#351 |
![]() ![]() Join Date: Jan 2011
Re: Project "Funky Monkey"
Did you check to see if the cheerleader was sitting on the hood? .. maybe?
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
#353 |
Looks like it opens about like mine Brian.I like it and if you need it higher you can take the struts loose and get the cheerleader to hold it up!
#354 |
Nate thinks I must have a defective strut. He is sending new ones. I hope those work.
other good new I believe I have worked up a deal to sell the other frame from under the 68. I got a warning from my HOA that I have to move it within 10 days. AND today I got some new 67 triplus fenders to mount my new Slosh Tubz to. ![]()
Never wrenched a day in my life and now... Im doing a frame off restoration on a 1968 C10 with a Porterbuilt Dropmember, Acuair E-Level kit, Boyd Welds Gas tank and mild c-notch. Click here to view my build |
#355 |
![]() Join Date: Dec 2006
Brian let me know how the quality of those Tri-Plus fenders are. I might be going that direction as well instead of tying to fix mine.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#356 |
![]() Join Date: Mar 2011
Brian, make sure to check the crown of the fender to the hood. The repop fenders I got for the 67 didn't have the same crown, it was more flat, just my 2 cents....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#357 |
Still Learning
Very clean install of the hinges and firewall shave. Sorry to hear about the issue with the struts. I've been thinking about designing some hinges for my truck. Keep up the progress.
#358 |
JRods Garage
DAAAAAAMN son! Love the build... Gonna keep up on this one
#359 |
They didn't match up too well in the front. I am just going to use my factory fenders for the Slosh Tubz. here are a few pics.
#360 |
I do have some good news... I have the motor, inside the cab and the rear all wired up and ready to go. After I get the fenders and tubz installed I will be able to run the front lights and the wiring will be complete!
#361 |
Truck and auto performance nut
my right front does the same thing..........guess you just pull it and look for a decent OEM?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#362 |
sneak peak... one Slosh tub kinda in. I love the way they look. very smooth and clean. I did an ok job cutting the fender. it made me really nervous cutting that out. its bot perfect but I hope it will work. tI didn't realize I couldn't run my factory battery tray. so that's going to set me back a little more. being the noob I am this seems to be a bit of a challenge. hopefully I can find an easy solution for this. I was thinking battery in the back but I just finished all my wiring this weekend so I hate to pull all that back out and rerun it back down the frame to the rear. any help would be greatly appreciated.
#363 |
67cheby
![]() Join Date: Sep 2008
LOOKS KILLER ...as far as the battery ?? they look so much better hidden in the back ! maybe one of the kinetic batteries that are much much smaller ?
#364 |
I may just go with a rear battery. The tub has a little gangster lean to it in the pic... I hadn't bolted up the bottom of the fender yet. Well now on to the drivers side.
#365 |
67cheby
They do have somewhat of a lean to them, because of how the tire cambers when fully dumped
Posted via Mobile Device |
#366 |
Tubz are look great, can't wait to see a finished pic of both installed.
#367 |
FIRED THE MOTOR UP TODAY WITH THE KEY!!!
I'm getting excited now. she's almost there. this is what I have left. add exhaust to that.
#368 |
67cheby
Sweet ! Can't wait to hear my motor fire up !
#369 |
It's alsways something.....
![]() Join Date: Nov 2008
Brian, Did that fitting work on the PS line?
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
#370 |
The end is in sight!!
________________________________ 1972 SWB stepside pro tour build thread http://67-72chevytrucks.com/vboard/s...d.php?t=452840 |
#371 |
I ordered some from nate at porterbuilt and I failed to mention I had a late model powerstering pump. So we have to order another set. I would much rather use something clean than trying to weld those two together.
#372 |
this is an awsome build funkytechmonkey i hope one day i can start my build
#373 |
Brian - you planning to paint this truck, or stay with the red? The paint looks good now, but just curious.
#374 |
I will be painting it. Yea from far away the paint looks good. But when you get up close to it there are a ton of things wrong with it. I will prob stay with the same color.
#375 |
I just reqd from start to here. For a rookie you have done an amazing job. The dark blue you mentioned in the beggining should look reallly nice. Wheels were a real nice choice. keep it up
