Old 03-05-2012, 11:20 PM   #351
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Project...praise the lowered
sweet build....subscribed!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 03-05-2012, 11:31 PM   #352
67cheby
67cheby
67cheby's Avatar
Looking good
67cheby is offline   Reply With Quote
Old 03-06-2012, 06:38 PM   #353
(joey)
(joey)'s Avatar
man you guys are making my view count sky rocket.i never imagined my build would have so much attention.i look forward to checking out the comments every day.thanks.
now on with the show,heres a peak of the intake cover i started to build.all stainless steel and will be fully functional as a ram air system.should get some attention peaking through the hood.i will also make a sheet metal fuel rail cover.something like the covers on the ls1`s
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain)
http://67-72chevytrucks.com/vboard/s...d.php?t=434253
(joey) is offline   Reply With Quote
Old 03-06-2012, 08:54 PM   #354
67cheby
67cheby
67cheby's Avatar
Sweet !! Nice tpuch
Old 03-06-2012, 09:12 PM   #355
68GMCCustom
so if its going to work as a ram air..... your sheetmetal box/intake will house the filter also?
Kurt -
Old 03-07-2012, 12:06 PM   #356
(joey)
(joey)'s Avatar
i should have said it will be like a ram air/frech air system.if you look close in the pics you can see a duct i started to build over top of the throtel body .the plan is to run that into a housing/cover over a cone style filter.but like everything else i do on the build i will probably change my mind 10000 times haha.
Old 03-07-2012, 03:49 PM   #357
DorianB
DorianB's Avatar
Just read through the whole thing and it is very similar to what I want to do!
I am in awe of your fabrication skills!!!!!!
Amazing progress and I look forward to more updates!
DorianB is offline   Reply With Quote
Old 03-07-2012, 05:02 PM   #358
imsuchaman55
imsuchaman55's Avatar
Awesome build. Im subscribed to see how this ends up!
imsuchaman55 is offline   Reply With Quote
Old 03-07-2012, 06:56 PM   #359
(joey)
(joey)'s Avatar
thats a long read from start to finish.i hope it inspired some ideas for your build.as for fabrication,its all patients and fine tuning.and the payoff in the end is well worth the blood and sweat.
the way i have been going lately the end is getting closer and closer by the day.welcome aboard
Old 03-08-2012, 03:03 AM   #360
smoknbarrels
Registered Mail
smoknbarrels's Avatar
geez, you sure have some awesome fab skills!! I can't believe how much work you've done on this thing! gotta see how this ends up. that shotgun intake is gonna look killer.
smoknbarrels is offline   Reply With Quote
Old 03-08-2012, 05:46 AM   #361
slick copper
slick copper's Avatar
Sweet idea man! I'm sure you'll get it tweaked to you liking. Always do. I agree that polished ss shotgun style sticking out of the hood against that black is gonna be bad @$$!
Raymond
1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594
The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939
Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402
slick copper is offline   Reply With Quote
Old 03-08-2012, 06:16 PM   #362
(joey)
(joey)'s Avatar
Red face Re: Project...praise the lowered
it was a ton of work.but i loved almost every minute of it.now its getting close to complete enough to drive im not sure what i will do with my spare time.hmmmmmmmmm
i had some time to play around with it after work before the wife picked me up.i grew a set and started cutting the hood a little at a time until the double barrel stuck through.but it still needs some tweaking.the front sits a little too high and i have to shift it to the left a little.but not bad for a 20 min hack job.i should have time tomorrow to adjust it then on with the polishing.it should look good all said and done.heres a couple teaser pics
Old 03-08-2012, 07:30 PM   #363
68GMCCustom
yeah....needs dropping a bit in the front, but looks great!
Kurt -
Old 03-08-2012, 08:11 PM   #364
oldman3
oldman3's Avatar
X2, if you could get the two barrels about level with the front of the hood opening, yes, no, I'm sure you will get it right.....Jim
oldman3 is offline   Reply With Quote
Old 03-09-2012, 07:24 AM   #365
slick copper
Cool!
Raymond
Old 03-09-2012, 05:54 PM   #366
(joey)
(joey)'s Avatar
i did a little more tweaking and fine tuning today.with so many wires and hoses being housed under the cover it was a pain to get it adjusted right.so i dropped the front down as much as i can and moved it to the side more.i also had to shift the front clip to the passenger side a little to square it up with the hood.so now on with the hours of sand/polishing
Old 03-09-2012, 06:48 PM   #367
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Nice shotgun inspired scoop/..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-09-2012, 09:22 PM   #368
oldman3
oldman3's Avatar
I think it looks a lot better, nice job....Jim
Old 03-09-2012, 10:58 PM   #369
72blueshark
72blueshark's Avatar
beautiful build, your fabrication is amazing, do you mind if we ask what you do for a living?
72blueshark is offline   Reply With Quote
Old 03-10-2012, 08:09 AM   #370
(joey)
(joey)'s Avatar
thanks guys.as soon as i get it polished like chrome i will snap another pic.
dont mind at all blueshark.im a welder but grew up doing body work with my father since i was knee high.
Old 03-11-2012, 03:00 PM   #371
(joey)
(joey)'s Avatar
back at it today.this morning i was able to get the bed floor completely welded and buffed smooth ready for primer.now i can start making my front bed panel/compartment.then this afternoon i hand sanded my hillbilly engineered scoop until my arm was ready to fall off then it was on with the polishing.it has some low spots where it was tacked on the underside but when i was done polishing they didnt look nearly as bad.i still have some areas that need attention but i will wait for the final round because im sure its going to get dinged up.here is a couple of pics
Old 03-11-2012, 06:55 PM   #372
oldman3
oldman3's Avatar
Looks absolutely great....Jim
Old 03-11-2012, 07:06 PM   #373
68GMCCustom
wow that polished up nice! I know how HARD it is to polish stainless.
Kurt -
Old 03-11-2012, 08:06 PM   #374
67cheby
67cheby
67cheby's Avatar
Great job
Old 03-11-2012, 10:45 PM   #375
Tinkermc
I just read it all from front to back. Real good work and a good mind How long did it take to get from A to here? Keep up the challenge, results are GREAT
Tinkermc is offline   Reply With Quote
