12-07-2012, 12:26 PM | #351 | |
Re: Project Goldilocks, '66 C10 SWB BBW Build
The front edge of the hood has rust and I'll probably go ahead and pull the vent boxes off the sides of the cowl like pdxhall did in his build thread to make sure there no rust hiding in there. Other than what little rust it has, the only other "major damage" is the extra holes drilled in the doors for west coast mirrors. The guy that owned it it's whole life owned the downtown Esso station and kept it inside when they didn't had an open stall. He must have pampered it since the inside of the bed is very straight and even the inside of the tailgate only has a few small dings. My dad and some of his friends have said that they remember the truck sitting in that station since it was near their high school. It had about 85,000 miles on it when the PO took it apart.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
12-07-2012, 12:53 PM | #352 | |
Hopefully, you got to pay a good bit less at buying it aready taken apart. It sounds like the PO got a wild hair for a project and then lost intrest. I know its a lot easier to take one apart than redo the parts and put it back together. |
12-07-2012, 02:46 PM | #353 | |
***I edited all of the old post to fix the dead pictures- everything on the first couple pages should show up now***
12-07-2012, 04:17 PM | #354 |
Rollin' Old Skool
how'd you do that? I was told I'd have to start a new thread when my links broke
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
12-07-2012, 04:20 PM | #355 |
Well, I'm glad you got it because with your intention of making it a pro-touring rebel, and your attention to detail, it is going to be off the charts!
I read through your '55 International build thread earlier today. You really are some sort of bodyshop god from looking at the repair work and paint work that you put into that truck! I'm in awe and bowing at your altar of hammered metal! |
12-07-2012, 05:01 PM | #356 | ||
This is what it looks like for me. I'm using Google Chrome, maybe it's different with for other internet explorers? Quote:
12-07-2012, 05:30 PM | #357 | |
You Sir, are big time skilled! I wish you didn't live across the country where I might try to apprentice a little! |
12-07-2012, 06:07 PM | #358 |
chevy only
Always such nice work!! Killer skills kat!
CHEVY ONLY... Nothin Else ! |
12-08-2012, 06:47 PM | #359 | |
I stuck the tach in another tach cluster I restored to check the fit. It's perfect, and the original shift pointers fit! And I also started tearing into the cluster I'll use for the truck. This one came from a '66 parts truck I bought so it'll have the correct water temp gauge. It's also in pretty good shape so it'll turn out better than the other cluster above.
12-09-2012, 12:06 AM | #360 | |
Rollin' Old Skool
btw, the tach looks great!
12-09-2012, 12:11 AM | #361 |
I think you should do a step by step write up on the cluster for the fact section.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
12-09-2012, 12:48 PM | #362 |
I have 2 clusters of parts I am not going to use, so if you need anything let me know. Just dont be in a hurry, anything mailed to you may take up to 2 weeks to arrive from my location to yours.
You would be welcome to anything I have in this regards tho !!
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
12-10-2012, 01:31 PM | #363 | ||
That's strange, maybe you have to be a subscribing member to edit old post? Quote:
Thanks McMurphy, I appreciate the offer! This cluster is complete and I'm pretty sure I'll be able to reuse everything. Now if you happen to have a LS2 block just laying around... I wouldn't mind waiting a few weeks for one of those!
12-17-2012, 06:09 PM | #364 |
More new parts/updates. I'd been looking for a cheap used bellhousing for mock up but those don't exist. Even checked with a local junkyard that checked in their database of ~8000 other junkyards and there were only two available nationwide, one at $200 and one at $240 plus shipping. I found that Tick Performance had new Tremec bellhousings for $199 shipped so I picked one up and it came today.
A guy called today wanting to buy the spindles, brakes, and steering parts that came with the frame so I'll order the No Limit rack kit if he buys my old parts. Gotta get new urethane body and engine mounts too so I can get the engine/trans mocked up and check for floor/firewall clearance. I'm undecided on sectioning the crossmember 1.5" for more control arm clearance at ride height. I wanted to set the engine as low as possible by notching the crossmember for the oil pan but... dropping the whole truck 1.5" might be more effective at lowering the center of gravity? I doubt I can do both since the rack is mounted on the front of the crossmember. I guess I'll need all the parts in front of me to know for sure. Have I rambled enough yet?
12-17-2012, 07:04 PM | #365 |
New aluminum is pretty!
12-17-2012, 09:49 PM | #366 |
I'm surprised it's not polished yet
12-17-2012, 09:52 PM | #367 |
1 thing at a time is progress.
Amazing as always!!
Alan
Philippians 2:14-16 |
12-17-2012, 11:24 PM | #368 |
No polishing for this one, it'll get painted with the factory overspray pattern like I did on the blue '65.
Thanks Alan, hope to get out next show season and see your truck in the flesh. So much detail and inspiration in that build! Posted via Mobile Device
12-17-2012, 11:57 PM | #369 |
I'd be imbarassed to park next to you, but would be honored at the same time. Beautifull work!!
Alan
12-18-2012, 01:36 PM | #370 | |
I'm just glad to be here!
Check out our thread for pictures, we do not have the LSA pan on yet, but the measurements say it will fit without issues. We are redoing the frame mounts for the engine now, so hopefully over the Christmas holidays we can get this put back together with the new pan.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
12-18-2012, 04:43 PM | #371 | |
12-20-2012, 01:02 PM | #372 |
Picked up my trans mount last night and the motor mount kit is on its way. I'm going to make the motor mounts tie the upper frame rail and to the crossmember like the stock mounts. I may chop up the original mounts and use the top half to hide the new mounts so it looks like a factory part.
12-20-2012, 01:43 PM | #373 |
Here is a link to where I got my LSA pan kit....it is a current auction and shows he has 3 left...
http://www.ebay.com/itm/261097128044...84.m1423.l2649
12-20-2012, 05:22 PM | #374 |
Those motor mount pieces look nice. I haven't seen a kit like that where you can locate your own mounting tabs. I went with the Dirty Dingo mounts which are basically the same idea, only the tabs are already welded and the holes are slots for motor location adaptability.
12-20-2012, 05:55 PM | #375 | ||
Looks like clearance would be good with the LSA pan, but I think I'm going to use a 98-02 F-body pan since I can get a trap door baffle that bolts in. http://www.improvedracing.com/oil-pa...ffle-p-30.html Quote:
I thought they were neat too. Two bolts and the engine is out. I found another similar kit that I liked but it didn't have the option to move the tabs around, and the outer tube of the bushing welded to the tabs. The ones I ordered have only a bolt going through the tabs and the outer bushing tube is removable. This was the other similar kit- outer tube welds to engine plate and isn't removable. Both are compact and simple, I didn't really like the ones with a huge rubber/urethane mount with brackets and plates everywhere. The bigger ones probably dampen engine vibration better but I'm not old enough to worry about that yet.
