Old 10-19-2013, 06:10 PM   #351
williamsboys
williamsboys's Avatar
Re: 66 c10 first timer build
I've seen several people on here running the same ser up as far as engine and rad. Could anyone tell me part numbers for top and bottom. Haveing a hard time at the parts store. We have an advance autoparts, orielys,and carquest. Thanks for any help.
Williamsboy
williamsboys is offline   Reply With Quote
Old 10-20-2013, 09:19 AM   #352
williamsboys
Sorry last post didn't make much sense. I have to use my phone to do this so sometimes I screw it up and don't check it before I post it. My question was part numbers for radiator hoses. I don't want to go with the flex hoses. Thanks
Williamsboy
Old 10-26-2013, 07:25 PM   #353
williamsboys
So Ive been trying several top rad hoses and this is kinda close what do yall think. It's dayco 70537
http://
http://
http://
Williamsboy
Old 11-01-2013, 12:21 PM   #354
williamsboys
Well went with a different hose this one I found on the forum. Fits a lot better then what I was finding. It's dayco 70344
http://
http://
Williamsboy
Old 11-01-2013, 04:16 PM   #355
gumbs77
I must say your making me want to get started on my build. It will also be my first. Looks great!! Keep up the good work.
gumbs77 is offline   Reply With Quote
Old 11-01-2013, 04:22 PM   #356
williamsboys
Thanks gumbs. Yea with it being my first it's been a crazy ride so far. Just learning as I go. I've Learned a ton since I've been on this forum. It's going slow but it should be worth it.
Williamsboy
Old 11-01-2013, 10:54 PM   #357
Jeff La
Your doing a great job, can't wait to start mine.
Jeff La is offline   Reply With Quote
Old 11-02-2013, 07:32 AM   #358
williamsboys
Thanks jeff
Williamsboy
Old 11-02-2013, 07:43 AM   #359
northern 85
northern 85's Avatar
Looks great, do you know if the wires are long enough to go down the back of the engine and under the headers?
northern 85 is offline   Reply With Quote
Old 11-02-2013, 08:06 AM   #360
williamsboys
Thanks. I haven't tried that yet. Good point. I was thinking about getting those wire hiders that bolt to ur valve covers, but I need to try your idea. Thanks for the pointer.
Williamsboy
Old 11-02-2013, 08:31 AM   #361
williamsboys
Well I tried the plug wires under headers but there touching in a lot of areas. I was going to get diff wires anyways maybe with the straight connection instead of the 90's.
http://
Williamsboy
Old 11-02-2013, 06:35 PM   #362
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Hoses look good to me!
I have been messing with the same thing lately.
It is pretty amazing how one NAPA employee will look at you like you are speaking a different language when you are trying to describe what you need, and another will take it on as a challenge to help you...and those are few & far between, at least in my neck of the woods!
Modges'66 is offline   Reply With Quote
Old 11-02-2013, 07:52 PM   #363
williamsboys
Yea I hear ya there. Nobody took it on as a challenge I just had to buy and try! I bought 5 top hoses before I got that one. And got lucky with the bottom and got it first try. Thanks for checking my thread out.
Williamsboy
Old 11-02-2013, 09:28 PM   #364
NEWFISHER
NEWFISHER's Avatar
Wires look better. There is a company selling a cap that forces the left bank of wires to the left side aNd thr right bank to the right side. I think its called Correct Cap...lemme google a bit and ill let you know. Its a cool set up
NEWFISHER is offline   Reply With Quote
Old 11-02-2013, 09:31 PM   #365
NEWFISHER
NEWFISHER's Avatar
Check this out:
http://m.youtube.com/watch?v=siguER1...%3DsiguER1hdp4
Old 11-03-2013, 12:13 PM   #366
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Love the finned valve covers!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 11-03-2013, 06:09 PM   #367
williamsboys
O thanks! They look a lot better then those plain Jane chrome ones.
Williamsboy
Old 11-03-2013, 06:11 PM   #368
williamsboys
Yea thanks. That is pretty cool. Watched the video too. Not bad thanks for the heads up.
Williamsboy
Old 12-07-2013, 06:11 PM   #369
williamsboys
So what do you use to cap off all these extra outlets on this tank? I only have one inlet on my fuel pump. Thankshttp://
Williamsboy
Old 12-07-2013, 08:26 PM   #370
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Well one of those will be for the filler hose and some are for breathers so you tank doesn't collapse or expand to much from pressure...not sure how you cap the breathers though...
Old 12-08-2013, 05:36 PM   #371
williamsboys
Yea so if there are 5 holes, 1 goes to the pump, 1 is the filler, so that leaves 3 holes. Any thoughts out there?
Williamsboy
Old 12-08-2013, 05:44 PM   #372
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
I think they can be plugged....not sure. I'll do a little research. Start a thread in the 60-66 forum and see if you get some responses.
Old 12-08-2013, 07:21 PM   #373
williamsboys
Yea ok. Thanks. I looked around and found out that one or maybe two go to the fuller tube for vents. So I'm slowing getting it.
Williamsboy
Old 12-10-2013, 09:23 PM   #374
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
That's right! Now that you mention it! One does goes to the filler tube! I forgot. Mine has an in-cab tank so I don't have to worry about it...So, one for the sending unit, one for the filler neck, and one for the filler neck vent(so to speak), and one more....Ya could probably put two on the filler neck and be fine.
Old 04-13-2014, 08:25 PM   #375
64shortboxchevy
I have the exact same tank kit installed and attempted putting the box on today. One crossmember is directly above the filler neck and rests on the gas tank as u mentioned. What did u end up doing to reinstall your box?
64shortboxchevy is offline   Reply With Quote
