.67-72chevytrucks.com/vboa...d.php?t=740378
#368 |
60-66 Nut
All of my booster brackets now come with slotted booster mounting holes to also accept aftermarket universal boosters with the 2-3/8" x 2-3/8" center to center mounting studs.
#369 |
#370 |
60-66 Nut
Sorry but I simply do not have time for phone calls, nor can I take your payment over the phone. Purchasing instructions are in post #1 of every one of my for sale threads. Send me a PM or an email and I will be happy to get you take care of. I went ahead and sent you a PM.
#371 |
60-66 Nut
I am officially notifying everyone that I will be on vacation from 02-05-18 thru 02-13-18. I will do my best to get all orders built and shipped before I leave, if placed by 01-31-18. Orders placed while I am gone will be built and shipped in order of receipt of payment once I return. Thanks for understanding.
#372 |
do I need those brackets for either of these boosters?
my truck is a 66' Chevy C10. Im trying to choose between CPP or POL. Which will fot better? |
#373 |
60-66 Nut
If you want to mount your brake booster correctly and without drilling holes, you will need one of my booster brackets. If you do not care about either of those criteria, then just use the universal mounting bracket that comes on the booster/ master assembly that you purchase. To my knowledge both companies sell the same universal booster which should fit any of my booster brackets.
#374 |
![]() Join Date: Apr 2014
I need a bracket for my 67! Pm sent
1972 Cheyenne super 1949 3100 |
#375 |
60-66 Nut
