Old 12-24-2013, 07:41 PM   #351
mcbassin
Still Learning
mcbassin's Avatar
Re: 86 Silverado Father and Son project
Nice !
mcbassin is offline   Reply With Quote
Old 12-25-2013, 12:26 AM   #352
Crash_OK
Crash_OK's Avatar
Looks great... Getting closer..
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 12-25-2013, 02:03 PM   #353
rfmaster
rfmaster's Avatar
Crimp and solder? Or just crimp???
As you said - check, check again and insert!
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 12-25-2013, 02:26 PM   #354
EightiesOnly
EightiesOnly's Avatar
Originally Posted by mcbassin View Post
Nice !
Thanks guys, and I'm real close now.
//RF
Definitely crimp and solder. And once you insert they're tough to get out without a tool made for it.
LC.
My Truck Build (1986 LS powered c10)
EightiesOnly is offline   Reply With Quote
Old 12-29-2013, 12:53 AM   #355
EightiesOnly
Update time
I ended up doing what I drew for the fuel system, except I'm using the original steel lines behind the switch from the 86 and high PSI rubber from the tanks switch to the pump and from the pump to the engine. Also probably high PSI rubber for the return. Gonna see how that works out. If it doesn't I'll likely put two in-tank pumps in and run a high pressure switch.
Anyway, it's stabbing time!
More to come in the morning.
LC.
Old 12-29-2013, 01:56 PM   #356
scotts62
One day...
scotts62's Avatar
Scott
93 crew cab build
Project 62
Old 12-29-2013, 04:48 PM   #357
EightiesOnly
Well the heart surgery is complete.
All I lack now is hooking up the fuel lines, driveshaft, trans lines, power steering, heater hoses, throttle cable, shifter linkage, and a few wires. Then we should be driving. It's quite a bit to do, but I got time.
LC.
Old 12-29-2013, 05:52 PM   #358
scotts62
One day...
scotts62's Avatar
Awesome!!!
When you get yours done come help with mine
Scott
93 crew cab build
Project 62
Old 12-29-2013, 11:02 PM   #359
mcbassin
Still Learning
mcbassin's Avatar
Old 12-30-2013, 12:04 PM   #360
rfmaster
rfmaster's Avatar
Are you going to move starter main feeds to passenger side?
AC - you have non AC engine in AC equipped truck - any plans?
Your photos of doing this swap during winter break brings out old memories (of doing the same some 30 years earlier! ) Keep on going.
//RF
"The Beast"
Old 12-31-2013, 02:39 AM   #361
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Looking good guys!!
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 12-31-2013, 09:44 PM   #362
EightiesOnly
//RF
For the main feeds I got a longer cable and routed it over to the battery, which I left in the original position.
For the AC I'm gonna adapt the compressor to the old dryer, but I'll worry about that in the spring.
LC.
Old 12-31-2013, 09:55 PM   #363
EightiesOnly
Alright it's ALIVE!!! I got most of everything wired and hooked up and it fired up first try!
Soldering
I still have to do the exhausts and either shorten or adjust the throttle cable. I also am going to use the TBSS manifolds that my dad got a while back, instead of the truck manifolds. The truck manifolds had the normal passenger side issues and the driver side manifold dumped into the bottom half of the frame.
Pics of the drivers side.
LC.
Old 12-31-2013, 10:21 PM   #364
Crash_OK
Crash_OK's Avatar
Great News... Looks great.
Mark
Crash's 69 4x4 SWB
Old 01-01-2014, 12:10 AM   #365
scotts62
One day...
scotts62's Avatar
Awesome, congrats
Scott
93 crew cab build
Project 62
Old 01-01-2014, 01:18 AM   #366
mcbassin
Still Learning
mcbassin's Avatar
Setting up this casting for oil sending unit to drill.
Old 01-01-2014, 01:22 AM   #367
mcbassin
Still Learning
mcbassin's Avatar
Drilled
Old 01-01-2014, 01:25 AM   #368
mcbassin
Still Learning
mcbassin's Avatar
Tapped
Old 01-01-2014, 01:28 AM   #369
mcbassin
Still Learning
mcbassin's Avatar
Done
Old 01-02-2014, 09:27 AM   #370
Low Elco
Woo Woo! Good news!
Low Elco is offline   Reply With Quote
Old 01-02-2014, 06:08 PM   #371
EightiesOnly
Originally Posted by Low Elco View Post
Woo Woo! Good news!
Yes but with good news comes some bad...
The driveshaft is too short
Not a huge deal but just more $$$$$$.
I got some new mufflers, they were cheap but so am I.
Got the oil pressure sending unit installed
The power steering lines from the '94 TBI were a direct bolt in so that's good.
LC.
Old 01-02-2014, 07:48 PM   #372
scotts62
One day...
scotts62's Avatar
Looking good! I like the sending unit
Scott
93 crew cab build
Project 62
Old 01-02-2014, 09:23 PM   #373
mcbassin
Still Learning
mcbassin's Avatar
Thanks Scott.
Old 01-03-2014, 03:33 PM   #374
EightiesOnly
Alright, so earlier when I said it fired right up, it did, but it would die after about 3 seconds. We figured it was just the O2 sensors struggling with adjusting to the open exhausts. We tested the fuel pressure at the rails and it was like 14 psi. So, we tested the voltage to the fuel pump and it was like 7v. It turns out we needed to flip the orange power wire and the green PCM signal wire on the relay.
So know it's truly running under its own power!
Here's a little start up vid...sorry about the terrible filming.
LC.
Old 01-03-2014, 03:40 PM   #375
mcbassin
Still Learning
mcbassin's Avatar
Nice video!
