Old 01-20-2011, 04:27 PM   #351
robnolimit
robnolimit's Avatar
Re: Make it handle
I'm not sure about our race schedule yet. Tina's Mustang will be done soon, and we'll want to get it out too. --- I did'nt even think about changing the oil .
StevieB, I'd have to sat that Herb Adams book on suspension/handling is the building block to all performance. And it will take a few readings. There are others, but this one is really good.
robnolimit is offline   Reply With Quote
Old 01-20-2011, 05:31 PM   #352
Hotchkis
Re: Make it handle
Rob,
We look forward to seeing you and your new projects! Let's make 2011 the best yet!
Hotchkis is offline   Reply With Quote
Old 01-20-2011, 11:37 PM   #353
Mechanic77
Re: Make it handle
Herb Adams Chassis Engineering is never too far out of my reach
Pro Touring 1964 C10-Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=441627
Project '65 Short Step Daily Driver http://67-72chevytrucks.com/vboard/s...d.php?t=661948
Mechanic77 is offline   Reply With Quote
Old 01-21-2011, 09:22 PM   #354
76kcfdeng
Re: Make it handle
Rob, here are some pics of the lower A arm moved forward an inch and how I did it. I would appreciate any thoughts on the good and bad of it. I mocked it up and cycled the suspension and steering with no issues I can see. I ground a notch in the lower cross arm an inch over from the stock dimple and cut the A arm for clearance. Did this to an old cross arm for a test, I did use my new drop spindles.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
At bumpstop, tested steering lock to lock
[IMG][/IMG]
70 Chevy SWB Fleet Project.
06 Lancer Evolution MR SE, stupid fast!
03 Ford f-250 crew cab, 6spd, diesel
56 ford f100 project
My build thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=426739
76kcfdeng is offline   Reply With Quote
Old 01-21-2011, 10:36 PM   #355
robnolimit
robnolimit's Avatar
Re: Make it handle
looks like it should work fine. I like it. There will be a small amount of spring shift from the lower pocket, but no issue. How long before you drive it?
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
Old 01-21-2011, 10:40 PM   #356
calvin78612
calvin78612's Avatar
Re: Make it handle
Just got my copy of Herb Adams chassis engineering yesterday,so far a great book with lots of info.
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 01-21-2011, 10:59 PM   #357
76kcfdeng
Re: Make it handle
Thanks Rob, I hope to have it driving in a few months. Depends on how much body work I want to do before I put it together, LOL. I may paint the firewall and prime the rest so I can drive it for a while and continue the body work. I thought about the spring pockets not lining up but came to the conclusion it would not be an issue. Still working on cross bracing the frame, have to make sure everything will fit.
My build thread.
Old 01-21-2011, 11:44 PM   #358
bedsled71
bedsled71's Avatar
Re: Make it handle
does anything have to be done to the top control arm?
bedsled71 is offline   Reply With Quote
Old 01-22-2011, 12:10 AM   #359
76kcfdeng
Re: Make it handle
Bedsled71, nothing needs to be done to the upper arm, according to Rob 1" forward on the lower arm should net 7 degrees caster.
My build thread.
Old 01-22-2011, 01:20 AM   #360
tomtuna1978
Re: Make it handle
so then what dose it do for the wheel being centered in the wheel well ? will it be 1 in. forwrd ? how will it look ? ... this looks like simple way of improving the alignment !!! and im verry interested in this as id like to improve my alignment !
tomtuna1978 is offline   Reply With Quote
Old 01-22-2011, 01:33 AM   #361
robnolimit
robnolimit's Avatar
Re: Make it handle
with a dropped spindle, the wheel will move forward about 1/2 of the lower A-arm shift. So, about 1/2".
Old 01-22-2011, 01:49 AM   #362
tomtuna1978
Re: Make it handle
1/2 in. wont look bad ! ... so ...to get this rite ... if i move the lower control arm forward 1 in. and put on a drop spindle it will give me aprox. 7 deg of caster ? ... this is a cheep mod ! does it matter what size (2,2.5,3 in. drop) drop spindle i use ? id like 3 if i could get some.
Old 01-22-2011, 01:59 AM   #363
76kcfdeng
Re: Make it handle
Does not matter the drop, caster will be the same. It will move the wheel forward different amount depending on the spindle but a small amount no matter which, 1/2" or less.
My build thread.
Old 01-24-2011, 12:22 PM   #364
solidaxel
solidaxel's Avatar
Re: Make it handle
Here's a quick lesson. BEFORE you go to the dyno shop, check to make sure that the throttle blade goes to WOT when you push the pedal to the floor. To be honest, we never did. First full pull was 331 rr whl hp. WHAT? then, we adjusted the cable/linkage to get full throttle (I felt like a 6 yr old that spilled the milk). Next pull, 428 hp. After a bit of tuning, 443 hp, 468 ft./lb. Crap, i've been running all year on about 5/8 throttle. I will say, it's a lot faster now. So, check the simple things. Have a great weekend.
I think they call that a "govener" that was needed for the "break in period" on your truck !!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-24-2011, 12:58 PM   #365
robnolimit
robnolimit's Avatar
Re: Make it handle
GOOOD MORNING !!! A little help here. Just for my own info, did you guys like the drawings last week? Does that type of thing help?let me know. thanks.
Old 01-24-2011, 01:06 PM   #366
dirtball
dirtball's Avatar
Re: Make it handle
The drawings really help me out. Really appreciating all the info you are sharing here.
Brett
dirtball is offline   Reply With Quote
Old 01-24-2011, 01:23 PM   #367
gcrtech
Re: Make it handle
Awesome stuff in this thread!! I'm new here but I've been been working on old Chevs for years. Currently working on a 66 SWB for the street and a 68 GMC for roadrace/rally fun. Preparing for a race called Targa Newfoundland, check it out at www.targanewfoundland.com.
I raced late model stock cars fo 20 years so some of this stuff is familiar, but I really like the truck specific stuff like swaybar sizes, alignment specs, etc.
Rob, I'm trying to decide on spring rates for the roadrace truck. I'm thinking 600lb front springs with a 1.25 inch sway bar and 175lb rear springs and a 1.00 rear bar. The race is held on public roads which can be quite rough. I am guessing shocks will be very important too and I was thinking about running Afco stock car shocks because I have some experience with them. Let mee know what you think would be a good setup. Thanks
gcrtech is offline   Reply With Quote
Old 01-24-2011, 01:37 PM   #368
dirtball
dirtball's Avatar
Re: Make it handle
Looks like this could be a good time to ask something that I have been scratching my head over. On the Hotchkis site, they show that their spring rates for 67-72 trucks are 1100/380 lbs/in! Those rates sound extremely high to me, I can't afford to drive down the road and knock the fillings out of my teeth. What do you think of these rates Rob? I gather you like the soft spring/ big bar approach. Hotchkis is using a 1 1/4" front bar with those springs in the TVS kit. The other question is about them using a 4" drop spring and no dropped spindle. I don't see that as being an ideal set up. Thanks for all your input Rob!
Brett
Old 01-24-2011, 03:27 PM   #369
4x4fab
Re: Make it handle
I def. like the drawings, helps me to understand things.
I'm in the middle of my build, Chopped 64' SWB. It will be bagged on a dropmember and linked rear, prolly parallel 4 link...?..........
I have the frame on the chassis table right now, finishing the notch and started bending some 1.75 x .120 dom to stiffen the frame up. My question is if I should spend the time boxing in the frame? this isn't going to be a race truck, just want it to handle nice and I have the ability, no how, and tools to do it right. I know there is more to it than just fully boxing the frame, and I'd love to learn more.
Thanks a lot for sharing your knowledge, I've read this thread 3 times now.
4x4fab is offline   Reply With Quote
Old 01-24-2011, 05:14 PM   #370
robnolimit
robnolimit's Avatar
Re: Make it handle
Spring rates for stock style C-10's seem high, but this is do to the A-arm ratio. Here are some stock spring rates
Moog # 6082 722 lbs/in 6 cyl, and light v-8
Moog # 6542 842 lbs/in std v-8
Moog # 6102 1015 lbs/in bigblock, longbed c.s.
Moog # 6104 1016 lbs/in 3/4 ton, sits 1/2" higher than #6102
Moog # 6454 1060 lbs/in 3/4t bbc, c.s, 1ton
So, Hotchkis' 1100lb may not be so heavy. I currently have the #6082 spring with one coil cut in the JT project, and it is too soft for me. I'm going to swap in the #6102 springs next week. Going to track test it tues. with the soft springs. All my number crunching shows me a 950 spring, but we'll see.
When it comes to frame boxing, i'm not a big fan of full chassis boxing, as it can lead to a cracked frame. Bracing key areas, and creating triangles is a better aproach, check the earlier posts.
Old 01-24-2011, 05:20 PM   #371
tubbedII
needs more $$$
tubbedII's Avatar
Re: Make it handle
Are you going to cut a coil on the 6102's as well? If so, what spring rate does that put you at?
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 01-24-2011, 05:21 PM   #372
robnolimit
robnolimit's Avatar
Re: Make it handle
Oops, only 1/2 the answer. I do like a softer spring/bigger bar set up. I do a lot of number crunching as a start, then go to the shop, then the track or street. This way I can cut down the development time. It's tough to get the rears to grip. I run a 220 rear spring on the bullit, it's on a rocker arm and the ratio yeilds 180 lbs on the axle. I may try a 200 spring, yeilding 163 lbs. Then it's all shock tuning. So, on a C-10, with the arm leverage and a bit more rear weight, first number crunch shows a 268 spring. So maybe a 300?
Old 01-24-2011, 05:24 PM   #373
robnolimit
robnolimit's Avatar
Re: Make it handle
as you shorten the spring it gets stiffer. I am going to trim them to my liking, and then I'll measure and let you know.
Old 01-24-2011, 05:57 PM   #374
dirtball
dirtball's Avatar
Re: Make it handle
I figured the A-arm ratio had to be playing into it but didn't expect that much. The 1100 lb rate does not sound so high now. So what is your take on a 4" drop with spring only, not in conjunction with spindle? I would like to get rid of my dropped spindle so I could run more B.S. on my 15" wheels.
Brett
Old 01-25-2011, 02:13 PM   #375
robnolimit
robnolimit's Avatar
Re: Make it handle
That brings up a good point. Springs vs. spindles. Lets start with the concept of a stock truck. If you put a set of 2 1/2" drop springs, the truck is lower, and the Roll Center changes (lower) a lot. Looking at the next drawing, first you need to understand the Instant Center. This "point" is the connection of two lines passing through the ball joints and A-arm pivit points. The I.C. is the point at which the mass of the truck rotates to push on the tire in a corner. As you lower with springs, the I.C. of each side drops.
Next is to understand the Roll Center (very important) The tire is grips the ground. So, the force line, or direction of push, on the tire, is the line from the I.C. to the center of the contact patch of the tire. The point where the two lines cross is the Roll Center. Natural "body roll" (without swaybars to control it) is created by the difference from R.C. to the Center of Gravity. We can estimate the C.G. of these trucks at about 2" above the cam shaft. The farther the R.C. is from the C.G., the more body roll, = less traction. There can be some positve benefits from shorter springs, such as more agressive camber gain, but once the lower ball joint is higher than the lower A-arm pivit, your loosing ground. In casses of really short springs, say 4"+, it is easy to have the R.C. under ground, not good. The goal is to get the R.C. as close to the C.G. as you can. When you drop with a spindle, the R.C. is not effected as much as when you drop with a spring. Just a note, Z'ing the frame up, - or - raising the crossmember may be the best aproach for handling in these trucks, as you get the lowering (lower C.G.) without lowering the R.C. - food for thought.
