#351 |
Re: 60-66 Tire/Wheel Pics
It's the weld joint.
You can find me on Instagram @neveno_cten |
#352 |
Few more shots.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
#353 |
![]() Join Date: May 2007
love it! huge fan of big billets!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#354 |
#355 |
Not really. Went to set doghouse on and lower sheet metal made contact with upper bag/arm mounts. Could cut but rather sell my nice parts. I'm committed, if it has gone this far lay it out. I will fab some inners, rear tubs or like. Just got it on ground. New tko 600 trans to replace t5. This is ride height.
#356 |
Fender contact.
#357 |
I have the stock 15" steelies with 56 chevy bel air hub caps.
#358 |
Looks great! Perfect setup. Get that hood on and outside for more shots. Lol
Chris
1966 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=615165 1968 GTO http://67-72chevytrucks.com/vboard/s...=1#post7650182 |
#359 |
Did you have to trim any sheet metal to fit the rear wheels in there? Very nice stance/tire/wheel combo!
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
#360 | |
Hood? I don't have new trans yet! Figure if I were to order new trans someone would call for job. Yep back to work. No more screwing around. New Porterbuilt hinges needed.
#361 |
well I don't have tires mounted or mounted on the truck ...should be mounted this coming up week ...but ill post what im putting on my ol beast ..not thru cleaning them up yet but you get the idea
66' Short Stepper- 350-NP440/4speed Under Construction - http://67-72chevytrucks.com/vboard/s...d.php?t=629426 |
#362 |
sixTsix,
Nice choice! ![]() How wide are your rims? I assume they are 15". Going with black walls or raised white letters? Mine are from a Jeep Wagoneer and you can see minor differences.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
#363 |
Yep, fan of the old school slots. One reason I chose Salt Flats.
#364 |
I got my slots for CHEAP. Otherwise I'd get the Salt Flats. Love that look. What size rim and tire is that on yours?
#365 |
That's a 295/45/18 on 18x9.5 Fronts are 245/45/18 on 18 × 8. Watched Trucks and their F100 is running same rear tiresults little widerwider fronts.
Guy down the street had a 65 that got wrecked but would not get rid of 15x10s
#366 | |
I'm starting to like the 18" all around better than me thinking I might do 20/18 offset or 20/20. Looks great LVPhoto's! |
#367 |
I just got the Porterbuilt crossmember in. The inners would have to be trimmed to clear bag mount/ upper arm mount. As for turning I would think it might be problem. I did use drop spindles so if you didn't want ride height so low...I bought rims as standard offset, still cost me custom price. The rear is a 70s 1.5" wider.
20s all round same size so you can rotate. I went for 28" tire for 3.73 gears and overdrive to get 2200rpm at 75
#368 |
You should probably get shorter valve stems put in when you get tires mounted.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
#369 |
![]() Join Date: Jun 2011
i had the 3" stainless trim rings until i broke the rear end last month. i pulled over to a parking lot and left the truck 20 min. came back to one missing. so my buddy Alan gave me a set of the 1 1/2" stainless trim rings and i like them better. i think it shows off the rim nicer.
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
#370 | |
Well It will either be Cooper Corbras or BF TA ...Raised letters all the way around. I am still going back and forth on size though. 255/70 or 255/60. well I guess ill find out this week hahaha... I've always love slots. What my pops always ran on his rides so it was a no brainer decision ya know. I'm not sure what brand mine are. The only markings I have found is the size and weight capacity stamped on the back. I do know they came off a 70 c10, so I can imagine from the way they look that they are era correct. They are 15x7, 3 3/4 BS. I'm also not going for mirror finish either. I'm going for the semi gloss finished like they were new. Regaurdless I'm very excited I found them in 6 lug in a 15x7 for a ok price..instead of the more common 15x8.5 or 15x10 in six lug. Best part is these have basically zero curb rash so I got a good deal. Soon as I have them mounted I snap some pics.
66' Short Stepper- 350-NP440/4speed Under Construction - http://67-72chevytrucks.com/vboard/s...d.php?t=629426 Last edited by sixTsix; 01-25-2015 at 09:34 PM. |
#371 |
Yea I will have metal short valve stems install when I have them mounted. One of them alrdy have a short metal valve stem installed. so that's what im going to get.
#372 |
Love me some slots. Would like to find a set of 16" just like running that size tires.
#373 |
Heres my wheels
#374 |
Here's a video of my slots IN ACTION for the first time.
#375 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
