Old 12-04-2020, 09:17 PM   #351
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Re: Polar Bear Suburban
Looks good to me!
DirtyLarry is offline   Reply With Quote
Old 12-04-2020, 09:18 PM   #352
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Larry, the new pieces sure look great! I really like that fixed yoke set up on there.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 06-23-2021, 11:36 AM   #353
Hart_Rod
Hart_Rod's Avatar
Great thread! Bump for an update....
Hart_Rod is offline   Reply With Quote
Old 06-23-2021, 07:36 PM   #354
83GMCK2500
I believe I saw some pictures on IG where he is out galivanting around in the reborn K10, I'm waiting for an update on either of his squares.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 06-24-2021, 12:01 AM   #355
Zoomad75
K5Camper
Zoomad75's Avatar
That he is. I'd be there with them, but I need to stick close to home as my Mom isn't doing well healthwise. The rebuild of the K10 and my 8.1 swap sucked up most of his wrenching time over the last year.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 03-23-2022, 09:32 PM   #356
twotonecrew
Jumping on the 8.1L band wagon, well I have been on it for a while but finally getting to do some work on mine. Wanted to thank you Larry for all the information that you have provided on this swap. I was wondering if anyone has ever put one of Raylar's superchargers on one of these while doing the swap? It is something that I am looking into and thinking it would be a lot of fun. Only thing I am wondering about is the pulley set up as I am running the brackets for the top mount a/c compressor. Called Raylar but haven't heard back form them. We will see where that goes.
twotonecrew is offline   Reply With Quote
Old 03-23-2022, 10:57 PM   #357
bennylava
bennylava's Avatar
I noticed in an early post that you steamed cleaned the engine bay after removing the engine. Which steamer did you use? And did you do any scrubbing, or did the steam handle most of it?
bennylava is offline   Reply With Quote
Old 03-24-2022, 10:59 PM   #358
Zoomad75
K5Camper
Zoomad75's Avatar
The guy I got my 8.1 from put a Raylar supercharger on an 8.1 in his 3/4 ton Yukon XL. He later used it on a PSI 8.8 block with a stroker crank that makes 9.5L and the blower. I got to ride in with the blown 8.1. Rowdy. I'll put it this way, with the 8.1 it was way quicker than a 3/4 ton Yukon was ever intended. With the 9.5 he told me it loses traction in 3rd gear north of 60mph.
As fun as it was, for what I do with mine it would be complete overkill. It's worth every penny though. I saw it before he installed it. It was very well done.
Rob Z.
Old 04-01-2022, 01:04 AM   #359
twotonecrew
I finally talked with Larry from Raylar and he told me to keep the factory suburban brackets and notch the frame as the high mount a/c compressor would cause problems with clearance and the new supercharger. So now I face that dilemma, ditch the supercharger idea or notch the frame.
Old 04-01-2022, 10:44 PM   #360
Zoomad75
K5Camper
Zoomad75's Avatar
I'm not a fan of cutting the fame. Even less so if you are stuffing a heavy blown big block right on the area of the frame that would need to be chopped up.
I guess it really depends on what the primary goal is with the truck. For Larry and I, having the blower is pointless as the power isn't needed like that off road 100 miles from pavement. If you plan on drag racing or embarrassing diesel bros with a blown 8.1 on the street, it may not be as much of an issue to chop the frame for ac compressor clearance.
Squarebody's have notoriously flexy frames so it wouldn't be my first plan to chop the frame and stress it further with a blown big block. But it ain't my truck.
Rob Z.
