04-26-2012, 03:59 AM | #351 |
Re: 86 squarebody made2drag
you could even make a hideaway underfloor partition under the frontpart to cleanly store stuff like jack wheelwrench jumpercables and assortment of tools bits bobs and thingamajigs if the space between the bedfloor and the double floor is high enough you might even be able to put the spacesaver sparetire under there
funny thing about murphies law; flat tires allways happen when you got like tree quarts of firewood stacked in the bed the tools and sparetire and jack would be under the load
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
04-26-2012, 11:08 AM | #352 | |
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
04-26-2012, 11:09 AM | #353 | |
06-04-2012, 07:05 PM | #354 |
any more work done to the truck? or whats next to be done to the truck?
06-09-2012, 05:23 PM | #355 |
im just enjoying it...its kind of how i want it...maybe an amp and a pair of 8's next. i usually dont work on stuff much during the summer due to the 90% humidity and 100 degree weather....i sweat just walking to the mailbox and back and its only june. and i only drive it about twice a week....ill be working on the 67 c10 soon...
06-11-2012, 10:26 AM | #357 |
thanks
06-13-2012, 06:41 PM | #358 |
Jason
Just lookin through thread. Great job!
Posted via Mobile Device |
06-19-2012, 10:47 AM | #359 |
Are you running spindles up front? Any other front drop besides the bags?
'82 C10 2WD SB. 350/4spd (floor) |
06-19-2012, 12:52 PM | #360 | |
to do it right, get a 3 inch spindle and 2700 airbags. you'll have a great ride, it would take half the air to raise the front and your tires wont wear down on the inner part because your camber would be close to factory. my camber corrects all the way, when i air it up to ride hieght. right now my focus is on my new project. a 78 blazer 2wd.
06-19-2012, 01:15 PM | #361 |
Thanks for the info, man.
Really wanting to drop mine. No interest in taking my brakes apart and having to take a sledge to get everything off. But yeah, I could see how bigger bags would ride nicer and a drop spindle might be worth it. Great truck you've built there.
06-20-2012, 12:08 PM | #362 | |
see the pic in the very beginning of my thread
07-13-2012, 12:48 AM | #363 | |
07-13-2012, 01:09 AM | #364 |
are those metal plastic or rubber fenders ?
07-13-2012, 01:10 AM | #365 |
07-13-2012, 01:15 AM | #366 |
i tried to find those in the netherlands but they where costing an arm and a leg
over here they usually buy plastic fenders , guess i need to look further
07-13-2012, 01:19 AM | #367 |
07-13-2012, 06:08 AM | #368 |
i might be able to find them cheaper to when i go to a agracultural kindah store or a trailerbuilder too , the only place i checked sofar was a semi truck accessoryshop i know there here somewhere
i used to mount quite a few of them some 20 or so years ago under trucks im still kindah in the air about the work to make them fit , the sloshtubz are basicly plug and play but there big and prolly expensive to schip to europe
07-13-2012, 09:57 AM | #369 |
i could do trailer fenders and i have looked at them at tractor supply co. they are 40 bucks each. the money doesnt bother me...what bothers me is...if i were to put them on...weld them in and prime them...then what? the bed liner was sprayed in a decade ago...unless i get it re-bedlined it wouldnt match. i kind of like the extreme look it gives to onlookers..
07-13-2012, 10:02 AM | #370 |
As long as you're happy with it it's perfect
07-13-2012, 10:04 AM | #371 |
Might could fab up covers for the bed and inner fender holes. Paint them to match the truck and bolt them in. The contrast might look pretty cool.
07-13-2012, 12:11 PM | #372 |
not a bad idea
07-13-2012, 12:15 PM | #373 |
im still thinking about doing a 4 inch raised floor that has hinges on the cab side of the bed. kind of like a tonnou cover but diamond plate aluminum....and let it dull so it wouldnt stand out so much or maybe paint that and the covers body color. and maybe even integrate covers into the hinged floor....
07-13-2012, 02:51 PM | #374 |
i think it would be better to just have the daimondplate powdercoated flat grey , bare aluminium turns intoo white powder over time after its dulled its kindah like rust besides it reacts to the metal frame it will be bolted on
08-17-2012, 11:19 AM | #375 |
Subscribed! Keep it up!
