#351 |
Re: The 6.0 Silverado Build
WOW! That looks great man. This has convinced me to use that chassis paint. So did you end up using 2 whole quarts? Did you just brush it on? Good job.
#352 |
Looks awesome man!
#353 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Used one quart. I am not as happy with the results as the last time because I used a cheap brush and you can see more of the brush marks. But it is already as hard as a rock and I figure I can spray it later to give it a nicer look if I want. I think it'll be just fine for a driver. Thanks for all the nice words fellas.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#354 |
Well it rolls again.
#355 |
AWESOME!!!!!
![]() Those are "right click save" pics right there. |
#356 |
One day...
Very nice!!!!
#357 |
VA72C10
![]() Join Date: Mar 2008
Looking great! You're making great progress on it!!!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#358 |
Good job man. Watching you is making me want to get started so bad.
#359 |
Still Learning
Looking good! Coming together nicely!
#360 |
Thanks guys, been a busy and long day so I'm not sure if the drivetrain will go back in tonight or not but by tomorrow at the latest. Still debating running one tank or not. What do you guys think. If I had the wiring for a 87 from the firewall back it would sure be alot easier.
#361 |
AWESOME! getting after it I see
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
#362 |
i'd keep the duel tanks buddy... that way when you get to a half tank just switch it over so your not worring about not having the '87's baffles. and think about the gas tank door needing filled and the tank switch on the dash too. just my couple pennies
#363 |
I'm not worried about the baffles. I have two new 87 tanks, two new 87 senders with new high pressure pumps, new high press. switching valve, etc. My only concern was how to wire the pumps to switch on and off with the position of the switching valve and only use one fuel pump relay. I guess I just need to find someone parting out a 87 that had dual tanks and get the wiring. Well, off to post in the classifides.
#364 |
Oooh yeah, I quit school 'cause of recess!
#365 |
Thanks Josh. Man that frame is lookig good!
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
#367 |
The little man decided he wanted to work on "daddy's" truck so as any good father would say, heck yeah, so the engine and trans are now back in the chassis permanantly. The tanks are next with the wiring for the fuel system and then the cab goes back home for good!
#368 |
One day...
Very cool! I would love to do that engine and trans setup in mine but then i would have to change some ideas
#369 |
thats is awesome! cool seeing your boy getting involved
![]() what did you have to do on the tranny cross member? looks nice and clean!
#370 |
It's a simple piece of 2x2 square tubing 1/4 wall thickness. Definately not going anywhere! Very simple and cost effective too!
#371 |
Looks great! It looks like your boy has square body fever too. Hey, what kind of tires are you running? I need a new set for my TBSS and I like the tread pattern on those.
#372 |
Toyo Proxess. Seem to ride pretty good too.
#373 |
Thanks, I'll see if I can get those at work tomorrow. What size are you running on your 86? I may need some for it too.
#374 |
Slots go on anything!
Looks good, Josh. What gears are you going to go with?
1974 Jimmy- 5.3/4L80e/NP241 |
#375 |
Jeramy, I am running 295/40r20 on the rear and 255/40r20 in the front. Jonboy, I am running 3.42 gears for now but I am thinking I would like to find a rear already set up with 3.73 gears instead.
